Reconfiguring the engine | CPU @ 100% | AIP-5
Mark^
It seems that almost everytime I log into the IPS Manager for the ASA-SSC-AIP-5 that it is reconfiguring the engine and the CPU is at 100%.  I am on sig version 625.0 and I knwo the current should be like S632.  Basically, this thing always seems to be in bypass mode so what is the point?  It's frustrating.
Has anyone else experienced this?  Is there somethign that should be done for performance, or do I need to look at my configurationg for something?
Maybe I am just checking for updates too often?
I'm looking for any suggestions or best practices for using these.
Thanks.
Mark
8 Replies 8
sawgupta
Any particular process that is eating up CPU ?
Please take a show tech output, it will have top command output and error logs (if any).
Sawan Gupta
Thanks & Regards, Sawan Gupta
Quite long, but here goes:
IPS_Sensor# show tech
System Status Report
This Report was generated on Thu Mar 15 09:54:38 2012.
Output from show version
Application Partition:
Cisco Intrusion Prevention System, Version 6.2(4)E4
Host:
    Realm Keys          key1.0
Signature Definition:
    Signature Update    S632.0                   2012-03-13
OS Version:             2.4.30-IDS-smp-bigphys
Platform:               ASA-SSC-AIP-5
Serial Number:          JAF1442BDBN
Licensed, expires:      07-Jan-2013 UTC
Sensor up-time is 36 days.
Using 350920704 out of 489398272 bytes of available memory (71% usage)
application-data is using 42.4M out of 166.8M bytes of available disk space (27% usage)
boot is using 40.8M out of 68.6M bytes of available disk space (63% usage)
MainApp          E-ECLIPSE_624_2011_JUN_23_00_20_6_2_3_17   (Ipsbuild)   2011-06-23T00:24:58-0500   Running
AnalysisEngine   E-ECLIPSE_624_2011_JUN_23_00_20_6_2_3_17   (Ipsbuild)   2011-06-23T00:24:58-0500   Running
CLI              E-ECLIPSE_624_2011_JUN_23_00_20_6_2_3_17   (Ipsbuild)   2011-06-23T00:24:58-0500
Upgrade History:
* IPS-sig-S631-req-E4       18:03:37 UTC Tue Mar 13 2012
  IPS-sig-S632-req-E4.pkg   18:03:38 UTC Wed Mar 14 2012
Recovery Partition Version 1.1 - 6.2(4)E4
Host Certificate Valid from: 14-Jan-2011 to 14-Jan-2013
Output from show interfaces
Interface Statistics
   Total Packets Received = 0
   Total Bytes Received = 0
   Missed Packet Percentage = 0
   Current Bypass Mode = Auto_off
MAC statistics from interface GigabitEthernet0/0
   Interface function = Sensing interface
   Description =
   Media Type = backplane
   Default Vlan = 0
   Inline Mode = Unpaired
   Pair Status = N/A
   Hardware Bypass Capable = No
   Hardware Bypass Paired = N/A
   Link Status = Up
   Admin Enabled Status = Enabled
   Link Speed = Auto_1000
   Link Duplex = Auto_Full
   Total Packets Received = 163575210
   Total Bytes Received = 100243725586
   Total Multicast Packets Received = 0
   Total Broadcast Packets Received = 0
   Total Jumbo Packets Received = 0
   Total Undersize Packets Received = 0
   Total Receive Errors = 0
   Total Receive FIFO Overruns = 0
   Total Packets Transmitted = 163575006
   Total Bytes Transmitted = 100243542691
   Total Multicast Packets Transmitted = 0
   Total Broadcast Packets Transmitted = 0
   Total Jumbo Packets Transmitted = 0
   Total Undersize Packets Transmitted = 0
   Total Transmit Errors = 0
   Total Transmit FIFO Overruns = 0
MAC statistics from interface Management0/0
   Interface function = Command-control interface
   Description =
   Media Type = TX
   Default Vlan = 0
   Link Status = Up
   Total Packets Received = 8837748
   Total Bytes Received = 1105352880
   Total Packets Transmitted = 9435508
   Total Bytes Transmitted = 1410112517
Output from show statistics authentication
General
   totalAuthenticationAttempts = 29
   failedAuthenticationAttempts = 2
Output from show statistics analysis-engine
Analysis Engine Statistics
   Number of seconds since service started = 3195884
   The rate of TCP connections tracked per second = 0
   The rate of packets per second = 46
   The rate of bytes per second = 1071
   Receiver Statistics
      Total number of packets processed since reset = 150102196
      Total number of IP packets processed since reset = 150102196
   Transmitter Statistics
      Total number of packets transmitted = 151226612
      Total number of packets denied = 70
      Total number of packets reset = 80
   Fragment Reassembly Unit Statistics
      Number of fragments currently in FRU = 0
      Number of datagrams currently in FRU = 0
   TCP Stream Reassembly Unit Statistics
      TCP streams currently in the embryonic state = 0
      TCP streams currently in the established state = 0
      TCP streams currently in the closing state = 0
      TCP streams currently in the system = 0
      TCP Packets currently queued for reassembly = 0
   The Signature Database Statistics.
      Total nodes active = 1634
      TCP nodes keyed on both IP addresses and both ports = 357
      UDP nodes keyed on both IP addresses and both ports = 0
      IP nodes keyed on both IP addresses = 134
   Statistics for Signature Events
      Number of SigEvents since reset = 473321
   Statistics for Actions executed on a SigEvent
      Number of Alerts written to the IdsEventStore = 673
   Inspection Stats
         Inspector            active   call        create    delete    createPct   callPct
         AtomicAdvanced       1        150092178   1         0         0           14
         Fixed                40       8387783     5498552   5498512   3           5
         MSRPC_TCP            15       5787118     1093973   1093958   0           3
         MSRPC_UDP            0        2156196     1071260   1071260   0           1
         MultiString          410      24911947    3282530   3282120   2           16
         MultiStringSP        0        2031        822       822       0           0
         ServiceDnsUdp        1        2156196     1         0         0           1
         ServiceDnsTcp        0        290         146       146       0           0
         ServiceFtp           0        1513        88        88        0           0
         ServiceGeneric       3        152319935   2228468   2228465   1           15
         ServiceHttp          254      2488814     1199894   1199640   0           1
         ServiceMsSql         0        7497        4         4         0           0
         ServiceNtp           0        4312392     2142520   2142520   1           2
         ServiceP2PUDP        0        86926       80336     80336     0           0
         ServiceP2PTCP        2        4897360     2228465   2228463   1           3
         ServiceRpcUDP        1        2156196     1         0         0           1
         ServiceRpcTCP        356      18860022    2224579   2224223   1           12
         ServiceSMBAdvanced   2        2189269     10389     10387     0           1
         ServiceSnmp          1        2156196     1         0         0           1
         ServiceTNS           0        2211389     2203383   2203383   1           1
         String               502      37492887    4282235   4281733   2           24
         SweepICMP            11       1113830     75054     75043     0           0
         SweepTCP             270      293642888   874680    874410    0           23
         SweepOtherTcp        134      146821444   449914    449780    0           11
Output from show statistics denied-attackers
Statistics for Virtual Sensor vs0
   Denied Attackers and hit count for each.
   Denied Attackers with percent denied and hit count for each.
Output from show statistics event-server
Statistics not available: event-server is disabled.
