07-24-2008 08:15 PM - edited 03-10-2019 04:12 AM
I have an ASA 5520 with 4GE SSM module.
In the ASDM, I see the basic IPS signatures...anyway to upgrade these signatures, add to them, etc?
Solved! Go to Solution.
07-26-2008 03:05 AM
Not really, you need to purchase the AIP-SSM module for that.
Farrukh
07-26-2008 03:05 AM
Farrukh
07-30-2008 07:24 AM
Farrukh is correct, you'll need one of the AIP-SSM modules. Unfortunately, there is only one module slot in your ASA520, so if you want to use an AIP-SSM, you'll have to give up your 4 port GigE module.
