10-03-2013 06:23 AM - edited 03-10-2019 06:03 AM
Have a question regarding HTTPS traffic going through IPS (AIP-SSM). I understand that Cisco IPS cannot monitor encrypted traffic except monitoring the headers and trailers. So,
- Does it mean there's no use of sending HTTPS traffic to AIP-SSM (unless the purpose is to monitor HTTPS headers and trailers)?
- What kind of protection can be expected by just looking at headers and trailers?
Is there any recommendation whether HTTPS traffic should be sent to AIP-SSM or not?
10-03-2013 06:27 AM
we had a similar problem - we solved it by using a F5 as reverse proxi and terminate the HTTPS/SSL session on the F5 and run un-encrypted from there - and pass the traffic through their ASM module which is similar to the IPS module - and in fact afterwards we also pass the traffic through a ASA and IPS module - but now un-encrypted...
10-04-2013 04:25 AM
Thank you tiwang but it's not a problem for me to not send HTTPS traffic through AIP-SSM. I am fine with not sending HTTPS traffic to AIP-SSM if there's no real use of it as it will be encrypted. So, as I had asked earlier, I just want to know:
- What kind of protection can be expected by just looking at headers and trailers of HTTPS?
10-04-2013 05:22 AM
To evaluate what you get by inspecting the encrypted traffic, you can look at the signatures. These Signatures have "HTTPS" in the name. Of course there are even more signatures that work in general on TCP and so on:
But at least the "Malformed Handshake" Signature caused lots of false positives in my environment.
I don't really have any general recommendations for that. With limited time to work on the sensor I wouldn't care about HTTPS, but if you have some time to implement it, it won't hurt and will give you a little bit better protection.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
