10-21-2008 12:56 AM - edited 03-10-2019 04:20 AM
Dear all
please find the attached file.
i have ips 4240 and it is working properly.
i tuned some signatures to block the connections for any pc that has abnormal traffic or try to use P2P application but i want to know something in the attached file , what is the difference between
connection block enabled ----> true
connection block enabled ----> false
In other words , what is the meaning of ture and false in the attached file???
waiting for your replies .
regards
Mohamed
10-21-2008 05:39 AM
Hello Mohammad
There are three type of blocks on the Cisco IPS, connection block enabled referred to the blocks that match no both source/dest etc. and not just the source. From the user guide:
"There are three types of blocks:
â¢Host block-Blocks all traffic from a given IP address.
â¢Connection block-Blocks traffic from a given source IP address to a given destination IP address and destination port.
Multiple connection blocks from the same source IP address to either a different destination IP address or destination port automatically switch the block from a connection block to a host block.
Note Connection blocks are not supported on firewalls. Firewalls only support host blocks with additional connection information.
â¢Network block-Blocks all traffic from a given network.
You can initiate host and connection blocks manually or automatically when a signature is triggered. You can only initiate network blocks manually.
Caution Do not confuse blocking with the sensor's ability to drop packets. The sensor can drop packets when the following actions are configured for a sensor in inline mode: deny packet inline, deny connection inline, and deny attacker inline. "
Please rate if helpful.
Farrukh
10-21-2008 09:31 AM
Dear Farrukh
Thanks for your reply and your support. What i need to know what is the meaning of True and False in the Connection Block Enabled column in the attached file????
regards
mohamed
10-21-2008 11:34 PM
Dear Mohammad
When that field is set to true, then it means a "Connection block" is being done instead of a "Host block" (based on source IP only). When it is false it implies a "Host Block".
Farrukh