Output from show statistics event-store
Event store statistics
   General information about the event store
      The current number of open subscriptions = 5
      The number of events lost by subscriptions and queries = 0
      The number of filtered events not written to the event store = 323047
      The number of queries issued = 1
      The number of times the event store circular buffer has wrapped = 0
   Number of events of each type currently stored
      Status events = 15070
      Shun request events = 0
      Error events, warning = 72
      Error events, error = 571
      Error events, fatal = 2
      Alert events, informational = 346
      Alert events, low = 462
      Alert events, medium = 7
      Alert events, high = 21
      Alert events, threat rating 0-20 = 0
      Alert events, threat rating 21-40 = 346
      Alert events, threat rating 41-60 = 479
      Alert events, threat rating 61-80 = 7
      Alert events, threat rating 81-100 = 4
   Cumulative number of each type of event
      Status events = 11532
      Error events, warning = 63
      Error events, error = 437
      Error events, fatal = 1
      Alert events, informational = 287
      Alert events, low = 360
      Alert events, medium = 5
      Alert events, threat rating 21-40 = 287
      Alert events, threat rating 41-60 = 377
      Alert events, threat rating 61-80 = 5
Output from show statistics external-product-interface
No interfaces configured
Output from show statistics host
General Statistics
   Last Change To Host Config (UTC) = 07-Feb-2012 15:03:14
   Command Control Port Device = Management0/0
Network Statistics
    = ma0_0     Link encap:Ethernet  HWaddr 00:4D:79:4D:41:43
    =           inet addr:10.1.2.2  Bcast:10.1.2.7  Mask:255.255.255.248
    =           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
    =           RX packets:8837838 errors:0 dropped:0 overruns:0 frame:0
    =           TX packets:9435686 errors:0 dropped:0 overruns:0 carrier:0
    =           collisions:0 txqueuelen:1000
    =           RX bytes:1105359006 (1.0 GiB)  TX bytes:1410145705 (1.3 GiB)
NTP Statistics
    =      remote           refid      st t when poll reach   delay   offset  jitter
    = *10.x.x.5        130.126.24.53    3 u  299 1024  377    3.915   11.079  18.216
    =  LOCAL(0)        73.78.73.84      5 l    3   64  377    0.000    0.000   0.002
    = ind assID status  conf reach auth condition  last_event cnt
    =   1 28364  b6e4   yes   yes  none  sys.peer   reachable 14
    =   2 28365  90e4   yes   yes  none    reject   reachable 14
   status = Synchronized
Memory Usage
   usedBytes = 350998528
   freeBytes = 138399744
   totalBytes = 489398272
Summertime Statistics
   start = 03:00:00 UTC Sun Mar 11 2012
   end = 01:00:00 GMT-06:00 Sun Nov 04 2012
CPU Statistics
   Usage over last 5 seconds = 27
   Usage over last minute = 21
   Usage over last 5 minutes = 27
Memory Statistics
   Memory usage (bytes) = 350998528
   Memory free (bytes) = 138399744
Auto Update Statistics
   lastDirectoryReadAttempt = 09:03:29 UTC Thu Mar 15 2012
    =   Read directory: https://198.133.219.25//cgi-bin/front.x/ida/locator/locator.pl
    =   Success: No installable auto update package found on server
   lastDownloadAttempt = 13:03:27 UTC Wed Mar 14 2012
   lastInstallAttempt = 13:13:49 UTC Wed Mar 14 2012
   nextAttempt = 11:03:17 UTC Thu Mar 15 2012
Auxilliary Processors Installed
Output from show statistics logger
The number of Log interprocessor FIFO overruns = 0
The number of syslog messages received = 95
The number of events written to the event store by severity
   Fatal Severity = 1
   Error Severity = 437
   Warning Severity = 158
   TOTAL = 596
The number of log messages written to the message log by severity
   Fatal Severity = 1
   Warning Severity = 63
   Timing Severity = 0
   Debug Severity = 0
   Unknown Severity = 0
   Blank Messages = 64132
   TOTAL = 64633
Output from show statistics network-access
Current Configuration
   LogAllBlockEventsAndSensors = true
   EnableNvramWrite = false
   EnableAclLogging = false
   AllowSensorBlock = false
   BlockMaxEntries = 250
   MaxDeviceInterfaces = 250
   NeverBlock
      IP = 10.x.x.8
      IP = 10.x.x.69
State
   BlockEnable = true
Output from show statistics notification
General
   Number of SNMP set requests = 0
   Number of SNMP get requests = 0
   Number of error traps sent = 497
   Number of alert traps sent = 19
Output from show statistics os-identification
   OS Identification
      Configured
      Imported
      Learned
         IP = 10.x.x.69 (windows-nt-2k-xp)
         IP = 10.x.x.117 (windows-nt-2k-xp)
         IP = 10.x.x.229 (windows-nt-2k-xp)
         IP = 10.x.x.230 (windows-nt-2k-xp)
         IP = 10.x.x.231 (windows-nt-2k-xp)
         IP = 10.x.x.232 (windows-nt-2k-xp)
         IP = 10.x.x.233 (windows-nt-2k-xp)
         IP = 10.x.x.234 (windows-nt-2k-xp)
         IP = 10.x.x.235 (windows-nt-2k-xp)
         IP = 10.x.x.236 (windows-nt-2k-xp)
         IP = 10.x.x.238 (windows-nt-2k-xp)
         IP = 10.x.x.240 (windows-nt-2k-xp)
         IP = 12.120.129.206 (linux)
         IP = 50.22.26.153 (linux)
         IP = 50.22.26.155 (linux)
         IP = 50.23.216.69 (linux)
         IP = 50.57.22.5 (linux)
         IP = 64.70.9.195 (linux)
         IP = 64.208.138.145 (linux)
         IP = 65.42.26.130 (bsd)
         IP = 66.117.14.61 (linux)
         IP = 66.147.244.114 (linux)
         IP = 67.192.92.227 (linux)
         IP = 68.142.213.143 (linux)
         IP = 69.12.162.28 (linux)
         IP = 69.64.250.20 (linux)
         IP = 69.172.216.56 (linux)
         IP = 70.98.35.165 (linux)
         IP = 71.13.87.218 (linux)
         IP = 72.22.182.37 (windows-nt-2k-xp)
         IP = 72.34.62.119 (linux)
         IP = 72.44.91.208 (linux)
         IP = 72.251.194.171 (linux)
         IP = 74.125.214.21 (linux)
         IP = 74.125.214.114 (linux)
         IP = 74.201.0.130 (linux)
         IP = 75.126.109.204 (linux)
         IP = 98.129.229.53 (linux)
         IP = 98.138.47.199 (linux)
         IP = 98.139.225.43 (linux)
         IP = 107.20.134.231 (linux)
         IP = 107.21.238.22 (linux)
         IP = 107.22.217.227 (linux)
         IP = 107.22.230.44 (linux)
         IP = 129.143.116.113 (linux)
         IP = 132.237.253.49 (linux)
         IP = 143.227.55.17 (linux)
         IP = 162.128.70.19 (linux)
         IP = 170.218.216.73 (linux)
         IP = 173.45.246.12 (linux)
         IP = 173.201.185.43 (linux)
         IP = 174.46.100.100 (hp-ux)
         IP = 174.129.1.166 (linux)
         IP = 184.72.226.104 (linux)
         IP = 192.168.168.135 (windows-nt-2k-xp)
         IP = 195.24.232.205 (linux)
         IP = 199.59.149.198 (linux)
         IP = 204.11.208.168 (linux)
         IP = 204.145.83.230 (linux)
         IP = 204.145.176.90 (linux)
         IP = 205.251.253.141 (linux)
         IP = 208.28.202.43 (linux)
         IP = 208.65.147.170 (linux)
         IP = 209.59.132.242 (linux)
         IP = 209.85.239.19 (linux)
         IP = 209.126.151.246 (linux)
         IP = 209.126.179.3 (linux)
         IP = 216.8.161.98 (bsd)
         IP = 216.75.16.204 (linux)
         IP = 216.129.117.152 (linux)
         IP = 216.138.155.154 (linux)
         IP = 216.231.189.130 (linux)
Output from show statistics sdee-server
General
   Open Subscriptions = 1
   Blocked Subscriptions = 1
   Maximum Available Subscriptions = 5
   Maximum Events Per Retrieval = 500
Subscriptions
   sub-9-19a8e927
      State = Read Pending
      Last Read Time = 14:54:38 UTC Thu Mar 15 2012
      Last Read Time (nanoseconds) = 1331823278914523000
Output from show statistics virtual-sensor
Virtual Sensor Statistics
      Name of current Signature-Defintion instance = sig0
      Name of current Event-Action-Rules instance = rules0
      List of interfaces monitored by this virtual sensor = GigabitEthernet0/0 subinterface 0
      General Statistics for this Virtual Sensor
         Number of seconds since a reset of the statistics = 3195885
         MemoryAlloPercent = 72
         MemoryUsedPercent = 67
         MemoryMaxCapacity = 300000
         MemoryMaxHighUsed = 319840
         MemoryCurrentAllo = 218439
         MemoryCurrentUsed = 203388
         Processing Load Percentage = 5
         Total packets processed since reset = 151232133
         Total IP packets processed since reset = 151232133
         Total IPv4 packets processed since reset = 151232133
         Total IPv6 packets processed since reset = 0
         Total IPv6 AH packets processed since reset = 0
         Total IPv6 ESP packets processed since reset = 0
         Total IPv6 Fragment packets processed since reset = 0
         Total IPv6 Routing Header packets processed since reset = 0
         Total IPv6 ICMP packets processed since reset = 0
         Total packets that were not IP processed since reset = 0
         Total TCP packets processed since reset = 147952089
         Total UDP packets processed since reset = 2156214
