11-27-2005 04:59 AM - edited 03-10-2019 01:46 AM
Hello.
I can boot ips 4240 with ids 4.5 image.
Here is the log.
Please tell me how can i boot with this image?
rommon #5> set
ROMMON Variable Settings:
ADDRESS=192.168.1.1
SERVER=192.168.1.10
GATEWAY=192.168.1.10
PORT=Management0/0
VLAN=untagged
IMAGE=IDS-42XX-K9-r-1.1-a-4.0-1-S37.tar.tar
CONFIG=
rommon #6> tftftp
tftp IDS-42XX-K9-r-1.1-a-4.0-1-S37.tar.tar@192.168.1.10 via 192.168.1.10
Received 137617408 bytes
Bad magic number (0x55a68d31)
rommon #7>
rommon #8> reset
ROMMON Platform Reboot
Rebooting....
Booting system, please wait...
CISCO SYSTEMS
Embedded BIOS Version 1.0(5)0 09/14/04 12:23:35.90
Low Memory: 631 KB
High Memory: 2048 MB
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 2578 Host Bridge
00 01 00 8086 2579 PCI-to-PCI Bridge
00 03 00 8086 257B PCI-to-PCI Bridge
00 1C 00 8086 25AE PCI-to-PCI Bridge
00 1D 00 8086 25A9 Serial Bus 11
00 1D 01 8086 25AA Serial Bus 10
00 1D 04 8086 25AB System
00 1D 05 8086 25AC IRQ Controller
00 1D 07 8086 25AD Serial Bus 9
00 1E 00 8086 244E PCI-to-PCI Bridge
00 1F 00 8086 25A1 ISA Bridge
00 1F 02 8086 25A3 IDE Controller 11
00 1F 03 8086 25A4 Serial Bus 5
00 1F 05 8086 25A6 Audio 5
02 01 00 8086 1075 Ethernet 11
03 01 00 177D 0003 Encrypt/Decrypt 9
03 02 00 8086 1079 Ethernet 9
03 02 01 8086 1079 Ethernet 9
03 03 00 8086 1079 Ethernet 9
03 03 01 8086 1079 Ethernet 9
04 02 00 8086 1209 Ethernet 11
04 03 00 8086 1209 Ethernet 5
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(5)0) #1: Tue Sep 14 12:20:30 PDT 2004
Platform IPS-4240-K9
Management0/0
MAC Address: 000f.f775.5b7f
Use ? for help.
rommon #0> set
ADDRESS=192.168.1.1
SERVER=192.168.1.10
PORT=Management0/0
VLAN=untagged
CONFIG=
11-27-2005 05:05 AM
zone(0): 4096 pages.
zone(1): 225280 pages.
zone(2): 294912 pages.
DMI not present.
ACPI: Unable to locate RSDP
Intel MultiProcessor Specification v1.1
Virtual Wire compatibility mode.
OEM ID: OEM ID Product ID: PRODUCT ID APIC at: 0xFEE00000
Processor #0 Pentium 4(tm) XEON(tm) APIC version 20
I/O APIC #14 Version 32 at 0xFEC00000.
I/O APIC #13 Version 32 at 0xFEC10000.
Enabling APIC mode: Flat. Using 2 I/O APICs
Processors: 1
Kernel command line: ro ramdisk_size=76800 rootrw=/dev/hda2 root=/dev/ram0 hda=flash nousb console=ttyS0 tlv=BP9QABj+gAovdm1saW51ei1ycg==
ide_setup: hda=flash
Initializing CPU#0
Detected 2000.115 MHz processor.
Console: colour dummy device 80x25
Calibrating delay loop... 3984.58 BogoMIPS
Memory: 2042596k/2097152k available (1620k kernel code, 54160k reserved, 636k data, 136k init, 1179648k highmem)
Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Inode cache hash table entries: 131072 (order: 8, 1048576 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 131072 (order: 7, 524288 bytes)
Page-cache hash table entries: 524288 (order: 9, 2097152 bytes)
CPU: Trace cache: 12K uops, L1 D cache: 8K
CPU: L2 cache: 512K
CPU: Hyper-Threading is disabled
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
mtrr: v1.40 (20010327) Richard Gooch (rgooch@atnf.csiro.au)
mtrr: detected mtrr type: Intel
CPU: L2 cache: 512K
CPU0: Intel(R) Pentium(R) 4 CPU 2.00GHz stepping 09
per-CPU timeslice cutoff: 1462.76 usecs.
enabled ExtINT on CPU#0
ESR value before enabling vector: 00000000
ESR value after enabling vector: 00000000
Error: only one processor found.
11-27-2005 05:05 AM
ENABLING IO-APIC IRQs
Setting 14 in the phys_id_present_map
...changing IO-APIC physical APIC ID to 14 ... ok.
Setting 13 in the phys_id_present_map
...changing IO-APIC physical APIC ID to 13 ... ok.
..TIMER: vector=0x31 pin1=2 pin2=0
testing the IO APIC.......................
.................................... done.
Using local APIC timer interrupts.
calibrating APIC timer ...
..... CPU clock speed is 2000.1116 MHz.
