Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Packet Display on IPS
First post ever, maybe my quetsion is so obvious ... but I'm really stuck :
The question is about the diversion off traffic in the ASA towards the IPS
On the IPS I can issue a "packet display gig0/0" nice to see packets floating around :-)
But when I do this om the backplane interface i see nothing happening.
Maybe this is simple : you cann't issue the command on the backplane, but what about this traffic diverting thing ?
Here you can see my settings (nearly exact thos from the manuals)
ciscoasa# sh running-config access-list
access-list alles extended permit icmp any any log critical
access-list alles extended permit ip any any log critical
ciscoasa# sh running-config access-group
access-group alles in interface mgmt
access-group alles out interface mgmt
access-group alles in interface e0/0
access-group alles out interface e0/0
ciscoasa# sh running-config class-map
class-map ip_class_map
match access-list alles
ciscoasa# sh running-config policy-map
policy-map ips_policy_map
class ip_class_map
ips promiscuous fail-open
ciscoasa# sh running-config service-policy
service-policy ips_policy_map global
Cisco Adaptive Security Appliance Software Version 7.1(1) (5510)
Cisco Intrusion Prevention System, Version 5.1(1)S205.0
asa-sensor# packet display gigabitEthernet0/1
Warning: This command will cause significant performance degradation
tcpdump: WARNING: ge0_1: no IPv4 address assigned
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on ge0_1, link-type EN10MB (Ethernet), capture size 65535 bytes
0 packets captured
0 packets received by filter
0 packets dropped by kernel
the biggest problem maybe :
ciscoasa# sh access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096)
alert-interval 300
access-list alles; 2 elements
access-list alles line 1 extended permit icmp any any log critical interval 300 (hitcnt=0) 0x1209f4e5
access-list alles line 2 extended permit ip any any log critical interval 300 (hitcnt=0) 0xa247179c
I just can't see any hits on the implied acl's
Any idea's ?
Tia
221