         Total ICMP packets processed since reset = 1123830
         Total packets that were not TCP, UDP, or ICMP processed since reset = 0
         Total ARP packets processed since reset = 0
         Total ISL encapsulated packets processed since reset = 0
         Total 802.1q encapsulated packets processed since reset = 5009
         Total GRE Packets processed since reset = 0
         Total GRE Fragment Packets processed since reset = 0
         Total GRE Packets skipped since reset = 0
         Total packets with bad IP checksums processed since reset = 0
         Total packets with bad layer 4 checksums processed since reset = 0
         Total number of bytes processed since reset = 90811729021
         The rate of packets per second since reset = 47
         The rate of bytes per second since reset = 28415
         The average bytes per packet since reset = 600
      Denied Address Information
         Number of Active Denied Attackers = 0
         Number of Denied Attackers Inserted = 0
         Number of Denied Attacker Victim Pairs Inserted = 0
         Number of Denied Attacker Service Pairs Inserted = 0
         Number of Denied Attackers Total Hits = 0
         Number of times max-denied-attackers limited creation of new entry = 0
         Number of exec Clear commands during uptime = 0
         The Number of each type of node active in the system
         The number of each type of node inserted since reset
            Total nodes inserted = 10505094
            TCP nodes keyed on both IP addresses and both ports = 2317586
            UDP nodes keyed on both IP addresses and both ports = 988001
            IP nodes keyed on both IP addresses = 685950
         The rate of nodes per second for each time since reset
            Nodes per second = 3
            TCP nodes keyed on both IP addresses and both ports per second = 0
            UDP nodes keyed on both IP addresses and both ports per second = 0
            IP nodes keyed on both IP addresses per second = 0
         The number of root nodes forced to expire because of memory constraints
            TCP nodes keyed on both IP addresses and both ports = 26357
         Packets dropped because they would exceed Database insertion rate limits = 0
      Fragment Reassembly Unit Statistics for this Virtual Sensor
         Number of fragments received since reset = 10018
         Number of fragments forwarded since reset = 10018
         Number of fragments dropped since last reset = 0
         Number of fragments modified since last reset = 0
         Number of complete datagrams reassembled since last reset = 5009
         Fragments hitting too many fragments condition since last reset = 0
         Number of overlapping fragments since last reset = 0
         Number of Datagrams too big since last reset = 0
         Number of overwriting fragments since last reset = 0
         Number of Inital fragment missing since last reset = 0
         Fragments hitting the max partial dgrams limit since last reset = 0
         Fragments too small since last reset = 0
         Too many fragments per dgram limit since last reset = 0
         Number of datagram reassembly timeout since last reset = 0
         Too many fragments claiming to be the last since last reset = 0
         Fragments with bad fragment flags since last reset = 0
      TCP Normalizer stage statistics
         Packets Input = 146821876
         Packets Modified = 0
         Dropped packets from queue = 0
         Dropped packets due to deny-connection = 0
         Duplicate Packets = 0
         Current Streams = 357
         Current Streams Closed = 0
         Current Streams Closing = 0
         Current Streams Embryonic = 0
         Current Streams Established = 0
         Current Streams Denied = 0
         Total SendAck Limited Packets = 0
         Total SendAck Limited Streams = 0
         Total SendAck Packets Sent = 0
      Statistics for the TCP Stream Reassembly Unit
         Current Statistics for the TCP Stream Reassembly Unit
         Cumulative Statistics for the TCP Stream Reassembly Unit since reset
            TCP streams that have been tracked since last reset = 0
            TCP streams that had a gap in the sequence jumped = 0
            TCP streams that was abandoned due to a gap in the sequence = 0
            TCP packets that arrived out of sequence order for their stream = 0
            TCP packets that arrived out of state order for their stream = 0
            The rate of TCP connections tracked per second since reset = 0
      SigEvent Preliminary Stage Statistics
         Number of Alerts received = 473321
         Number of Alerts Consumed by AlertInterval = 55
         Number of Alerts Consumed by Event Count = 30
         Number of FireOnce First Alerts = 158
         Number of FireOnce Intermediate Alerts = 255
         Number of Summary First Alerts  = 78928
         Number of Summary Intermediate Alerts  = 372829
         Number of Regular Summary Final Alerts  = 20879
         Number of Global Summary Final Alerts  = 0
         Number of Active SigEventDataNodes  = 6
         Number of Alerts Output for further processing = 473236
         Per-Signature SigEvent count since reset
            Sig 3002.0 = 187
            Sig 3653.0 = 28
            Sig 5474.0 = 183
            Sig 5575.0 = 423
            Sig 5581.0 = 408
            Sig 5591.0 = 6
            Sig 5595.0 = 15
            Sig 5606.0 = 21
            Sig 5903.2 = 505
            Sig 6061.0 = 5
            Sig 6131.6 = 13
            Sig 6187.0 = 6
            Sig 6403.1 = 26
            Sig 6409.1 = 22
            Sig 6409.2 = 370
            Sig 6984.2 = 92
            Sig 7241.1 = 3
            Sig 7264.1 = 13
            Sig 11233.3 = 1
            Sig 16297.0 = 21
            Sig 19219.1 = 6
            Sig 20059.1 = 7950
            Sig 21539.1 = 7
            Sig 21619.1 = 257
            Sig 23782.2 = 461703
            Sig 25022.1 = 26
            Sig 27839.2 = 928
            Sig 30260.1 = 9
            Sig 30459.1 = 9
            Sig 41846.1 = 78
      SigEvent Action Override Stage Statistics
         Number of Alerts received to Action Override Processor = 473236
         Number of Alerts where an override was applied = 98
         Actions Added
            deny-attacker-inline = 0
            deny-attacker-victim-pair-inline = 0
            deny-attacker-service-pair-inline = 0
            deny-connection-inline = 0
            deny-packet-inline = 93
            modify-packet-inline = 0
            log-attacker-packets = 5
            log-pair-packets = 5
            log-victim-packets = 5
            produce-alert = 0
            produce-verbose-alert = 5
            request-block-connection = 0
            request-block-host = 0
            request-snmp-trap = 0
            reset-tcp-connection = 0
            request-rate-limit = 0
            stop-flow-inspection = 0
      SigEvent Action Filter Stage Statistics
         Number of Alerts received to Action Filter Processor = 0
         Number of Alerts where an action was filtered = 15
         Number of Filter Line matches = 15
         Number of Filter Line matches causing decreased DenyPercentage = 0
         Actions Filtered
            deny-packet-inline = 0
            log-attacker-packets = 0
            log-pair-packets = 0
            log-victim-packets = 0
            produce-alert = 15
            produce-verbose-alert = 0
         Filter Hit Counts
            3  = 15
      SigEvent Action Handling Stage Statistics.
         Number of Alerts received to Action Handling Processor = 1310
         Number of Alerts where produceAlert was forced = 0
         Number of Alerts where produceAlert was off = 15
         Number of Alerts using Auto One Way Reset = 89
         Actions Performed
            deny-connection-inline = 89
            deny-packet-inline = 89
            produce-alert = 673
         Deny Actions Requested in Promiscuous Mode
            deny-packet not performed = 0
            deny-connection not performed = 0
            deny-attacker not performed = 0
            deny-attacker-victim-pair not performed = 0
            deny-attacker-service-pair not performed = 0
            modify-packet not performed = 0
         Number of Alerts where deny-connection was forced for deny-packet action = 89
         Number of Alerts where deny-packet was forced for non-TCP deny-connection action = 0
Output from show statistics transaction-server
General
   totalControlTransactions = 2840
   failedControlTransactions = 16
Output from show statistics web-server
listener-443
   session-4
      remote host = 10.x.x.69
      session is persistent = yes
      number of requests serviced on current connection = 1
      last status code = 200
      last request method = POST
      last request URI = cgi-bin/transaction-server
      last protocol version = HTTP/1.1
      session state = processingActionsState
   session-6
      session is persistent = no
