IPS4260 - PXE-E61: Media test failure, check cable
daniellandry
Can't boot the appliance (IPS-4260-4GE) at the first
startup sequence !
Message :
Cisco Systems
BIOS Date: 03/14/06 08:31:22 Ver: 08.00.10
SE7520JR23 Production BIOS Version 10.00, Build 0087
CPU : Intel(R) Xeon(TM) CPU 3.60GHz with EM64T
Speed : 3.6 GHz Count : 2
800MHz Front Side Bus
DDRII-400, Standard, Dual Channel mode
Checking NVRAM..Update OK!
Initializing USB Controllers .. Done.
Testing system memory, memory size=4096MB
4096MB Extended Memory Passed
Auto-Detecting Pri Master..IDE Hard Disk
Evaluating run options...4
Intel(R) Boot Agent GE v1.2.26
Copyright (C) 1997-2004, Intel Corporation
PXE-M0F: Exiting Intel Boot Agent.
Reboot and Select proper Boot device
or Insert Boot Media in selected Boot device and press a key
mhellman
Level 7
Level 7
That is a generic error that indicates that the device is trying to boot from the network and failing. you might try to 'break' in during bootup and use tftp to get the latest image.
