CSA 5.2 245 and EFS
When attempting to encrypt folders in windows that contain .exe's and scripts the following CSA rule fires and blocks access:
Configuration > Rule Modules > Windows Rule Modules > Windows LSASS Security Module [V5.2 r245] > Rules File access control [137]
We don't want to fully disable this rule. Is there a workaround that will allow EFS to work without fully disabling the rule?
I haven't been able to decypher the difference between EFS encrypting a file and any other type of lsass.exe file writes..
Any suggestions?
Thanks!
Jennifer
1 REPLY
Bronze
Re: CSA 5.2 245 and EFS
Here's the process to create the rule for administrators:
1. Configuration> Rule Modules> Windows Rule Modules> [New]
2. Enter {Name} & {Description}
3. Under "State Conditions"
select "Apply this rule module only if the following state conditions are met"
check "User State Conditions"
select "Administrators"
4. Click on [Save]
5. Click on [Modify rules]
6. Click on [Add rule] and then [Agent Service Control]
7. Enter {Description}
8. Under "Query Settings" Select "Agent Service Control - Disable agent security"
9. Under "when" check "attempt to disable the agent security"
10. Click on [Save]
169