      last request method = GET
      last request URI = cgi-bin/sdee-server
      session state = processingGetServlet
   session-5
   number of server session requests handled = 629400
   number of server session requests rejected = 0
   total HTTP requests handled = 629696
   maximum number of session objects allowed = 40
   number of idle allocated session objects = 7
   number of busy allocated session objects = 3
summarized log messages
   number of TCP socket failure messages logged = 0
   number of TLS socket failure messages logged = 1
   number of TLS protocol failure messages logged = 0
   number of TLS connection failure messages logged = 0
   number of TLS crypto warning messages logged = 0
   number of TLS expired certificate warning messages logged = 0
   number of receipt of TLS fatal alert message messages logged = 0
crypto library version = 6.2.1.0
Output from show health
Overall Health Status                                   Green
Health Status for Failed Applications                   Green
Health Status for Signature Updates                     Green
Health Status for License Key Expiration                Green
Health Status for Running in Bypass Mode                Green
Health Status for Interfaces Being Down                 Green
Health Status for the Inspection Load                   Green
Health Status for the Time Since Last Event Retrieval   Green
Health Status for the Number of Missed Packets          Green
Health Status for the Memory Usage                      Not Enabled
Security Status for Virtual Sensor vs0   Green
Output from show configuration
! Current configuration last modified Tue Feb 07 09:04:20 2012
! Version 6.2(4)
! Host:
!     Realm Keys          key1.0
! Signature Definition:
!     Signature Update    S632.0   2012-03-13
service interface
bypass-mode auto
exit
service authentication
exit
service event-action-rules rules0
overrides log-attacker-packets
override-item-status Enabled
risk-rating-range 70-89
exit
overrides log-victim-packets
exit
overrides log-pair-packets
exit
overrides produce-alert
exit
overrides produce-verbose-alert
exit
filters edit Ignore_two_hosts
signature-id-range 3030
subsignature-id-range 0
attacker-address-range 10.x.x.0-10.x.x.255
actions-to-remove produce-alert
os-relevance relevant|not-relevant|unknown
exit
filters edit Q00000
signature-id-range 11226,11228
victim-address-range 10.x.x.69
actions-to-remove log-attacker-packets|log-victim-packets|log-pair-packets
exit
filters edit Q00001
signature-id-range 5595
attacker-address-range 10.x.x.220-10.x.x.245
exit
filters edit Q00002
signature-id-range 2100
attacker-address-range 10.x.x.86
exit
filters move Ignore_two_hosts begin
filters move Q00000 after Ignore_two_hosts
filters move Q00001 after Q00000
filters move Q00002 after Q00001
exit
service host
network-settings
host-ip 10.1.2.2/29,10.1.2.1
host-name IPS_Sensor
telnet-option disabled
access-list 10.x.x.5/32
access-list 10.x.x.69/32
access-list 10.x.x.86/32
access-list 10.x.x.117/32
exit
time-zone-settings
offset -360
standard-time-zone-name GMT-06:00
exit
ntp-option enabled-ntp-unauthenticated
ntp-server 10.x.x.5
exit
summertime-option recurring
summertime-zone-name UTC
exit
auto-upgrade
cisco-server enabled
schedule-option periodic-schedule
start-time 09:03:17
interval 2
exit
user-name markpiontek
cisco-url https://198.133.219.25//cgi-bin/front.x/ida/locator/locator.pl
exit
exit
exit
service logger
exit
service network-access
general
never-block-hosts 10.x.x.8
never-block-hosts 10.x.x.69
exit
exit
service notification
trap-destinations 10.x.x.86
trap-community-name public
trap-port 162
exit
error-filter warning|error|fatal
enable-detail-traps false
enable-notifications true
enable-set-get true
read-only-community nagioscheck
read-write-community c5c6692a461c537f8cd37b2eb7bec9fb
exit
service signature-definition sig0
signatures 1004 0
status
enabled true
exit
exit
signatures 1225 0
status
enabled true
exit
exit
signatures 1316 0
status
enabled true
exit
exit
signatures 1406 0
status
enabled false
exit
exit
signatures 1408 0
status
enabled true
exit
exit
signatures 1604 0
status
enabled true
exit
exit
signatures 1611 0
status
enabled true
exit
exit
signatures 1623 0
status
enabled true
exit
exit
signatures 1627 0
status
enabled true
exit
exit
signatures 1701 0
status
enabled true
exit
exit
signatures 1703 0
status
enabled true
exit
exit
signatures 1706 0
status
enabled true
exit
exit
signatures 1725 0
status
enabled true
exit
exit
signatures 2011 0
status
enabled true
exit
exit
signatures 2152 0
status
enabled true
exit
exit
signatures 2200 0
status
enabled true
exit
exit
signatures 3030 0
status
enabled true
exit
exit
signatures 3128 1
status
enabled true
exit
exit
signatures 3142 3
status
enabled true
exit
exit
signatures 3143 3
status
enabled true
exit
exit
signatures 3143 4
status
enabled true
exit
exit
signatures 3151 0
status
enabled true
exit
exit
signatures 3220 0
status
enabled true
exit
exit
signatures 3323 0
status
enabled true
exit
exit
signatures 3325 0
status
enabled true
exit
exit
signatures 3357 0
status
enabled true
exit
exit
signatures 3537 1
status
enabled true
exit
exit
signatures 4001 0
status
enabled true
exit
exit
signatures 4068 0
status
enabled true
exit
exit
signatures 4602 3
status
enabled true
exit
exit
signatures 4602 4
status
enabled true
exit
exit
signatures 4607 6
status
enabled true
exit
exit
signatures 4607 7
status
enabled true
exit
exit
signatures 4607 8
status
enabled true
exit
exit
signatures 4607 9
status
enabled true
exit
exit
signatures 4609 1
status
enabled true
exit
exit
signatures 4615 2
status
enabled true
exit
exit
signatures 4615 3
status
enabled true
exit
exit
signatures 4704 0
status
enabled true
exit
exit
signatures 5055 0
status
enabled true
exit
exit
signatures 5176 0
status
enabled true
exit
exit
signatures 5448 0
status
enabled true
exit
exit
signatures 5449 0
status
enabled true
exit
exit
signatures 5450 0
status
enabled true
exit
exit
signatures 5451 0
status
enabled true
exit
exit
signatures 5478 0
status
enabled true
exit
exit
signatures 5513 0
status
enabled true
exit
exit
signatures 5538 0
status
enabled true
exit
exit
signatures 5546 0
status
enabled true
exit
exit
signatures 5648 0
status
enabled true
exit
exit
signatures 5653 0
status
enabled true
exit
exit
signatures 5654 0
status
enabled true
exit
exit
signatures 5663 0
status
enabled true
exit
exit
signatures 5710 0
status
enabled true
exit
exit
signatures 5726 0
status
enabled true
exit
exit
signatures 5726 1
status
enabled true
exit
exit
signatures 5739 0
status
enabled true
exit
exit
signatures 5930 7
status
enabled true
exit
exit
signatures 6007 0
status
enabled true
exit
exit
signatures 6066 0
status
enabled true
exit
exit
signatures 6155 0
status
enabled true
exit
exit
signatures 6155 1
status
enabled true
exit
exit
signatures 6408 0
status
enabled true
exit
exit
signatures 6462 0
status
enabled true
exit
exit
signatures 6462 1
status
enabled true
exit
exit
signatures 6462 2
status
enabled true
exit
exit
signatures 6522 0
status
enabled true
exit
exit
signatures 6996 0
status
enabled true
exit
exit
signatures 7104 0
status
enabled true
exit
exit
signatures 7201 0
engine service-p2p
event-action deny-connection-inline|produce-alert
exit
exit
signatures 7202 0
engine service-p2p
specify-service-ports yes
service-ports 1-1024
exit
exit
status
enabled true
exit
exit
signatures 9401 2
status
enabled true
exit
exit
signatures 9403 2
status
enabled true
exit
exit
signatures 9412 1
status
enabled true
exit
exit
signatures 9418 1
status
enabled true
exit
exit
signatures 9430 1
status
enabled true
exit
exit
signatures 9433 1
status
enabled true
exit
exit
signatures 9515 0
status
enabled true
exit
exit
signatures 9516 0
status
enabled true
exit
exit
signatures 9583 0
status
enabled true
exit
exit
signatures 11001 0
engine string-tcp
event-action produce-alert|deny-packet-inline
exit
exit
signatures 11001 1
engine service-p2p
event-action deny-packet-inline|produce-alert
exit
exit
signatures 11005 1
engine service-http
exit
exit
signatures 11005 2
engine service-p2p
exit
exit
signatures 11007 0
engine string-tcp
exit
exit
signatures 11007 1
engine service-p2p
exit
exit
signatures 11018 0
engine string-tcp
exit
exit
signatures 11019 0
status
enabled true
exit
exit
signatures 11019 1
status
enabled true
exit
exit
signatures 11020 1
engine service-p2p
event-action produce-alert|reset-tcp-connection
exit
exit
signatures 11024 0
status
enabled true
exit
exit
signatures 11030 0
engine service-http
exit
exit
signatures 11031 0
engine service-http
exit
exit
signatures 11202 0
status
enabled true
exit
exit
signatures 11211 0
status
enabled true
exit
exit
signatures 11211 1
status
enabled true
exit
exit
signatures 11214 0
status
enabled true
exit
exit
signatures 11216 0
status
enabled true
exit
exit
signatures 11219 0
status
enabled true
exit
exit
signatures 11221 0
status
enabled true
exit
exit
signatures 11226 0
status
enabled false
exit
exit
signatures 11228 0
status
