08-04-2012 11:28 PM - edited 03-10-2019 05:44 AM
I have an ASA-5520 with a IPS-SSM-40. I configured the IPS control port to an ip address on the ASA's inside network subnet and connected it to the same switch as the ASA's inside port is connected to. I am using a single context. What vlan should the switch port be on that connects to the IPS?
I can SSH to the ASA and go to session 1 and see the config. But I cannot connect thru the ASDM.
ASA 5500 Series Security Services Module-40
Model: ASA-SSM-40
Hardware version: 1.0
Serial Number: JAF1545CBNM
Firmware version: 1.0(14)5
Software version: 6.0(6)E4
MAC Address Range: 44d3.ca0f.0413 to 44d3.ca0f.0413
App. name: IPS
App. Status: Up
App. Status Desc:
App. version: 6.0(6)E4
Data plane Status: Up
Status: Up
Mgmt IP addr: 192.168.0.12
Mgmt web ports: 443
Mgmt TLS enabled: true MAC Address Range: 44d3.ca0f.0413 to 44d3.ca0f.0413
App. name: IPS
App. Status: Up
App. Status Desc:
Status: Up
Mgmt web ports: 443
08-05-2012 12:39 AM
what is your PC ip address, and can the PC connect to the IPS module ip address?
Have you configured access-list on the IPS module itself to allow your PC to manage it?
You can just run the "setup" command once you session into the module from the ASA, and there will be an option to add the ip address/subnet to manage the IPS.
08-05-2012 09:03 AM
I am working remotely, so my IP address changes. Just for initial setup I have the access-list set to 0.0.0.0/0 so thats not what is stopping it. I can ssh to the ASA, then go to session 1, and I am in the IPS-SSM. I cannot https directly to the sensor. The control interface, gi0/0 is up. From the sensor I can ping the gatewayand the ASA inside address.
I keep getting an error:
error connecting to sensor. error loading sensor
08-06-2012 12:05 AM
When you say you are working remotely, are you connecting from the internet? or are you VPN in and then trying to access the IPS module?
Can you pls share the ASA config too. Thx
08-06-2012 10:01 AM
I am running ASDM and Putty from the internet. AnyConnect is setup and works. Config file is attached.
PS. I notice in the older support forum posts that this problem was common in version 6 and not so much in version 7. Should I just load version 7 on the IPS-SSM?
08-07-2012 12:41 AM
great idea.. pls upgrade to the latest version of 7.x
08-08-2012 06:46 AM
I tried to upgrade, but I could not do it remotely. The ASA could not reach my laptop with tftp. I used AnyConnect to start a VPN session that I thought would carry the tftp, then opened a Putty session to the ASA outside address. I could not ping the tftp server from the ASA.
So I must have an error in the firewall configuration, which is probably the root cause of my original problem. I looked at the NAT section and the outside ACL and made a change but it didn't help. On the ACL I added a permit from the vpn subnet to the inside subnet. In NAT I added a static translation from the IPS management address to the vpn subnet in both directions.
Any ideas?
08-08-2012 08:58 AM
The config that you have earlier should already allow access to the IPS via AnyConnect. Pls remove the config that you have just added as it sounds incorrect.
Can you ping the IPS from the AnyConnect client?
I assume that you can ping 192.168.0.31 and 192.168.0.4 when you are connected via AnyConnect, right?
If you can, then you should be able to ping 192.168.0.12 as well. I also assume that the port on the module is connected to the same switch where the ASA inside interface is connected.
Can you install a TFTP server on a host on your inside network, and transfer the image to the IPS module via an inside host. I assume you can RDP to an inside host once you are connected via AnyConnect.
08-08-2012 08:45 PM
No I cannot ping either address from the AnyConnect client. They are connected to the same switch on the inside.
08-09-2012 05:39 AM
Meaning, your AnyConnect is never working?? or are you able to access anything with your AnyConnect?
Which tunnel-group do you use?
08-09-2012 05:59 AM
I am using tunnel group=Creamery AnyConnect which uses GroupPolicy_Creamery Anyconnect. Most of the tunnel groups are from the original PIX that this ASA is replacing and only do IPSEC.
08-09-2012 09:22 PM
Pls add the following:
access-list split-creamery-acl permit 192.168.0.0 255.255.255.0
group-policy "GroupPolicy_Creamery Anyconnect" attributes
split-tunnel-policy tunnelspecific
split-tunnel-network-list value split-creamery-acl
08-10-2012 01:15 PM
Jennifer,
That didn't work either. I still can't ping. I am going to convert this to a TAC case.
Mike
08-11-2012 03:06 PM
Jennifer,
Thanks for all your help. There was nothing wrong with the ASA after all. It turned out to be a routing statement in the core switch.
