Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
login failure to aip ssm-20
I have two firewalls namely cisco asa 5520 with AIP ssm-20 IPS modules built into them.  I am trying to use the IPS modules built into them
Neither of them will let me login to the IPS:
session 1 prompts me to login so i login with default cisco / cisco but its not working
i am getting the same error on both devices but the two firewalls have been up and running for quite a while and are causing no problems
any ideas where i am going wrong on this one?
All the user guides are also saying cisco / cisco
regards,
Kevin
Gold
Kevin -
You are correct, the default usernaem/password is cisco/cisco. Check the status of your AIP-SSM:
asa# show module 1 details
ASA 5500 Series Security Services Module-10
Model:              ASA-SSM-10
Hardware version:   1.0
Serial Number:      JAB09370212
Firmware version:   1.0(10)0
Software version:   6.0(4)E1
MAC Address Range:  0012.d948.fe73 to 0012.d948.fe73
App. name:          IPS
App. Status:        Up
App. Status Desc:
App. version:       6.0(4)E1
Data plane Status:  Up
Status:             Up
Mgmt IP addr: 171.69.36.171
Mgmt web ports:     443
Mgmt TLS enabled:   true
asa#
If that looks good, it's time for a password recovery or a reimage:
http://www.cisco.com/en/US/docs/security/ips/6.0/configuration/guide/cli/cliSSM.html#wp1034193
- Bob
Bob,
Is this software version ok?
fwWestlTelem01# show module 1 details
Getting details from the Service Module, please wait...
ASA 5500 Series Security Services Module-20
Model:              ASA-SSM-20
Serial Number:      JAF1251BRDR
Firmware version:   1.0(11)2
Software version:   6.1(3)E3
MAC Address Range:  c84c.7576.c27b to c84c.7576.c27b
App. name:          IPS
App. Status:        Up
App. Status Desc:
App. version:       6.1(3)E3
Status:             Up
Mgmt IP addr:       10.10.10.11
Mgmt web ports:     443
Kevin
Gold
Kevin -
Yeah, the software version is good enough to let you log in (although you'll want to update the version to one of the E4 releases to apply the latest signature pack once you get access).
Your sensor looks like it's running. I would try a password recovery.
- Bob
683
