IEV 5 and IPS 6.0
Does IEV v5 support IPS 6.0? If not, will there be a new version of IEV?
Re: IEV 5 and IPS 6.0
IEV 5 and IPS 6.0 should operate together. It is not anticipated that a new version will be required.
Scott
Scott,
Has Cisco "tested" IEV 5.2(1)with IPS v6 ?
I need something better than "they should operate together".
I'm sure there are other IEV users who need to know a more definitive answer as well.
For the folks not using CiscoWorks or MARS, IEV is the only Cisco tool we have for reviewing event data on the IPS.
Thanks for any additional info -
David
David,
Yes, Cisco has tested IEV 5 against with IPS 6. From Readme.txt file:
IEV 5.1(1) introduced the following new features and major changes:
-- Added support for 5.0, 5.1 and 6.0 sensors, (4.x & 3.x are not
supported).
-- Added display features in GUI tables for new IPS 5.X and 6.0 fields.
IEV is being supported, so the TAC can open bug reports against it if any issues are found. We will also monitor this forum for issues as well.
Scott
Thanks Scott -
You said everything I wanted to know...
Thanks Again,
David
173
