Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
IP SLA issues - 2900 series
Hello all. I'm running a 2900 series router and I'm trying to get SLA to work. I have a few issues. The main one is I can not seem to ping from either g0/0 or g0/0/0 using ping 8.8.8.8 sou g0/0. Just fails. I can however ping from g0/1 which tells me that it's probably something messed up in my routes. I'm at a loss though.
Second issue I am having is that for some reason my VoIP system (192.) is wide open to the outside world on port 80 and 25, when it shouldn't be. None of those ports are open to the public that I can tell.
Here is the basics of the current running config:
boot-start-marker
boot-end-marker
enable secret 5
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip name-server 208.xxx.xxx.xxx
license udi pid CISCO2901/K9 sn
license boot module c2900 technology-package datak9
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Suddenlink
 ip address 66.xxx.xxx.xxx 255.255.255.0 secondary
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 description Inside LAN
 ip address 172.xxx.xxx.254 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1.10
 description MITEL
 encapsulation dot1Q 10
 ip address 192.168.200.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/0/0
 description Verizon LTE
 ip address 166.xxx.xxx.xxx 255.255.255.252
 ip nat inside
 duplex auto
 speed auto
ip local policy route-map LocalPolicy
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool FTP 172.xxx.xxx.61 172.xxx.xxx.61 netmask 255.255.255.0 type rotary
ip nat inside source static tcp 172.xxx.xxx.61 1723 interface GigabitEthernet0/0 1723
ip nat inside source static udp 172.xxx.xxx.61 500 interface GigabitEthernet0/0 500
ip nat inside source route-map nonat interface GigabitEthernet0/0 overload
ip nat inside source static udp 192.xxx.xxx.xxx 67 66.xxx.xxx.xxx 67 extendable
ip nat inside source static udp 192.xxx.xxx.xxx 68 66.xxx.xxx.xxx 68 extendable
ip nat inside source static udp 192.xxx.xxx.xxx 69 66.xxx.xxx.xxx 69 extendable
ip nat inside source static udp 192.xxx.xxx.xxx 100 66.xxx.xxx.xxx 100 extendable
ip nat inside source static tcp 192.xxx.xxx.xxx 3998 66.xxx.xxx.xxx 3998 extendable
ip nat inside source static tcp 192.xxx.xxx.xxx 3999 66.xxx.xxx.xxx 3999 extendable
ip nat inside source static tcp 192.xxx.xxx.xxx 4000 66.xxx.xxx.xxx 4000 extendable
ip nat inside source static tcp 192.xxx.xxx.xxx 5566 66.xxx.xxx.xxx 5566 extendable
ip nat inside source static udp 192.xxx.xxx.xxx 5567 66.xxx.xxx.xxx 5567 extendable
ip nat inside source static tcp 192.xxx.xxx.xxx 6800 66.xxx.xxx.xxx 6800 extendable
ip nat inside source static tcp 192.xxx.xxx.xxx 6801 66.xxx.xxx.xxx 6801 extendable
ip nat inside source static tcp 192.xxx.xxx.xxx 6802 66.xxx.xxx.xxx 6802 extendable
ip nat inside source static udp 192.xxx.xxx.xxx 20001 66.xxx.xxx.xxx 20001 extendable
ip nat inside source static tcp 192.xxx.xxx.xxx 44000 66.xxx.xxx.xxx 44000 extendable
ip nat inside source static 192.xxx.xxx.xxx 66.xxx.xxx.xxx route-map nonat
ip nat inside source static tcp 172.xxx.xxx.154 25 66.xxx.xxx.xxx3 25 extendable
ip nat inside source static tcp 172.xxx.xxx.154 443 66.xxx.xxx.xxx3 443 extendable
ip nat inside source static tcp 172.xxx.xxx.154 25 166.xxx.xxx.xxx 25 extendable
ip nat inside source static tcp 172.xxx.xxx.154 443 166.xxx.xxx.xxx 443 extendable
ip nat inside destination list 104 pool FTP
ip route 0.0.0.0 0.0.0.0 66.xxx.xxx.xxx track 100
ip route 0.0.0.0 0.0.0.0 66.xxx.xxx.xxx 250
ip route 172.xxx.xxx.0 255.255.255.0 66.76.12.0
ip route 192.168.1.0 255.255.255.0 172.xxx.xxx.10
ip sla responder
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 102 permit ip 172.xxx.xxx.0 0.0.0.255 172.16.4.0 0.0.0.255
access-list 103 permit ip 172.xxx.xxx.0 0.0.0.255 any
access-list 103 deny   ip 172.xxx.xxx.0 0.0.0.255 172.16.4.0 0.0.0.255
access-list 103 deny   ip 172.xxx.xxx.0 0.0.0.255 172.16.6.0 0.0.0.255
access-list 104 permit tcp any any range 12200 12300
access-list 105 permit tcp any any range 6800 6802
access-list 106 permit udp any any range 6004 6261
access-list 107 permit udp any any range 5004 5007
access-list 108 permit udp any any range 50098 50508
route-map MITEL permit 10
 match ip address 105 106 107 108
route-map nonat permit 10
 match ip address 103
snmp-server community public RO
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password
 login
 transport input all
scheduler allocate 20000 1000
end
Thanks!
186