enabled false
exit
exit
signatures 11231 0
status
enabled true
exit
exit
signatures 11233 2
status
enabled false
exit
exit
signatures 11233 3
status
enabled true
exit
exit
signatures 11238 0
status
enabled false
exit
exit
signatures 11252 0
status
enabled true
exit
exit
signatures 11252 1
status
enabled true
exit
exit
signatures 12704 0
status
enabled true
exit
exit
signatures 12711 0
status
enabled true
exit
exit
signatures 15235 0
status
enabled true
exit
exit
signatures 15235 1
status
enabled true
exit
exit
signatures 15235 2
status
enabled true
exit
exit
signatures 15393 0
status
enabled true
exit
exit
signatures 15816 0
status
enabled true
exit
exit
signatures 17269 0
status
enabled true
exit
exit
signatures 17397 0
status
enabled true
exit
exit
signatures 50013 2
status
enabled true
exit
exit
exit
service ssh-known-hosts
exit
service trusted-certificates
exit
service web-server
exit
service anomaly-detection ad0
exit
service external-product-interface
exit
service health-monitor
exit
service analysis-engine
virtual-sensor vs0
physical-interface GigabitEthernet0/0
exit
exit
Output from cidDump
cidDiag
CID Diagnostics Report Thu Mar 15 09:56:45 UTC 2012
exec: cat /usr/cids/idsRoot/etc/VERSION
6.2(4)E4
exec: /usr/cids/idsRoot/bin/ceGrep -e .*<\/defaultVersions> /usr/cids/idsRoot/etc/config/signatureDefinition/default.xml
      632.0
      2012-03-13
exec: cat /usr/cids/idsRoot/etc/VERSION_RP
1.1 - 6.2(4)E4
exec: cat /proc/version
Linux version 2.4.30-IDS-smp-bigphys (@zunix) (gcc version 2.95.3 20010315 (release)) #2 SMP Mon Dec 15 17:53:56 UTC 2008
exec: uptime
09:58:34 up 36 days, 23:50,  1 user,  load average: 4.11, 2.07, 1.18
exec: ps -ew f
  PID TTY      STAT   TIME COMMAND
    1 ?        S      0:28 init
    2 ?        S      0:00 [keventd]
    3 ?        SN     0:00 [ksoftirqd_CPU0]
    4 ?        S      0:00 [kswapd]
    5 ?        S      0:00 [bdflush]
    6 ?        S      0:00 [kupdated]
   50 ?        S      0:01 [kjournald]
   75 ?        S      0:00 [kjournald]
  108 ?        Ss     0:00 /sbin/syslogd -m 0
  111 ?        Ss     0:00 /sbin/klogd
  123 ?        Ss     0:00 /usr/sbin/inetd
  127 ?        Ss     0:01 /sbin/sshd
32127 ?        Ss     0:03  \_ sshd: cisco@pts/0
32147 pts/0    Ss+    0:01      \_ -cidcli
32151 pts/0    S+     0:00          \_ -cidcli
32152 pts/0    SN+    3:45              \_ -cidcli
32161 pts/0    SN+    0:00              \_ -cidcli
  634 pts/0    SN+    0:00              \_ -cidcli
  317 ?        S<     0:00 /usr/cids/idsRoot/bin/SSM_control_proc
  343 ?        Ss     0:31 /usr/cids/idsRoot/bin/mainApp -d -c 0
  346 ?        S      0:27  \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  347 ?        SN     2:03      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  460 ?        SN     0:02      |   \_ /usr/cids/idsRoot/bin/sensorApp -z 347
  487 ?        SN     0:00      |       \_ /usr/cids/idsRoot/bin/sensorApp -z 347
  488 ?        SN    12:22      |           \_ /usr/cids/idsRoot/bin/sensorApp -z 347
  505 ?        SN    72:38      |           \_ /usr/cids/idsRoot/bin/sensorApp -z 347
1656 ?        S<   2346:40      |           \_ /usr/cids/idsRoot/bin/sensorApp -z 347
  348 ?        S     65:11      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  413 ?        SN   141:59      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  635 ?        SN     0:00      |   \_ /bin/bash /usr/cids/idsRoot/bin/cidDump -text -wxml -nostatus -stdout
  714 ?        RN     0:00      |       \_ ps -ew f
  414 ?        S      0:00      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  420 ?        S      6:13      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  433 ?        SN     0:20      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  434 ?        SN     0:01      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  435 ?        SN     0:00      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  436 ?        SN     0:02      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  437 ?        SN     0:00      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  438 ?        RN     3:23      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  439 ?        SN     3:01      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  440 ?        SN     2:58      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  441 ?        RN     2:59      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  442 ?        RN     3:00      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  443 ?        SN     3:29      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  444 ?        RN     3:03      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  445 ?        SN     2:59      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  446 ?        SN     2:59      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  447 ?        SN     3:03      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  448 ?        SN     2:42      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  452 ?        SN     0:00      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  461 ?        SN     0:22      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  462 ?        RN     0:06      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  463 ?        SN     0:04      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  464 ?        SN     0:07      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  465 ?        SN    12:01      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  699 ?        SN     0:00      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  700 ?        SN     0:00      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  703 ?        SN     0:00      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  704 ?        SN     0:00      \_ /usr/cids/idsRoot/bin/mainApp -d -c 0
  384 tty1     Ss+    0:00 /sbin/getty 38400 tty1
  385 tty2     Ss+    0:00 /sbin/getty 38400 tty2
  386 ttyS0    Ss+    0:00 /sbin/getty -L ttyS0 9600 vt100
  426 ?        SNLs  16:53 ntpd
exec: cat /usr/cids/idsRoot/tmp/top.log
top - 09:56:47 up 36 days, 23:49,  1 user,  load average: 1.50, 1.00, 0.78
Tasks:  69 total,   3 running,  66 sleeping,   0 stopped,   0 zombie
Cpu(s):   2.0% user,  23.5% system,   3.3% nice,  71.2% idle
Mem:    477928k total,   445572k used,    32356k free,     6412k buffers
Swap:        0k total,        0k used,        0k free,   101912k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
  644 root      20   5   508  508  432 R 51.9  0.1   0:01.09 grep
  636 root      17   5   920  920  732 R 23.0  0.2   0:00.75 top
  638 root      13   5   520  520  448 S  7.2  0.1   0:00.27 vmstat
1656 cids       5  -9 22828 346m 332m S  2.0 74.2   2346:33 sensorApp
    1 root       8   0   572  572  488 S  0.0  0.1   0:28.91 init
    2 root       9   0     0    0    0 S  0.0  0.0   0:00.00 keventd
    3 root      18  19     0    0    0 S  0.0  0.0   0:00.00 ksoftirqd_CPU0
    4 root       9   0     0    0    0 S  0.0  0.0   0:00.09 kswapd
    5 root       9   0     0    0    0 S  0.0  0.0   0:00.00 bdflush
    6 root       9   0     0    0    0 S  0.0  0.0   0:00.00 kupdated
   50 root       9   0     0    0    0 S  0.0  0.0   0:01.10 kjournald
   75 root       9   0     0    0    0 S  0.0  0.0   0:00.05 kjournald
  108 root       9   0   580  580  500 S  0.0  0.1   0:00.09 syslogd
  111 root       9   0   564  564  488 S  0.0  0.1   0:00.03 klogd
  123 root       9   0   704  704  608 S  0.0  0.1   0:00.01 inetd
  127 root       9   0   852  852  732 S  0.0  0.2   0:01.05 sshd
  317 root       5  -9   708  708  612 S  0.0  0.1   0:00.15 SSM_control_pro
  343 cids       9   0 14316  13m 9596 S  0.0  3.0   0:31.11 mainApp
  346 cids       8   0 14316  13m 9596 S  0.0  3.0   0:27.20 mainApp
  347 cids      13   5 14316  13m 9596 S  0.0  3.0   2:03.26 mainApp
  348 cids       9   0 14316  13m 9596 S  0.0  3.0  65:11.30 mainApp
  384 root       9   0   536  536  456 S  0.0  0.1   0:00.04 getty
  385 root       9   0   536  536  456 S  0.0  0.1   0:00.04 getty
  386 root       9   0   544  544  464 S  0.0  0.1   0:00.04 getty
  413 cids      13   5 14316  13m 9596 S  0.0  3.0 141:59.42 mainApp
  414 cids       9   0 14316  13m 9596 S  0.0  3.0   0:00.00 mainApp
  420 cids       9   0 14316  13m 9596 S  0.0  3.0   6:13.39 mainApp
  426 root      13   5  2504 2504 1820 S  0.0  0.5  16:53.79 ntpd
  433 cids      13   5 14316  13m 9596 S  0.0  3.0   0:20.64 mainApp
  434 cids      13   5 14316  13m 9596 S  0.0  3.0   0:01.66 mainApp
  435 cids      17  15 14316  13m 9596 S  0.0  3.0   0:00.01 mainApp
  436 cids      13   5 14316  13m 9596 S  0.0  3.0   0:02.37 mainApp
  437 cids      13   5 14316  13m 9596 S  0.0  3.0   0:00.01 mainApp
  438 cids      15  10 14316  13m 9596 S  0.0  3.0   3:23.64 mainApp
  439 cids      15  10 14316  13m 9596 S  0.0  3.0   3:01.15 mainApp
  440 cids      15  10 14316  13m 9596 S  0.0  3.0   2:58.92 mainApp
