08-25-2007 12:19 AM - edited 03-10-2019 03:45 AM
The management interface of IPS 4240 is disabled by default can anyone tell me how to enable this interface.
I hv just done the basic setup and not able to access the IPS through Web browser
08-26-2007 07:40 AM
management interfaces are disabled by default and they always are
on the cisco ips run
setup and once you setup an Ip for the ips you will be able to connect to the web interface
here is a example of how a command-control should look like
ex:
media-type: tx
description:
admin-state: disabled
duplex: full default: auto
speed: auto
alt-tcp-reset-interface
none
subinterface-type
none
command-control: FastEthernet0/1
bypass-mode: auto
interface-notifications
missed-percentage-threshold: 0 percent
notification-interval: 30 seconds
idle-interface-delay: 30 seconds
as you see they are "protected" so you cannot change the state from disable to enable
08-26-2007 09:30 PM
Thnx for the solution but i already tryed this its not happening, is there anything like need to open the web server port or allowed ip address to access the web innterface.
08-27-2007 09:48 AM
You are using HTTPS right, and not just HTTP?
