Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
IPS functionality addition on ASA5585-S40-K9
I sold two quantity of ASA5585-S40-K9 to a customer. They are in HA configuration and running 9.1 software image. Now customer wants to have IPS functionality on these ASA devices. I need your help on following two points:
1. Can you please share the BOM to add the IPS functionality on these existing ASA devices?
2. Can the IPS functionality thus added work on Active-Active? Kindly help me understand.
Thank you.
Ram
Everyone's tags (1)
1 ACCEPTED SOLUTION
Community Member
Hello Ram,The IPS that will
Hello Ram,
The IPS that will be available on this platform is a software based so no module is needed.
You will be needing the license to enable the IPS on the ASA itself and then one license applied on the IPS for the signatures.
Then eveything else will be working the same as any ips module.
Laura
Community Member
Hello Ram,
Laura
Community Member
Thank you Laura,  thanks
Thank you Laura,  thanks Hesam, appreciate your help.
Community Member
Hello everyone,As far as I
Hello everyone,
As far as I know the IPS funtionality in 5585-x is only supported through SSP modules and the mentioned model has this module installed in it. The license you need for the IPS funtionality for 1 year can be achieved through the following part number:
ASA5585-40-IP1Y=
You can use the following part number for signature update:
L-ASA5585-40-1SCA=
You can extend the time for IPS functionality up to 5 years and signature update up to 3 years.
Regarding A/A configuration, there is no obstacle and you can implement IPS functionality using virtual sensors.
Hesam
115
