07-31-2009 08:14 AM - edited 03-10-2019 04:43 AM
I am getting an error
"Error occurs when start polling event(- IOException: Connection Refused: connect." It was working. Any ideas?
08-05-2009 04:17 PM
What exactly are you trying to do here and where do you see this message on. Will need more details to comment.
08-05-2009 04:23 PM
I figured it out. There was no configuration problems on AIP-SSM itself. The problem was with the IME client application. It could not communicate with the a backend service that is installed with IME on the monitoring station. I reinstalled the client app. And everything works now. This is the first time that I have used IME. I didnt not know that there was a service in the background and assumed that it was configuration issue with AIP.
My mistake...
Thanks for the reply.
08-05-2010 05:44 PM
Hi there,
I have got the same issue here, I will try to install the new version and see if will work. However i didnt understand exactly what you meant by " It could not communicate with the a backend service that is installed with IME on the monitoring station"
can u clarify please?
08-05-2010 07:34 PM
I guess i know what u mean, The service within windows was stoped? that was my problem anyway, got it solved
thanks.
