02-27-2006 02:21 PM - edited 03-10-2019 01:54 AM
Hello,I am quite fluent with pix/ios, and understand the fundementals well. I will be installing my first CSA soon. Is the online documentation good enough to get this done?
TIA
Shervan
Solved! Go to Solution.
03-03-2006 08:06 AM
CSA automatically disables it when installed.
02-27-2006 10:50 PM
I'm assuming your talking about installing the CSA Management Console.
Installing the CSAMC on CiscoWorks is fairly straight forward. Configuring the CSA policy's is a whole nother thing. Most installations usually take a couple of months to complete even then you have to continue to tune your policys weekly.
Patrick
02-28-2006 05:50 AM
Buy this book to help supplement the documentation:
Cisco Security Agent by Chad Sullivan. Published by Cisco Press.
It will give you some ideas about setting up a pilot program. As Patrick accurately mentioned, most installations do take a couple of months. Tuning of policies is an iterative process that consumes plenty of time of the beginning but which becomes easier as you get to know the CSA product and how it interacts with your network.
Hope this helps.
03-02-2006 12:24 PM
Hello
I realise that CSA can be classed as a firewall that is 'signatureless'. Would I however still requre a formal firewall that does rely on signatures, eg windows XP standard or any other 3rd party product.
What about a antivirus scan engine..would one be needed on clients
TIA
03-02-2006 01:58 PM
CSA doesn't work well with other software firewalls installed on the client. It's network shim does the firewall capability. You should still install an anti-virus application on the client because it will enable you to remove the malware should the PC become infected. CSA will help stop the spread of the virus and keep it local.
03-03-2006 06:24 AM
Hello, thanks for the feedback
Does this mean disabling XP standard firewall?
TIA
03-03-2006 08:06 AM
