Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
how to use Cisco ASA5510 as an IPS
We have a Cisco ASA5510 w
ith ASA-SSM-10 module but we´d like to know how to configure it as
an IPS. We have it in the same network but in a simulate enviroment 2 different network segments.
Everyone's tags (2)
1 REPLY
Re: how to use Cisco ASA5510 as an IPS
You need the ASA to pass traffic through the IPS as explained in http://supportforums.cisco.com/docs/DOC-5668
Note that since this is a different module you will need something like
access-list ips-acl extended permi ip any any
class-map ips-class
match access-list ips-acl
policy-map global_policy
class ips-class
  ips fail-open
service-policy global_policy global
Then you can start configuring the ips following its config guide to fire on signatures etc.
I hope it helps.
PK
4594