  441 cids      15  10 14316  13m 9596 S  0.0  3.0   2:59.74 mainApp
  442 cids      15  10 14316  13m 9596 S  0.0  3.0   3:00.58 mainApp
  443 cids      15  10 14316  13m 9596 S  0.0  3.0   3:29.60 mainApp
  444 cids      15  10 14316  13m 9596 S  0.0  3.0   3:03.72 mainApp
  445 cids      15  10 14316  13m 9596 S  0.0  3.0   2:59.21 mainApp
  446 cids      15  10 14316  13m 9596 S  0.0  3.0   2:59.60 mainApp
  447 cids      15  10 14316  13m 9596 S  0.0  3.0   3:03.92 mainApp
  448 cids      13   5 14316  13m 9596 S  0.0  3.0   2:42.38 mainApp
  452 cids      17  15 14316  13m 9596 S  0.0  3.0   0:00.17 mainApp
  460 cids      13   5 22828 346m 332m S  0.0 74.2   0:02.71 sensorApp
  461 cids      17  15 14316  13m 9596 S  0.0  3.0   0:22.35 mainApp
  462 cids      17  15 14316  13m 9596 S  0.0  3.0   0:06.23 mainApp
  463 cids      17  15 14316  13m 9596 S  0.0  3.0   0:04.12 mainApp
  464 cids      17  15 14316  13m 9596 S  0.0  3.0   0:07.79 mainApp
  465 cids      17  15 14316  13m 9596 R  0.0  3.0  12:01.55 mainApp
  487 cids      13   5 22828 346m 332m S  0.0 74.2   0:00.13 sensorApp
  488 cids      13   5 22828 346m 332m S  0.0 74.2  12:22.27 sensorApp
  505 cids      13   5 22828 346m 332m S  0.0 74.2  72:38.62 sensorApp
32127 root       9   0  1636 1632 1248 S  0.0  0.3   0:03.81 sshd
32147 cisco      9   0  6768 6768 5160 S  0.0  1.4   0:01.51 cidcli
32151 cisco      9   0  6768 6768 5160 S  0.0  1.4   0:00.00 cidcli
32152 cisco     13   5  6768 6768 5160 S  0.0  1.4   3:45.57 cidcli
32161 cisco     16  15  6768 6768 5160 S  0.0  1.4   0:00.00 cidcli
  628 cids      16  15 14316  13m 9596 S  0.0  3.0   0:00.01 mainApp
  629 cids      17  15 14316  13m 9596 S  0.0  3.0   0:00.04 mainApp
  632 cids      16  15 14316  13m 9596 S  0.0  3.0   0:00.00 mainApp
  633 cids      17  15 14316  13m 9596 S  0.0  3.0   0:00.04 mainApp
  634 cisco     14  10  6768 6768 5160 S  0.0  1.4   0:00.00 cidcli
  635 root      13   5  1004 1004  896 S  0.0  0.2   0:00.13 cidDump
  637 root      13   5   528  528  472 S  0.0  0.1   0:00.03 mpstat
  641 root      13   5  1008 1008  900 S  0.0  0.2   0:00.00 cidDump
  642 root      13   5   464  464  392 S  0.0  0.1   0:00.04 cat
  643 root      13   5   520  520  376 S  0.0  0.1   0:00.05 gzip
top - 09:56:52 up 36 days, 23:49,  1 user,  load average: 1.54, 1.02, 0.79
Tasks:  71 total,   5 running,  66 sleeping,   0 stopped,   0 zombie
Cpu(s):   0.4% user,  42.8% system,  56.8% nice,   0.0% idle
Mem:    477928k total,   445624k used,    32304k free,     6412k buffers
Swap:        0k total,        0k used,        0k free,   101920k cached
  644 root      20   5   512  512  432 R 72.6  0.1   0:04.85 grep
  638 root      13   5   520  520  448 S  9.5  0.1   0:00.76 vmstat
  636 root      17   5  1016 1016  816 R  9.1  0.2   0:01.22 top
1656 cids       5  -9 22828 346m 332m S  1.9 74.2   2346:33 sensorApp
  646 cids      17  15 14332  13m 9596 S  1.0  3.0   0:00.05 mainApp
  648 cids      17  15 14332  13m 9596 S  1.0  3.0   0:00.05 mainApp
  650 cids      17  15 14332  13m 9596 S  0.8  3.0   0:00.04 mainApp
  643 root      13   5   520  520  376 S  0.6  0.1   0:00.08 gzip
  445 cids      15  10 14332  13m 9596 R  0.2  3.0   2:59.22 mainApp
  465 cids      17  15 14332  13m 9596 R  0.2  3.0  12:01.56 mainApp
  343 cids       9   0 14332  13m 9596 S  0.0  3.0   0:31.11 mainApp
  346 cids       9   0 14332  13m 9596 S  0.0  3.0   0:27.20 mainApp
  347 cids      13   5 14332  13m 9596 S  0.0  3.0   2:03.26 mainApp
  348 cids       9   0 14332  13m 9596 S  0.0  3.0  65:11.30 mainApp
  413 cids      13   5 14332  13m 9596 S  0.0  3.0 141:59.42 mainApp
  414 cids       9   0 14332  13m 9596 S  0.0  3.0   0:00.00 mainApp
  420 cids       9   0 14332  13m 9596 S  0.0  3.0   6:13.39 mainApp
  433 cids      13   5 14332  13m 9596 S  0.0  3.0   0:20.64 mainApp
  434 cids      13   5 14332  13m 9596 S  0.0  3.0   0:01.66 mainApp
  435 cids      17  15 14332  13m 9596 S  0.0  3.0   0:00.01 mainApp
  436 cids      13   5 14332  13m 9596 S  0.0  3.0   0:02.37 mainApp
  437 cids      13   5 14332  13m 9596 S  0.0  3.0   0:00.01 mainApp
  438 cids      15  10 14332  13m 9596 S  0.0  3.0   3:23.64 mainApp
  439 cids      15  10 14332  13m 9596 S  0.0  3.0   3:01.15 mainApp
  440 cids      15  10 14332  13m 9596 S  0.0  3.0   2:58.92 mainApp
  441 cids      15  10 14332  13m 9596 R  0.0  3.0   2:59.74 mainApp
  442 cids      15  10 14332  13m 9596 S  0.0  3.0   3:00.58 mainApp
  443 cids      15  10 14332  13m 9596 S  0.0  3.0   3:29.60 mainApp
  444 cids      15  10 14332  13m 9596 S  0.0  3.0   3:03.72 mainApp
  446 cids      15  10 14332  13m 9596 S  0.0  3.0   2:59.60 mainApp
  447 cids      15  10 14332  13m 9596 S  0.0  3.0   3:03.92 mainApp
  448 cids      13   5 14332  13m 9596 S  0.0  3.0   2:42.38 mainApp
  452 cids      17  15 14332  13m 9596 S  0.0  3.0   0:00.17 mainApp
  461 cids      17  15 14332  13m 9596 S  0.0  3.0   0:22.35 mainApp
  462 cids      17  15 14332  13m 9596 S  0.0  3.0   0:06.23 mainApp
  463 cids      17  15 14332  13m 9596 S  0.0  3.0   0:04.12 mainApp
  464 cids      17  15 14332  13m 9596 S  0.0  3.0   0:07.79 mainApp
  645 cids      16  15 14332  13m 9596 S  0.0  3.0   0:00.00 mainApp
  647 cids      16  15 14332  13m 9596 S  0.0  3.0   0:00.00 mainApp
  649 cids      16  15 14332  13m 9596 S  0.0  3.0   0:00.00 mainApp
top - 09:56:57 up 36 days, 23:49,  1 user,  load average: 1.74, 1.07, 0.80
Cpu(s):   0.4% user,  44.3% system,  55.3% nice,   0.0% idle
Mem:    477928k total,   445628k used,    32300k free,     6412k buffers
Swap:        0k total,        0k used,        0k free,   101924k cached
  644 root      17   5   512  512  432 R 75.2  0.1   0:08.62 grep
  636 root      18   5  1020 1020  816 R 10.2  0.2   0:01.73 top
  638 root      13   5   520  520  448 S  9.8  0.1   0:01.25 vmstat
1656 cids       5  -9 22828 346m 332m S  1.6 74.2   2346:33 sensorApp
  643 root      13   5   520  520  376 S  1.6  0.1   0:00.16 gzip
  652 cids      17  15 14332  13m 9596 S  1.2  3.0   0:00.06 mainApp
  441 cids      15  10 14332  13m 9596 S  0.0  3.0   2:59.74 mainApp
  445 cids      15  10 14332  13m 9596 R  0.0  3.0   2:59.22 mainApp
  465 cids      17  15 14332  13m 9596 R  0.0  3.0  12:01.56 mainApp
  634 cisco     14  10  6768 6768 5160 R  0.0  1.4   0:00.00 cidcli
  646 cids      17  15 14332  13m 9596 S  0.0  3.0   0:00.05 mainApp
  650 cids      17  15 14332  13m 9596 S  0.0  3.0   0:00.04 mainApp
  651 cids      16  15 14332  13m 9596 S  0.0  3.0   0:00.00 mainApp
top - 09:57:02 up 36 days, 23:49,  1 user,  load average: 1.68, 1.07, 0.80
Tasks:  71 total,   4 running,  67 sleeping,   0 stopped,   0 zombie
Cpu(s):   1.4% user,  44.1% system,  54.5% nice,   0.0% idle
Mem:    477928k total,   445636k used,    32292k free,     6412k buffers
Swap:        0k total,        0k used,        0k free,   101932k cached
  644 root      17   5   512  512  432 R 75.5  0.1   0:12.42 grep
  636 root      17   5  1020 1020  816 R 10.3  0.2   0:02.25 top
  638 root      13   5   520  520  448 S  9.5  0.1   0:01.73 vmstat
1656 cids       5  -9 22828 346m 332m S  2.8 74.2   2346:33 sensorApp
  643 root      13   5   520  520  376 S  1.2  0.1   0:00.22 gzip
  654 cids      17  15 14332  13m 9596 S  0.8  3.0   0:00.04 mainApp
  465 cids      17  15 14332  13m 9596 S  0.0  3.0  12:01.56 mainApp
  653 cids      16  15 14332  13m 9596 S  0.0  3.0   0:00.00 mainApp
exec: cat /usr/cids/idsRoot/tmp/mpstat.log
Linux 2.4.30-IDS-smp-bigphys (IPS_Sensor) 03/15/12
09:56:45     CPU   %user   %nice %system %iowait    %irq   %soft   %idle    intr/s
09:56:46     all    2.00   45.00   53.00    0.00    0.00    0.00    0.00   9187.00
09:56:47     all    0.00   57.00   43.00    0.00    0.00    0.00    0.00   9201.00
09:56:48     all    1.00   49.00   50.00    0.00    0.00    0.00    0.00   9218.00
09:56:49     all    0.00   63.00   37.00    0.00    0.00    0.00    0.00   9199.00
09:56:50     all    1.00   61.00   38.00    0.00    0.00    0.00    0.00   9185.00
09:56:51     all    0.00   56.00   44.00    0.00    0.00    0.00    0.00   9190.00
09:56:52     all    0.00   57.00   43.00    0.00    0.00    0.00    0.00   9201.00
09:56:53     all    0.00   50.00   50.00    0.00    0.00    0.00    0.00   9198.00
09:56:54     all    1.00   54.00   45.00    0.00    0.00    0.00    0.00   9203.00
09:56:55     all    0.00   59.00   41.00    0.00    0.00    0.00    0.00   9191.00
09:56:56     all    0.00   59.00   41.00    0.00    0.00    0.00    0.00   9189.00
09:56:57     all    1.00   53.00   46.00    0.00    0.00    0.00    0.00   9194.00
09:56:58     all    3.00   52.00   45.00    0.00    0.00    0.00    0.00   9201.00
09:56:59     all    2.00   53.00   45.00    0.00    0.00    0.00    0.00   9204.00
09:57:00     all    0.00   53.00   47.00    0.00    0.00    0.00    0.00   9195.00
09:57:01     all    2.00   61.00   37.00    0.00    0.00    0.00    0.00   9217.00
09:57:02     all    0.00   56.00   44.00    0.00    0.00    0.00    0.00   9213.00
