Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
IPS v5 in Cisco 1841 drives cpu to 100 percent
I tried today to upgrade my 1841 Adv Security from 12.4.6T7 using sdf v4 files to the newer v5 12.4.11T3. All went well with the initial config, three basic signatures activated. I used the v296 pkg file for the latest signatures.
When I tried to copy the pkg to the idconf, the router goes to 100 percent utilization and stays there til I reboot it. None of the additional signature engines activate, no matter how long I wait for it to compile them.
Any hints on why this is happenning? This is my first go at the new v5 format files.
Thanks, Jeff
1 REPLY
Re: IPS v5 in Cisco 1841 drives cpu to 100 percent
Hi Jeff,
This is due to a bug being investigated. Please load 12.4.11T2 image, delete all the xml files
created on the flash (root or ipsconfig location
if configured), and follow the procedure outlined at http://www.cisco.com/en/US/products/ps6634/products_white_paper0900aecd805c4ea8.shtml
If your router has 256MB memory, in step 4.4, you may replace the command
"category ios_ips basic" with the command
"category ios_ips advanced".
If you change actions of signatures or unretire any other category, due to another bug, reloading will take about 8-10 minutes with high CPU but router prompt should come back after that.
Since I don't follow this forum, pls send your
subsequent messages on this issue to kemal@cisco.com and CC alyeung@cisco.com
Kemal
216
