IDSM2 System Image Upgrade
zakid
Dear all,
Current running System Image is 6.0(1)E1, whether I can upgrade direct to 6.1(1)E2 or I have to go step by step like 6.0(2)E1 and then next. In addition I want to know if I upgrade, the current configuration will lose or not. kindly
update.
thanks & regards,
5 Replies 5
Farrukh Haroon
From Cisco:
"The minimum required version for upgrading to 6.1(1) is 5.0(1) or later, which is available as a download from Cisco.com.".
You won't loose any configs but just keep a backup handy and check the release notes for any particular caveats related to your specific platform:
http://www.cisco.com/en/US/docs/security/ips/6.1/release/notes/17173_01.html#wp1114017
Farrukh
many thanks.....
Dear after I upgrade from 6.0(1)E1 to 6.0(2)E1 the sensor restart and gone to status other, after a while the status showing powerdown. will you please show me how to rectify.
thanks & regards
Try one of the following:
hw-module module 5 boot 0
hw-module module 5 boot 1
hw-module module 5 boot 2
Whichever works :)
Farrukh
Hai dear, thanks for your comments.....
unfortunately i have to complete this task very urgent. so I reimage system files 6.1(1)E1. its working fine.
thanks & Regards,
Glad you managed to fix it :)
Farrukh
