Lincense 4240
HI ALL,
PL find sh version out put and give me answer for following Q.
1.is it possible to confirm whether first time license is installed or not?
2.At present Will it work or not
3.IOS upgration is possible from this condtion(5.1 to 6.0 or 6.1)
sh ver[2C
Application Partition:
Cisco Intrusion Prevention System, Version 5.1(6)E1
Host:
Realm Keys key1.0
Signature Definition:
Signature Update S291.0 2007-06-18
Virus Update V1.2 2005-11-24
OS Version: 2.4.26-IDS-smp-bigphys
Platform: IPS-4240-K9
Serial Number: JMX1044K0Q4
No license present
Sensor up-time is 2 days.
Using 751603712 out of 1454153728 bytes of available memory (51% usage)
system is using 17.4M out of 29.0M bytes of available disk space (60% usage)
application-data is using 46.1M out of 166.8M bytes of available disk space (29% usage)
boot is using 35.3M out of 68.6M bytes of available disk space (54% usage)
MainApp Z-2007_JUN_19_12_49 (Release) 2007-06-19T13:04:08-0500 Running
AnalysisEngine Z-2007_JUN_19_12_49 (Release) 2007-06-19T13:04:08-0500 Running
CLI Z-2007_JUN_19_12_49 (Release) 2007-06-19T13:04:08-0500
Upgrade History:
IPS-K9-5.1-6-E1 05:04:37 UTC Sat Nov 15 2008
Recovery Partition Version 1.1 - 5.1(6)E1
We have below mentioned details of IPS 4240.
1.imps-4240.k9 --IPS4240 Application server
2.cwvns-2.3-winb-k9-vms 5 device basic license
3.IPS-5w.5.0 -IPS 5.0 software for IDS 4215,IPS 4240 AND 4255 IPS SENSOR
This is ok for the IPS installation.kindly confirm the license
Gold
Re: Lincense 4240
this line tells you that your sensor is not licensed:
No license present
your sensor will still run and perform all the normal IPS functions.
You have some older signatures S291 on it. If you upgrade the software to 5.1(8)E3 or 6.0(5)E3 or 6.1(1)E3 or 6.2(1)E3 you can upgrade the signatures to S366 without needing a license. The signatures are contained in the software updates. The software updates may be applied without a license. Only signature updates require a license.
Re: Lincense 4240
HI rhermes /All
After upgration IPS-4240-K9-sys-1.1-a-5.0-2.img to IPS-4240-K9-sys-1.1-a-6.1-1-E3.img i am getting below message
There is no license key installed on the IPS-4240.
The system will continue to operate with the currently installed
signature set. A valid license must be obtained in order to apply
signature updates. Please go to http://www.cisco.com/go/license
to obtain a new license or install a license.
Its not going to promt mode ?
How can i go to ips configuration mode?
Any steps which are to be done first?
KInldy reply back
115
