Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Downgrade IPS 5.1(1) to IDS ver 4.x
Hi all,
I want to know, step to complete this task because I know when I upgrade to 5.0, downgrade cannot be run.
So I want to return the previous version, through re-image the sensor, I try to do it but error messages appear
<i@10.1.185.2/WS-SVC-IDSM2-K9-sys-1.1-a-5.1-1.bin.gz
Downloading the image. This may take several minutes...
Password for amzaini@10.1.185.2:
ftp://amzaini@10.1.185.2/WS-SVC-IDSM2-K9-sys-1.1-a-5.1-1.bin.gz (7893K)
/tmp/upgrade.gz [########################] 7893K | 12164.41K/s
8082832 bytes transferred in 0.65 sec (12162.54k/sec)
ERROR: /tmp/upgrade.gz: unexpected end of file
root@BR05IDS02.localdomain#
Any one has idea??? ASAP
1 ACCEPTED SOLUTION
Gold
Re: Downgrade IPS 5.1(1) to IDS ver 4.x
We've had many problems re-imageing sensors back to 4.x due to teh fact that it has to be done via TFTP. One of the primary problems is getting a TFTP server on a connection with the sensor that has enough bandwidth, otherwise we experienced timeouts. You will also need a TFTP server that can handle large files (not all can). We found this free TFTP to work well:
http://perso.wanadoo.fr/philippe.jounin/tftpd32.html
Check the file on your 10.1.185.2 ftp server.
The above output shows that is downloaded a 7893K file which is too small for the WS-SVC-IDSM2-K9-sys-1.1-a-5.1-1.bin.gz file.
Look at he download page for the WS-SVC-IDSM2-K9-sys-1.1-a-5.1-1.bin.gz file:
http://www.cisco.com/cgi-bin/tablebuild.pl/ips5-cat6500-idsm2-sys
You will see that the file should be 23369742 bytes (22822K approximately).
So it looks like the file on your ftp server is incomplete if it is only 7893K.
You would need to download the file again from CCO and place it in your 10.1.185.2 ftp server. Once it is on your ftp server you will want to compare the file size against the file size listed on CCO to ensure you have the complete file before you even attempt the imahe installation.
If I remember right there had been a problem before where downloading the file using Internet Explorer would sometimes cause an issue. Internet Explorer itself would attempt to unzip the file because of the gz file extension, and you would wind up with a corrupted file.
If you do run into this issue then try using a different browser (like Mozilla).
This problem was only seen with the IDSM-2 System Images because of the .gz extension on the filename. All other files (like major, minor, and signature updates, as well as system images for other systems) end in either a .pkg or .img extenstion and so are not corrupted by Internet Explorer during download.
Gold
Hi all,
I would like to say thank for anybody has give me advise, solutions and committed with my questions, because the problem has been solved when I using another FTP server.
I thing this issue about FTP and large file
Thank for information.
So now, I need to download file again using mozila and let me try to downgrade IDSM2 first before update later
345
