IPS problem - please help
Dear all,
We have an ASA5520 running with AIP-SSM 10 IPS module. IPS module is in inline mode. We have having some problem. Curruntly its handling 30 to 40 mbps data. the problem is that i am getting high latency from my LAN. If i bypass IPS i get 1 ms latency where as if i use IPS i get 120 ms to 160 ms. which is creating some problem running some of my application like Team 2.
Below is part of my ASA config.
class-map brac-ips-class
match any
class-map inspection_default
match default-inspection-traffic
class-map http-map1
match any
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
class brac-ips-class
ips inline fail-open
class http-map1
set connection advanced-options mss-map
What i did today, i just omit from my asa the two line which are
by giving "no class brac-ips-class" and noting else. I didn't save it even. everything was just fine. but suddenly i found my network down. When it become ok i found that ASA has reload autometically and back to its original configuratioin.
Could you please tell me why it happened.
what the other config that i have to erase for bypassing IPS.
Here also i am giving the sh ver of my IPS module for your suggestion. Plz let me know if my IPS has reached to its maximum capacity or any guideline.
bblsensor# sh ver
Application Partition:
Cisco Intrusion Prevention System, Version 5.1(5)E1
Host:
Realm Keys key1.0
Signature Definition:
Signature Update S278.0 2007-03-28
Virus Update V1.2 2005-11-24
OS Version: 2.4.26-IDS-smp-bigphys
Platform: ASA-SSM-10
Serial Number: JAF1124071C
No license present
Sensor up-time is 45 days.
Using 682496000 out of 1054670848 bytes of available memory (64% usage)
system is using 17.4M out of 29.0M bytes of available disk space (60% usage)
application-data is using 45.8M out of 166.8M bytes of available disk space (29% usage)
boot is using 35.3M out of 68.6M bytes of available disk space (54% usage)
MainApp 2007_FEB_02_15_58 (Release) 2007-02-02T16:04:00-0600 Running
AnalysisEngine 2007_FEB_02_15_58 (Release) 2007-02-02T16:04:00-0600 Running
CLI 2007_FEB_02_15_58 (Release) 2007-02-02T16:04:00-0600
Upgrade History:
IPS-K9-sp-5.1-5-E1 15:58:00 UTC Fri Feb 02 2007
Recovery Partition Version 1.1 - 5.1(5)E1
Waiting for your reply.
Regards.
Tuhin.
1 REPLY
Re: IPS problem - please help
Tuhin,
ur asa crashed ( rebooted on it;s own ).I would suggest collecting sh crash and opening a case with TAC so that a thorough analysis of crash could be done.
152
