03-20-2008 11:58 AM - edited 03-10-2019 04:02 AM
We have an auditor that wants to see all active signatures from our version 6.0(3) SSM-10s.
Is there any way to export all active signatures in report form? The auditor says he has received this from other clients.
We use CSM, ASDM, and MARS but I don't see any export options that address this.
Thanks!
Solved! Go to Solution.
03-20-2008 12:02 PM
The easiest method here is bring up IDM and go to the signatures configuration.
NOTE: You can use the viewing filters in IDM to only show signatures matching a certain criteria (like enabled).
Use your mouse to highlight/select all of the signatures.
NOTE: Do not use the Select All button.
Now use Ctrl-C to copy all of the entries.
Open Excel
Select the cell A1 and use Ctrl-V to paste the values into the spreadsheet.
03-20-2008 12:02 PM
Open Excel
03-20-2008 12:32 PM
Marc,
I had tried the Select All. Works fine your way!
Regards, Dave
03-21-2008 09:23 AM
Now, if only CSM could do that trick....
04-15-2008 09:48 AM
Can I used this method to export customer signatures from the IDS and import them into another IDS?
04-16-2008 08:14 AM
You can use CSM (free 90 day trial) to move custom sigs between sensors. Import the sensor with the custom sigs, make a policy out of the configuration and apply it to your other sensors.
04-16-2008 10:01 AM
This method works very well, we used it to migrate our sensor policies from VMS to CSM.
