Cpu utilization of NIDS 4235
Kindly indicate the command to know the IDS cpu utilization.Thanks in advance
Gold
Re: Cpu utilization of NIDS 4235
An a non service user, try:
show statistics host
As the service user try (this will give you much better insight into utilization):
top
Thanks for ur response.By using the above command i m finding only mem usage..i need to know the cpu utilization
Gold
You don't mention which version of software you're using, but with 6.x it shows a bunch of statistics including CPU. You have to "page" through them.
# show statistics host
General Statistics
NTP Statistics
Memory Usage
Summertime Statistics
CPU Statistics
Usage over last 5 seconds = 44
Usage over last minute = 36
Usage over last 5 minutes = 26
Thanks for ur response.My ver is 4.1(5)..showing like bellow..
IDS# sh statistics host
General Statistics
Last Change To Host Config (UTC) = 03:58:53 Tue Dec 04 2007
Command Control Port Device = eth1
Command Control Port Type = tx
Network Statistics
eth1 Link encap:Ethernet HWaddr 00:0D:56:FD:7B:97
inet addr:172.X.X.X Bcast:172.
x.x. Mask:255.255.252.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:57782472 errors:0 dropped:0 overruns:0 frame:0
TX packets:25549317 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:2342748677 (2234.2 Mb) TX bytes:3744649148 (3571.1 Mb)
Interrupt:16 Base address:0xdcc0 Memory:feb20000-feb40000
NTP Statistics
status = Not applicable
Memory Usage
usedBytes = 911388672
freeBytes = 10133504
totalBytes = 921522176
Swap Usage
usedBytes = 0
freeBytes = 0
totalBytes = 0
Gold
4.x? sorry, can't help you there, I haven't used that version in years.
Silver
I don't know if this method is supported
by Cisco TAC but you can do it quite easily.
I tested this on version 4.1. By the way,
IDS version 4.1 is a LinuxOS.
a- create an account called "test" and assign "service" privilege,
b- logout of the IDS and log back in with
the test account. This will put you in
bash shell,
c- type "su -" and enter the "admin" or "root" password,
d- now you are in superuser mode, type "top".
This will show you cpu usage in real-time.
Thanks a lot..It is working..but its is showing separatly like bellow..What is the meaning of nice in that...so to know the total cpu usage i have to add the all usages apart from idle usage..
CPU states: 18.4% user, 3.7% system, 3.1% nice, 74.7% idle
Silver
How familiar with Unix/Linux? That's how
it works. Another command you may want
to use is "vmstat x" where x is the number
of seconds you want it to repeat.
CCIE security
180
