cisco 4235 IDS in GRUB>
was trying to recover password..entered to "recovery mode", during recovery i restarted the IDS. after reboot the IDS device is going to GRUB> and NO commands are working.....
kindly advice..
Re: cisco 4235 IDS in GRUB>
If you have a Recovery CD, then boot to the CD and re-image everything.
If you don't have a CD, then reboot it and when the GRUB menu comes up try and select the Recovery Partition option from the Grub Menu.
The Recovery Partition may cause multiple reboots in some versions. Be sure to let the Recovery procedure complete before attempting to login or modify the sensor.
I am getting the following error when i try to 'boot' from grub>
"kernel panic:VFS:Unable to mount root fs on 09:00"
kindly suggest..
Thanks Marcabal, it worked..
277
