04-05-2006 11:34 AM - edited 03-10-2019 01:57 AM
I need to upgrade the IDSM-2 Modules in my 6513 switches from ver. 4.x to 5.0.1. (a major upgrade). The procedures indicate "the system will be restarted at the end of the upgrade...". My question is which system will restart? Will just the IDSM-2 module reboot or the entire switch?
Solved! Go to Solution.
04-06-2006 01:29 PM
Just the IDSM-2, not the switch.
04-06-2006 01:29 PM
