06-16-2008 11:20 PM - edited 03-10-2019 04:09 AM
I am upgrading IDSM-2 image from v5 to v6 (IPS-K9-6.0-4a-E1.pkg) after this upgrade do we need to go for the Upgradation of Recovery Partition ?
Thank you,
Dinesh
Solved! Go to Solution.
07-19-2008 04:26 AM
Every thing is same as shown in document, but i am not able to see any logs, If i keep same vlan on SPAN logs are there.
Any trouble shooting steps or tools are there ?
07-19-2008 09:03 AM
If you Inline VLAN Pair is not functional, then no traffic will pass through anyway. You can try to ping between any two devices in the 'bridged' VLANS.
Farrukh
07-22-2008 09:34 PM
My configuration is like this,
firewall vlan-group 2 10,100
Vlan 10 Inside & Vlan 100 is outsie interface of the FW Context,
I created on L2 Vlan 101
and added this VLAN (10 and 101) in VLAN PAIR config and this interface giga 0/8.1 (Subinterface). same interface is config for Virtual Sensor 0.
I dont have problem with traffic but not able to see any logs.
07-23-2008 11:04 PM
07-26-2008 02:58 AM
In which mode is the sensor operating?
Auto/Bypass etc.
Farrukh
07-27-2008 11:16 PM
It is in Auto (Bypass inspection when analysis engine is stopped.)
Is this will create a problem ? or do we need to change it to ON & OFF.
07-27-2008 11:21 PM
Nah Auto is fine. Can you post the configs? (show config)
Farrukh
