Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
License part number
Dear all
I have an ASA5510 installed AIP-SSM  module and need a part number for signature update license for that IPS, Which license  i should
purchase, If u can send me the part number, i would be thankful  to you.
Thank you
1 REPLY
Re: License part number
You should be able to gather the product ID for the AIP-SSM from the output of the 'show version' command.  Note the called out entry below:
sensor# sh ver
Application Partition:
Cisco Intrusion Prevention System, Version 7.0(2)E4
Host:
    Realm Keys          key1.0
Signature Definition:
    Signature Update    S490.0                   2010-05-12
OS Version:             2.4.30-IDS-smp-bigphys
Platform:               IPS-4240-K9
Serial Number:
Your Cisco account team or partner should be able to provide the correct contract type to provide signature update support.
Scott
365
