Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Highlighted
Community Member
CSA500186 always trigers rule 178
All applications, I started on my latop, triger the rule 178.
"The process 'C:\Program Files\Microsoft Office\OFFICE11\OUTLOOK.EXE' (as user KFKI\eperjesitamas) attempted to call the function VirtualProtect from a buffer (the return address was 0xa524e6). The code at this address is '8b55086a 00546a40 5152ff15 04c6a500 5983f800 74138b4d 0c8b5508 5152ff15' This either happens when a process uses self-modifying code or when a process has been subverted by a buffer overflow attack. The operation was allowed. "
Is this normal and I need to allow all my softwares to run?
1 REPLY
Blue
Re: CSA500186 always trigers rule 178
1. Is this only your laptop?
If so, it may be something else you have installed or the way Outlook is configured.
2. Is the code pattern always the same?
If so, you could create an exception based on the code pattern when Outlook makes that call from a buffer.
Tom S
165
