Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
One interface of pair goes down
If two interfaces are paired into one group and one interface of pair goes down, will the second interface will be declared as down by IPS?
Bronze
Which is the software version that you are using ?
Sawan Gupta
Thanks & Regards, Sawan Gupta
Community Member
I I have a problem connected to this issue.
I have only one IPS4270-20 with software 7.0(7)E4 and I use 2 IF pairs on it. Both IF pairs are for the same operation, and they were implemented for HA purposes. We have two 6500 chassis in VSS and all of the IPS ports connected to these switches. Gi3/0-Gi3/1 and Gi1/2-Gi3/3 are in pair, and Gi3/0-Gi3/2 are the inbound and Gi3/1-Gi3/3 are the outbound interfaces, so it achieves the hardwer failover requirements. Inbound IFs creat an Etherchannel, and outbound IFs creat an other Etherchannel, so we try to prevent an L2 loop when VSS breaks.
The issue what I can't solve is the following:
If I shut down the 6500 IF what is connected to the IPS Gi3/0 I would like Gi3/1 to goes down, but it isn't the case.
I tried to use LACP in the Etherchannel, so when Gi3/0 goes down, the 6500 port which connected to the IPS Gi3/1 should be removed from the Etherchannel, but it isn't the case also.
Do you have an idea, what could be the problem, or I should redesign the topology?
Miki
Bronze
Please file an enhancement request if there is not one already. For the pair if one link goes down, the other one link should go down automatically.
Sawan Gupta
535
