the below error is shown whenn trying to update a 4240 IPS , i tried the solution mentionned in this page https://supportforums.cisco.com/docs/DOC-3589
but the directory /usr/cids/idsRoot/var/virtualSensor and /usr/cids/idsRoot/var/virtualSensor does not exist
the below was found in the directory /usr/cids/idsRoot/var/
bash-2.05b# cd /usr/cids/idsRoot/var/
bash-2.05b# ls
H225Q931Regex2.pmz fixed-tcp.pmz
H225SetupRegex1.pmz fixed-udp.pmz
application-policy-enforcement-http.bod1.pmz iplogs
application-policy-enforcement-http.ctm1.pmz multi-string-tcp.pmz
application-policy-enforcement-http.ctv1.pmz multi-string-udp.pmz
application-policy-enforcement-http.met1.pmz nac.shun.txt
application-policy-enforcement-http.xfr1.pmz service-http.pmz
application.policy.enforcement.ftp1.pmz state.pmz
atomic-ip-advanced.pmz string-tcp.pmz
eventStore updates
events.tar.gz
does deleting the .pmz files will solve this issue
thank you
