error upgrading IDSM2 5.1(4) past s261
I have a 6500 IDSM2 at 5.1(4) + S261. When I attempt to upgrade to S267 or S268, I get the error msg:
Error: execUpgradeSoftware : Error status returned with status str Internal Error.
I have rebooted the IDS - no difference. I'm using "upgrade http:" with http sw which has always worked in the past. What should I look at?
Re: error upgrading IDSM2 5.1(4) past s261
You could try the same sigupdate using ftp or scp as the file transfer protocol. If this fails, then you will probably need to generate a "show tech" and open a cisco tac case.
Green
I assume you're using the "minreq-5.1-2.pkg" filename for version 5 sensors?
Yes, the sig update I tried is:
IPS-sig-S268-minreq-5.1-2.pkg
I suppose I could consider imaging the IDS up to v6, which would probably avoid the problem.
Further info: I reimaged the sensor to v6. Same error.
It appears that UPGEADE HTTP: is no longer supported for sig application. As soon as I tried an UPGRADE FTP:, everything works.
137
