06-27-2006 07:47 AM - edited 03-10-2019 03:04 AM
From the documentation it looks like the CSA Management Center will only work with SQL 2000. Does CSA work with SQL 2005? The server we will need will have 4GB of RAM. Using SQL 2005 will allow us to use the Standard version of SQL instead of the Enterprise version. This will save a significant amount of money.
06-27-2006 09:14 AM
Why can't you buy Standard 2005 and use Standard 2000? I believe MS allows this.
Tom S
06-27-2006 09:20 AM
SQL Standard 2000 only recoginizes 2GB of RAM. To leagly install Enterprise 2000 I would need to purchase Enterprise 2005. The 2005 version will address the ammount of memory that the OS version will address.
06-27-2006 09:58 AM
How many agents are you deploying?
06-29-2006 05:32 AM
Sorry for the delay. We are deploying around 2000 to start with. We have decided to only go wiht 2GB of RAM and add a 2nd server to split the database from the other functions as we grow.
Thanks for your help.
06-29-2006 12:09 PM
Sounds good. We have 3500 on one 4.0.x server now with 1GB RAM. I think we will move to a two server configuration with a remote DB when we go to 5.X
Tom
