How to disable wireless and bluetooth
Is it possible to control this two protocols with CSA 4.5.1.539 ? All I get is a warning for detection of unauthorized network component for wireless ('s24trans'). There is no option for blocking or something in this way.
Re: How to disable wireless and bluetooth
Could you please send the exact warning that you are getting
Blue
The Sniffer and protocol detection rule only monitors non IP based protocols. You can stop these messages by putting them in the exceptions list for this rule.
If you are trying to control them, you'd need to deny access to the drivers to prevent them from loading.
Warning
An unauthorized Network Component, 's24trans' was detected registering with the system. The operation was allowed.
Details Rule 123
Blue
All that rule does is monitor the non-IP protocols. You can choose not to monitor them by putting them in the exception list.
If you are trying to disable Bluetooth and wireless, you need to go about it in a different way.
Tom
277
