Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
how to upgrade IPS 5.1(6)E1 to 6.0(1)-E1.
Hi ,
Iam facing problem in configuring IPS SSM in ASA 5520
1)Its not taking the ip on virtual sensing interface.
2)iam not able to ping the management ip address although the gateway is pingable.
this is the show config of SSM Module.
Do i need to upgrade it to 6.0(1)-E1
! Version 5.1(6)
! Current configuration last modified Tue May 2
service interface
physical-interfaces GigabitEthernet0/1
description "SSM Interface"
exit
exit
service analysis-engine
virtual-sensor vs0
physical-interface GigabitEthernet0/1
exit
exit
service authentication
exit
service event-action-rules rules0
exit
service host
network-settings
host-ip 192.168.1.1/24,192.168.1.2
host-name iyogi_SSM
telnet-option disabled
exit
time-zone-settings
offset 0
standard-time-zone-name UTC
exit
summertime-option disabled
exit
service logger
exit
service network-access
exit
service notification
exit
service signature-definition sig0
exit
service ssh-known-hosts
exit
service trusted-certificates
exit
service web-server
port 443
exit
1 REPLY
Silver
Re: how to upgrade IPS 5.1(6)E1 to 6.0(1)-E1.
1) IP address cannot be assigned on sensing interfaces.
2) When you say gateway(192.168.1.2) is pingable, do you mean its pingable from the module?
If so, are you able to ping management IP(192.168.1.1) from the gateway and 192.168.1.0/24 network?
Vibhor.
Where are you trying to ping management ip from? What is the source IP address?
143
