I am trying to add a custom signature in CSM3.0 for IDSM2 which is running IPS5.1 in cat6500.I am using custom
wizard to create the custom signature ( say "sweep" ).Under sigature, IPS5.x, I could see the created custom signature but when the sigature triggers, IPS event viewer shows only the old ( built in - sweep )signature ID and not the customized one.
Just to test the changes in effect,
I tried to change the event level say "low" to "high" for one of the built in signature( sweep 2100) by editing the same.Display shows the changed level, but when the sigature triggers the IPS event viewer shows the level as "low" instead of "high".
Also I tried with enabling the check box for the option " retire".
How do I create and test the customized signature..I tried with both IDM and CSM3.0.Any suggestions...
