Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
IPS Module in ASA and DNS
Ok.....once again you'll have to bare with me as i'm not too familiar with this stuff and am consulting the professionals in here
for advice.
Here is my dilemma.   I have a pair of 5520 ASA's that work in a stateful failover scenario.   Within these ASA's, there is an IPS module.
We also have a URL filter (smartfilter) to which we filter http requests.
For quite a while now, we will get random rejects on normal web requests.   The reason being that DNS doesn't resolve the name and therefore sends
the IP address to the URL filter in which we deny IP addresses.  Therefore getting the stop page from the filter.  We only allow select URL NAMES.
So your probably wondering why i would post this in the IPS forum.   Well, this doesn't occur all the time, it's random and I can't recreate it on demand
and i'm looking for possible solutions or causes.   In my little troubleshooting process I came across the firewall logs and it is showing alot of these type
of messages:
5162011/10/31 08:52:41.835 CDTx.x.x.x%ASA-4-507003: tcp flow from inside:x.x.x.x/1161 to outside:x.x.x.x/80 terminated by inspection engine, reason - inspector reset unconditionally.
5212011/10/31 08:52:44.304 CDTx.x.x.x%ASA-6-106015: Deny TCP (no connection) from x.x.x.x/1161 to x.x.x.x/80 flags FIN ACK on interface inside
Now i'm a little unsure what is going on with line 516 and whether or not this could be my cause of failed dns resolutions?    Line 521 nearly always comes
after the tcp flow message.   So could this be my issue?   And if so.....how do i go about resolving it?
Here is what I have in the config of the ASA regarding the IPS:
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum 512
  message-length maximum client auto
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
class IPS-class
  ips promiscuous fail-open
service-policy global_policy global
Again, your help is greatly appreciated.   Thanks in advance!!!
1 REPLY
Gold
The two ASA syslogs you posted were both from an internal host to port 80 on an external host. This would indicate that a sucessful DNS resolution has occured in these two instances.
If the cause of your problem is bad DNS lookups, you should see evidence in your AIP-SSM event log of the packets being dropped.
- Bob
735
