09-12-2006 06:13 AM - edited 03-10-2019 03:12 AM
All, I have upgraded my first sensor 4.x to 5.0 to 5.1. Here is my process
1) Upgraded from 4.x to 5.0 using FTP with this file IPS-K9-maj-5.0-1c-S149.rpm.pkg
2) Installed License Key
3) Using VMS, I went from 5.0 to 5.1 using file IPS-K9-min-5.1-1.zip
4) Now, my switchport is down, down monitoring.
Am I missing a patch?
Did I upgrade properly?
Why is it down down monitoring and not up down monitoring on the switchport that my sensing port connects to in the switch.
Solved! Go to Solution.
09-12-2006 01:57 PM
You may be hitting a common issue with 5.1.1 where the senorApp process becomes unresponsive. You should not stay at 5.1.1 - you need to upgrade to 5.1.3. If you are seeing this issue then:
1) disable the sniffing interfaces
2) reboot the sensor
3) upgrade to 5.1.3
4) enable the sniffing interfaces
09-12-2006 06:18 AM
This is a 4215 sensor.
09-12-2006 01:57 PM
3) upgrade to 5.1.3
09-13-2006 05:10 AM
I disabled the physical interface and started the frp process. thanks for the info I will post the results.
09-13-2006 06:55 AM
I had to reboot the sensor. Then, I was able to upgrade it to sp 5.1-3. The port is now up down monitoring and https access is much better through the IDM. Thank you for your help.
