Migration CSA agents 4.5 to 6.0
teperjesi
Hi all,
I'm planning to migrate a CSAMC from 4.5 to 6.0 on the same machine. I understand that I need to upgrade firs to 5.0, than back-up the config, database etc and reinstall the whole system for 6.0. I'm not sure if I need to migrate my agents first into 5.0 then into 6.0, or I can migrate clients from 4.5 immediatelly into 6.0.
Many thanks!
Tamas
tsteger1
Level 8
Level 8
I believe the migration can be from 4.5 to 6.0 though I haven't performed this.
They will still have the 4.5 agent and report to the 6.0 MC and the 6.0 agent kit should be an available update.
Tom
Unfortunately the answer is no. I need to pool every agents into every new versions.:(
Bummer. The documentation wasn't terribly clear on the sequence.
Tom
