IDM and IDS sensor can manage FW for TCP reset ?
iqbalkhan
HI
I have found that
IDM and IDS Sensors are used to manage a Cisco router for TCP Reset.
BUT If I want Cisco FIREWALL in place of Router then it can possible ? if yes then give me the document link .
Thnaks
Biplob
mhellman
Level 7
Level 7
The TCP Reset functionality is completely separate from the ability to use a router/firewall to block. Yes, you can use a Cisco firewall to block. See the "Configuring Attack Response Controller for
Blocking and Rate Limiting" in the user guide.
for v5:
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_configuration_guide_chapter09186a008055df77.html
for v6:
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_configuration_guide_chapter09186a0080618945.html
