IDSM-2 "redundancy" in a single chassis
I understand how IDSM-2 redundancy could work having two 6500's...but what do you do when you are doing inline vlan pairs and the IDSM-2 fails and is no longer there to bridge the vlans together? How can the switch be setup to bridge the vlans in the event that the IDSM-2 fails?
Also, instead of pairing all the vlans that have SVI's on the FWSM, could I just pair the FWSM's VLAN/SVI on the MSFC with another vlan and get the same effect as pairing all the vlans that are on the FWSM? Thanks.
Gold
Re: IDSM-2 "redundancy" in a single chassis
I havn't tried this inside a 6500 chassis, but this works externally:
Set up your in-line sensors as multiple alternate paths connecting the two VLANs together and use spanning tree to assign one sensor path a higher STP cost. Once the primary sensor fails the traffic should re-route to the standby sensor. If you play with the STP settings you can get the switchover time down under a second.
I am not sure what you mean by "externally." this is an IDSM-2 which is a blade in the 6500 and there is only one of them in the 6500 chassis....otherwise I would do ECLB.
Gold
I meant that I have used this method with stand alone switches and appliance sensors, but it should be applicable to IDSMs and a 6500 chassis.
261