..... host bus clock speed is 100.0054 MHz.
cpu: 0, clocks: 1000054, slice: 500027
CPU0<1000048>1000048>
Waiting on wait_init_idle (map = 0x0)
All processors have done init_idle
PCI: PCI BIOS revision 2.10 entry at 0xff648, last bus=4
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
PCI: Ignoring BAR0-3 of IDE controller 00:1f.2
Transparent bridge - Intel Corp. 82801BA/CA/DB/EB PCI Bridge
PCI->APIC IRQ transform: (B0,I29,P0) -> 16
PCI->APIC IRQ transform: (B0,I29,P1) -> 19
PCI->APIC IRQ transform: (B0,I29,P3) -> 23
PCI->APIC IRQ transform: (B0,I31,P0) -> 16
PCI->APIC IRQ transform: (B0,I31,P1) -> 17
PCI->APIC IRQ transform: (B2,I1,P0) -> 18
PCI->APIC IRQ transform: (B3,I1,P0) -> 24
PCI->APIC IRQ transform: (B3,I2,P0) -> 24
PCI->APIC IRQ transform: (B3,I2,P1) -> 25
PCI->APIC IRQ transform: (B3,I3,P0) -> 26
PCI->APIC IRQ transform: (B3,I3,P1) -> 27
PCI->APIC IRQ transform: (B4,I2,P0) -> 16
PCI->APIC IRQ transform: (B4,I3,P0) -> 17
PCI: Cannot allocate resource region 0 of device 00:00.0
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
allocated 32 pages and 32 bhs reserved for the highmem bounces
Journalled Block Device driver loaded
keyboard: controller not found
pty: 2048 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI ISAPNP enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
ttyS01 at 0x02f8 (irq = 3) is a 16550A
Real Time Clock Driver v1.10f
RAMDISK driver initialized: 16 RAM disks of 76800K size 1024 blocksize
loop: loaded (max 8 devices)
lpc: version 0.1 (Mar 4 2005)
Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
hdb: C/H/S=0/0/0 from BIOS ignored
hda: SanDisk SDCFB-512, CFA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: attached ide-disk driver.
hda: task_no_data_intr: status=0x51 { DriveReady SeekComplete Error }
hda: task_no_data_intr: error=0x04 { DriveStatusError }
hda: 1000944 sectors (512 MB) w/1KiB Cache, CHS=993/16/63
Partition check:
hda: hda1 hda2 hda3 hda4
ide: late registration of driver.
SCSI subsystem driver Revision: 1.00
i2c-core.o: i2c core module version 2.8.7 (20040611)
i2c-dev.o: i2c /dev entries driver module version 2.8.7 (20040611)
11-27-2005 05:06 AM
i2c-proc.o version 2.8.7 (20040611)
i2c-i801 version 2.8.7 (20040611)
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 16384 buckets, 128Kbytes
TCP: Hash tables configured (established 262144 bind 65536)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 26526k freed
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 136k freed
init started: BusyBox v1.00-rcEXT2-fs warning: checktime reached, running e2fsck is recommended
1 (2005.03.04-09:39+0000) multi-call binary
init started: BusyBox v1.00-rc1 (2005.03.04-09:39+0000) multi-call binary
Starting pid 10, console /dev/ttyS0: '/etc/init.d/rcS'
Recovery version 1.13
Started on Sun Nov 27 22:05:09 UTC 2005
IPS application recovery
Checking for previous config
Making filesystems on /dev/hda1
Copying grub to /dev/hda1
Installing grub to /dev/hda1
Making filesystems on /dev/hda2
Installing base image
Updating idsRoot/shared
Updating grub
Installing IPS components
Installed: /tmp/IPS-5.0-maj-S1.pkg
Finalizing system settings:
Creating boot.info[ OK ]
Checking for system modifications since last boot[WARNING]
Checking model identification[ OK ]
Model: IPS-4240
Checking kernel allocated memory: [ OK ]
Done...
The system is going down NOW !!
Sending SIGTERM to all processes.
Sending SIGKILL to all processes.
Please stand by while rebooting the system.
CISCO SYSTEMS
Low Memory: 631 KB
PCI Device Table.
Management0/0
Use ? for help.
11-28-2005 11:19 AM
You are using the wrong file (IDS-42XX-K9-r-1.1-a-4.0-1-S37.tar.pkg)
You need to use: IPS-4240-K9-sys-4.1-4-S91.img
The Recovery Image (-r- in the filename) can only be applied using the sensor's CLI "upgrade" command.
To load an image through ROMMON you need to load a System Image file (-sys- in the filename).
The file contents of a Recovery Image (-r-) and a System Image (-sys-) of the same version are almost exactly the same image. The difference is in the extra stuff wrapped around the underlying image. The Recovery Image (-r-) files are wrapped with extra information that the CLI upgrade command uses to install the underlying image.
The System Image (-sys-) files are wrapped with extra information that the ROMMMON uses to install the underlying image.
Also be aware that 4.0(1) is not supported on the 4240. The 4240 was first supported in version 4.1(4) so you need to use the IPS-4240-K9-sys-4.1-4-S91.img image.
