CSA rule to allow protocol for particular time
fisko
Hello!
How to make a rule for exapme for network acccess that will allow http for 5 minutes from boot?
tsteger1
Level 8
Level 8
The "Roaming - Force VPN [V5.2 r245]" rule module has most of this set up already.
Just make a similar rule module that only has the 'System booting' system state and go from there.
Tom
Just remember that "System Booting" is not defined by "when does my login prompt appear" but is active until all services have started on your windows box. Also i believe that Roaming VPN is using a dynamic application class that won't actually enforce the 5 minute rule, since it will just give you another 5 minutes if you close the application and open it again, since the "add process to class" rule is enabled in all system states.