09:57:03     all    0.00   52.00   48.00    0.00    0.00    0.00    0.00   9169.00
09:57:04     all    0.00   51.00   49.00    0.00    0.00    0.00    0.00   9204.00
09:57:05     all    0.00   61.00   39.00    0.00    0.00    0.00    0.00   9195.00
Average:     all    0.65   55.10   44.25    0.00    0.00    0.00    0.00   9197.70
exec: cat /usr/cids/idsRoot/tmp/vmstat.log
procs -----------memory---------- ---swap-- -----io---- --system-- ----cpu----
r  b   swpd   free   buff  cache   si   so    bi    bo   in    cs us sy id wa
3  0      0  32816   6412 101900    0    0     0     0    3    10  5 24 71  0
4  0      0  32364   6412 101912    0    0     0     0 13412   472 52 48  0  0
6  0      0  32344   6412 101920    0    0     0     0 11785   456 52 48  0  0
3  0      0  32344   6412 101920    0    0     0     0 11783   510 60 40  0  0
3  0      0  32344   6412 101920    0    0     0     0 11119   419 61 39  0  0
6  0      0  32308   6412 101920    0    0     0     0 11126   466 55 45  0  0
4  0      0  32300   6412 101924    0    0     0     0 12324   433 54 46  0  0
4  0      0  32300   6412 101924    0    0     0     0 11043   522 56 44  0  0
4  0      0  32300   6412 101924    0    0     0     0 11212   460 58 42  0  0
5  0      0  32300   6412 101924    0    0     0     0 11028   447 58 42  0  0
3  0      0  32292   6412 101932    0    0     0     0 11678   409 52 48  0  0
4  0      0  32292   6412 101932    0    0     0     0 11508   539 55 45  0  0
5  0      0  32292   6412 101932    0    0     0     0 11218   464 56 44  0  0
4  0      0  32292   6412 101932    0    0     0     0 11149   472 64 36  0  0
6  0      0  32288   6412 101936    0    0     0     0 10937   376 49 51  0  0
4  0      0  32500   6412 101940    0    0     0     0 11408   523 54 46  0  0
4  0      0  32568   6412 101940    0    0     0     0 11034   452 58 42  0  0
4  0      0  32568   6412 101940    0    0     0     0 11129   447 54 46  0  0
5  0      0  32568   6412 101940    0    0     0     0 11310   467 54 46  0  0
4  0      0  32580   6412 101940    0    0     0     0 11046   484 54 46  0  0
exec: df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/ramdisk             38.5M     18.2M     20.3M  47% /
/dev/hda2               166.8M     42.4M    115.8M  27% /mnt/rw
/dev/hda2               166.8M     42.4M    115.8M  27% /dev
/dev/hda2               166.8M     42.4M    115.8M  27% /etc
/dev/hda2               166.8M     42.4M    115.8M  27% /home
/dev/hda2               166.8M     42.4M    115.8M  27% /usr/cids
/dev/hda2               166.8M     42.4M    115.8M  27% /lib/modules
/dev/boot                68.6M     40.8M     24.2M  63% /boot
none                      5.0M      4.0k      5.0M   0% /tmp
none                      8.0M     68.0k      7.9M   1% /var
none                  16384.0T         0  16384.0T   0% /mnt/huge
none                    513.0M     19.3M    493.7M   4% /usr/cids/idsRoot/var/iplogs
none                    521.0M     40.0k    521.0M   0% /usr/cids/idsRoot/tmp
none                     31.0M      9.6M     21.4M  31% /usr/cids/idsRoot/var/eventStore
exec: mount
/dev/ramdisk on / type ext2 (rw)
/proc on /proc type proc (rw)
/dev/hda2 on /mnt/rw type ext3 (rw,noatime)
/dev/hda2 on /dev type ext3 (rw,noatime)
/dev/hda2 on /etc type ext3 (rw,noatime)
/dev/hda2 on /home type ext3 (rw,noatime)
/dev/hda2 on /usr/cids type ext3 (rw,noatime)
/dev/hda2 on /lib/modules type ext3 (rw,noatime)
/dev/boot on /boot type ext3 (ro)
none on /tmp type tmpfs (rw)
none on /var type tmpfs (rw)
none on /dev/pts type devpts (rw)
none on /mnt/huge type hugetlbfs (rw)
none on /usr/cids/idsRoot/var/iplogs type tmpfs (rw)
none on /usr/cids/idsRoot/tmp type tmpfs (rw)
none on /usr/cids/idsRoot/var/eventStore type tmpfs (rw)
exec: cat /var/log/messages
Feb  7 09:02:56 sensor syslog.info syslogd started: BusyBox v1.00-rc1 (2008.12.15-18:01+0000)
Feb  7 09:02:56 sensor user.warn kernel: zone(1): 125929 pages.
Feb  7 09:02:56 sensor user.warn kernel: zone(2): 0 pages.
Feb  7 09:02:56 sensor user.info kernel: DMI not present.
Feb  7 09:02:56 sensor user.err kernel: ACPI: Unable to locate RSDP
Feb  7 09:02:56 sensor user.warn kernel: Kernel command line: ro ramdisk_size=76800 rootrw=/dev/hda2 root=/dev/ram0 init=loadrc hda=flash nousb console=ttyS0 htlblow=8 hugepages=74 tlv=BP9QAAD9gAD+gB8vdm1saW51ei0yLjQuMzAtSURTLXNtcC1iaWdwaHlzcw==
Feb  7 09:02:56 sensor user.info kernel: ide_setup: hda=flash
Feb  7 09:02:56 sensor user.info kernel: hugetlb_lowmem_setup: Allocated 33554432 huge pages (size=0x400000) from lowmem area at 0xc1800000
Feb  7 09:02:56 sensor user.warn kernel: No local APIC present or hardware disabled
Feb  7 09:02:56 sensor user.info kernel: Initializing CPU#0
Feb  7 09:02:56 sensor user.warn kernel: Detected 498.059 MHz processor.
Feb  7 09:02:56 sensor user.warn kernel: Console: colour *CGA 80x25
Feb  7 09:02:56 sensor user.warn kernel: Calibrating delay loop... 992.87 BogoMIPS
Feb  7 09:02:56 sensor user.info kernel: Memory: 470240k/520100k available (1621k kernel code, 49468k reserved, 707k data, 132k init, 0k highmem)
Feb  7 09:02:56 sensor user.info kernel: Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
Feb  7 09:02:56 sensor user.info kernel: Inode cache hash table entries: 32768 (order: 6, 262144 bytes)
Feb  7 09:02:56 sensor user.info kernel: Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Feb  7 09:02:56 sensor user.info kernel: Buffer cache hash table entries: 32768 (order: 5, 131072 bytes)
Feb  7 09:02:56 sensor user.warn kernel: Page-cache hash table entries: 131072 (order: 7, 524288 bytes)
Feb  7 09:02:56 sensor user.info kernel: CPU: L1 I Cache: 64K (32 bytes/line), D cache 64K (32 bytes/line)
Feb  7 09:02:56 sensor user.info kernel: CPU: L2 Cache: 128K (32 bytes/line)
Feb  7 09:02:56 sensor user.debug kernel: CPU:     After generic, caps: 0088a93d c0c0a13d 00000000 00000000
Feb  7 09:02:56 sensor user.debug kernel: CPU:             Common caps: 0088a93d c0c0a13d 00000000 00000000
Feb  7 09:02:56 sensor user.info kernel: Checking 'hlt' instruction... OK.
Feb  7 09:02:56 sensor user.warn kernel: POSIX conformance testing by UNIFIX
Feb  7 09:02:56 sensor user.warn kernel: mtrr: v1.40 (20010327) Richard Gooch (rgooch@atnf.csiro.au)
Feb  7 09:02:56 sensor user.warn kernel: mtrr: detected mtrr type: none
Feb  7 09:02:56 sensor user.warn kernel: CPU0: AMD Geode(TM) Integrated Processor by AMD PCS stepping 02
Feb  7 09:02:56 sensor user.warn kernel: per-CPU timeslice cutoff: 365.46 usecs.
Feb  7 09:02:56 sensor user.notice kernel: SMP motherboard not detected.
Feb  7 09:02:56 sensor daemon.info init: ^MStarting pid 113, console /dev/console: '/etc/init.d/rcS'
Feb  7 09:02:56 sensor user.notice kernel: Local APIC not detected. Using dummy APIC emulation.
Feb  7 09:02:56 sensor user.warn kernel: Waiting on wait_init_idle (map = 0x0)
Feb  7 09:02:56 sensor user.warn kernel: All processors have done init_idle
Feb  7 09:02:56 sensor user.info kernel: PCI: PCI BIOS revision 2.10 entry at 0xff699, last bus=0
Feb  7 09:02:56 sensor user.info kernel: PCI: Using configuration type 1
Feb  7 09:02:56 sensor user.info kernel: PCI: Probing PCI hardware
Feb  7 09:02:56 sensor user.warn kernel: PCI: Probing PCI hardware (bus 00)
Feb  7 09:02:56 sensor user.info kernel: isapnp: Scanning for PnP cards...
Feb  7 09:02:56 sensor user.info kernel: isapnp: No Plug & Play device found
Feb  7 09:02:56 sensor user.info kernel: Linux NET4.0 for Linux 2.4
Feb  7 09:02:56 sensor user.info kernel: Based upon Swansea University Computer Society NET3.039
Feb  7 09:02:56 sensor user.warn kernel: Initializing RT netlink socket
Feb  7 09:02:56 sensor user.err kernel: hugetlb_init: Using 8 pages from low memory at c1800000for HugeTLB FS
Feb  7 09:02:56 sensor user.info kernel: hugetlb_init: Adding a 0x400000 size page at c109c020 to HugeTLB lowmem freelist
Feb  7 09:02:56 sensor user.info kernel: hugetlb_init: Adding a 0x400000 size page at c1090020 to HugeTLB lowmem freelist
Feb  7 09:02:56 sensor user.info kernel: hugetlb_init: Adding a 0x400000 size page at c1084020 to HugeTLB lowmem freelist
Feb  7 09:02:56 sensor user.info kernel: hugetlb_init: Adding a 0x400000 size page at c1078020 to HugeTLB lowmem freelist
Feb  7 09:02:56 sensor user.info kernel: hugetlb_init: Adding a 0x400000 size page at c106c020 to HugeTLB lowmem freelist
Feb  7 09:02:56 sensor user.info kernel: hugetlb_init: Adding a 0x400000 size page at c1060020 to HugeTLB lowmem freelist
Feb  7 09:02:56 sensor user.info kernel: hugetlb_init: Adding a 0x400000 size page at c1054020 to HugeTLB lowmem freelist
Feb  7 09:02:56 sensor user.info kernel: hugetlb_init: Adding a 0x400000 size page at c1048020 to HugeTLB lowmem freelist
Feb  7 09:02:56 sensor user.warn kernel: Total HugeTLB memory allocated, 82 of 0x400000 size pages
Feb  7 09:02:56 sensor user.warn kernel: Starting kswapd
Feb  7 09:02:56 sensor user.info kernel: Journalled Block Device driver loaded
Feb  7 09:02:56 sensor user.warn kernel: Hugetlbfs mounted.
