Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
IPS AIP-SM-10 Auto Upgrade Question
Hi all,
I'm very new into the IPS configuration.
When i enable the auto update form cisco, do i still need to configure the sensor? Are the package files (.pkg) automatically applied to the sensor and capturing/blocking mailicious traffic ?
1 REPLY
Re: IPS AIP-SM-10 Auto Upgrade Question
The auto-update only pertains to the signature updates. You still need to configure the sensor as per your security policy. Also you might need to tune/disable those newly installed signatures as per the policy.
Farrukh
171
