Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ovt Bronze
Bronze
IDM constantly failing...
Hi!
IDM java applet is constantly failing on my machine. Sometimes the applet isn't even loaded. And usually all the IE windows disapper. I'm using IE 6.0.2800.1106 with JRE 1.5.0_06-b05. I've added the "-Xmx256m" into the JRE runtime settings. Am I missed something? What browser are you guys using?
Re: IDM constantly failing...
What version of IDS/IPS software are you running? If 5.0.x, have you applied the latest service pack to bring you to 5.0.5?
If you're running 5.1 and you're still hitting this problems you make need to install the p1 patch.
ovt Bronze
Bronze
5.0(5)
ovt Bronze
Bronze
This was probably due to a bad memory module.
Community Member
You mention that your ie windows just disappear. I had this exact same issue a while back and thought it was my PC. I got on another PC and had the same issue. I reimaged the sensor from the recovery partition and still had the same issue. Finally, I blew the entire image away and reloaded with tftp and then it worked.
I know this is not the ideal solution, but wanted to share.
M
155