Feb  7 09:02:56 sensor user.info kernel: keyboard: controller not found
Feb  7 09:02:56 sensor user.warn kernel: pty: 2048 Unix98 ptys configured
Feb  7 09:02:56 sensor user.info kernel: Serial driver version 5.05c (2001-07-08) with MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI ISAPNP enabled
Feb  7 09:02:56 sensor user.info kernel: ttyS00 at 0x03f8 (irq = 4) is a 16550A
Feb  7 09:02:56 sensor user.info kernel: Real Time Clock Driver v1.10f
Feb  7 09:02:56 sensor user.warn kernel: RAMDISK driver initialized: 16 RAM disks of 76800K size 1024 blocksize
Feb  7 09:02:56 sensor user.info kernel: loop: loaded (max 8 devices)
Feb  7 09:02:56 sensor user.info kernel: lpc: version 0.1 (Dec 15 2008)
Feb  7 09:02:56 sensor user.info kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
Feb  7 09:02:56 sensor user.info kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Feb  7 09:02:56 sensor user.warn kernel: hdb: C/H/S=0/0/0 from BIOS ignored
Feb  7 09:02:56 sensor user.warn kernel: hda: VI 512MB, CFA DISK drive
Feb  7 09:02:56 sensor user.warn kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Feb  7 09:02:56 sensor user.warn kernel: hda: attached ide-disk driver.
Feb  7 09:02:56 sensor user.info kernel: hda: 1015056 sectors (520 MB) w/1KiB Cache, CHS=1007/16/63
Feb  7 09:02:56 sensor user.info kernel: Partition check:
Feb  7 09:02:56 sensor user.info kernel:  hda: hda1 hda2 hda3 hda4
Feb  7 09:02:56 sensor user.err kernel: ide: late registration of driver.
Feb  7 09:02:56 sensor user.info kernel: SCSI subsystem driver Revision: 1.00
Feb  7 09:02:56 sensor user.info kernel: i2c-core.o: i2c core module version 2.10.0 (20060214)
Feb  7 09:02:56 sensor user.info kernel: i2c-dev.o: i2c /dev entries driver module version 2.10.0 (20060214)
Feb  7 09:02:56 sensor user.info kernel: i2c-proc.o version 2.10.0 (20060214)
Feb  7 09:02:56 sensor user.info kernel: i2c-i801 version 2.10.0 (20060214)
Feb  7 09:02:56 sensor user.info kernel: ipmi message handler version 37
Feb  7 09:02:56 sensor user.info kernel: ipmi device interface version 37
Feb  7 09:02:56 sensor user.info kernel: IPMI SMB Interface driver version 37a
Feb  7 09:02:56 sensor user.info kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Feb  7 09:02:56 sensor user.info kernel: IP Protocols: ICMP, UDP, TCP, IGMP
Feb  7 09:02:56 sensor user.info kernel: IP: routing cache hash table of 4096 buckets, 32Kbytes
Feb  7 09:02:56 sensor user.info kernel: TCP: Hash tables configured (established 32768 bind 32768)
Feb  7 09:02:56 sensor user.info kernel: Linux IP multicast router 0.06 plus PIM-SM
Feb  7 09:02:56 sensor user.info kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Feb  7 09:02:56 sensor user.notice kernel: RAMDISK: Compressed image found at block 0
Feb  7 09:02:56 sensor user.info kernel: Freeing initrd memory: 7554k freed
Feb  7 09:02:56 sensor user.warn kernel: VFS: Mounted root (ext2 filesystem) readonly.
Feb  7 09:02:56 sensor user.info kernel: Freeing unused kernel memory: 132k freed
Feb  7 09:02:56 sensor user.warn kernel: EXT2-fs warning: checktime reached, running e2fsck is recommended
Feb  7 09:02:56 sensor user.info kernel: kjournald starting.  Commit interval 5 seconds
Feb  7 09:02:56 sensor user.info kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,2), internal journal
Feb  7 09:02:56 sensor user.info kernel: EXT3-fs: mounted filesystem with ordered data mode.
Feb  7 09:02:56 sensor auth.info sshd[127]: Server listening on 0.0.0.0 port 22.
Feb  7 09:02:58 sensor user.warn kernel: cs5536_gpio_baseaddr f000
Feb  7 09:02:58 sensor user.debug kernel: scx200_acb: NatSemi SCx200 ACCESS.bus Driver
Feb  7 09:02:58 sensor user.debug kernel: i2c-dev.o: Registered 'SCx200 ACB0' as minor 0
Feb  7 09:03:00 sensor user.debug platform[159]: error 19 opening lpc device
Feb  7 09:03:01 sensor user.info kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,1), internal journal
Feb  7 09:03:02 sensor user.notice /etc/init.d/S80cids: Load cidmodcap:
Feb  7 09:03:02 sensor user.notice /etc/init.d/S80cids: Create node:
Feb  7 09:03:03 sensor user.warn kernel: sk98lin: Network Device Driver v8.41.2.3
Feb  7 09:03:03 sensor user.warn kernel: (C)Copyright 1999-2006 Marvell(R).
Feb  7 09:03:03 sensor user.warn kernel: sk98lin: Port A: FlowControl impossible without AutoNegotiation, disabled
Feb  7 09:03:03 sensor user.warn kernel: eth0: Generic Marvell Yukon chipset Ethernet device
Feb  7 09:03:03 sensor user.warn kernel:       PrefPort:A  RlmtMode:Check Link State
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsSetDebugLevel,800): Setting CIDS debug level 0x00000000.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsSetOperMode,784): Setting CIDS operation mode SENSOR.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsSetPacketDump,830): CIDS packet dump - False.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsSetDataLoopback,863): CIDS data loopback - False.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(sk98lin_init_device,692): Attempts to initialize sensing virtual devices.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsDevRegister,266): Registers virtual device eth1 as a Linux network device successfully.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsRegisterVirtualDevices,414): Add eth1 successfully to CIDS context.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsDevRegister,266): Registers virtual device eth2 as a Linux network device successfully.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsRegisterVirtualDevices,414): Add eth2 successfully to CIDS context.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsShrRegister,1052): Registers virtual sensing device as a Linux network device successfully.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsRegisterVirtualDevices,414): Add eth3 successfully to CIDS context.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(SkCidsInit,949): Register virtual net devices to CIDS context successfully.
Feb  7 09:03:03 sensor user.warn kernel: skge-cids(sk98lin_init_device,699): Sensing virtual devices initialized successfully.
Feb  7 09:03:04 sensor user.warn kernel: eth0: network connection up using port A
Feb  7 09:03:04 sensor user.warn kernel:     speed:           1000
Feb  7 09:03:04 sensor user.warn kernel:     autonegotiation: no
Feb  7 09:03:04 sensor user.warn kernel:     duplex mode:     full
Feb  7 09:03:04 sensor user.warn kernel:     flowctrl:        none
Feb  7 09:03:04 sensor user.warn kernel:     irq moderation:  dynamic (2000 ints/sec)
Feb  7 09:03:04 sensor user.warn kernel:     scatter-gather:  disabled
Feb  7 09:03:04 sensor user.warn kernel:     tx-checksum:     enabled
Feb  7 09:03:04 sensor user.warn kernel:     rx-checksum:     enabled
Feb  7 09:03:04 sensor user.warn kernel: skge-cids(SkGeOpen,2617): Attempt to open sensing virtual devices.
Feb  7 09:03:04 sensor user.warn kernel: skge-cids(SkCidsOpenVirtual,531): Open virtual device eth1 successfully.
Feb  7 09:03:04 sensor user.warn kernel: skge-cids(SkCidsOpen,1035): Open virtual device successfully.
Feb  7 09:03:04 sensor user.warn kernel: skge-cids(SkCidsOpenVirtual,531): Open virtual device eth2 successfully.
Feb  7 09:03:04 sensor user.warn kernel: skge-cids(SkCidsOpenVirtual,531): Open virtual device eth3 successfully.
Feb  7 09:03:04 sensor user.warn kernel: skge-cids(SkGeOpen,2622): Sensing virtual devices opened successfully.
Feb  7 09:03:06 sensor user.warn kernel: skge-cids(SkCidsShrStart,202): Starting cids-shared component.
Feb  7 09:03:06 sensor user.warn kernel: ip_tables: (C) 2000-2002 Netfilter core team
Feb  7 09:03:07 sensor user.warn kernel: ip_conntrack version 2.1 (4063 buckets, 32504 max) - 288 bytes per conntrack
Feb  7 09:03:08 sensor user.notice /etc/init.d/S80cids: Load rebootkom:
Feb  7 09:03:08 sensor user.notice root: Starting SSM controlplane
Feb  7 09:03:08 sensor user.warn kernel: TIPC: Compiled Dec 15 2008 18:40:43
Feb  7 09:03:08 sensor user.info kernel: ../reg.c: Started in single node mode
Feb  7 09:03:08 sensor user.info kernel: ../reg.c: Started in network mode
Feb  7 09:03:08 sensor user.info kernel: ../reg.c: Own node address <1.1.2>, network identity 1234
Feb  7 09:03:08 sensor user.info kernel: ../media.c: Enabled bearer , detection scope <1.1.0>
Feb  7 09:03:10 sensor user.notice root: running with superuser privileges
Feb  7 09:03:10 sensor user.notice root: removing master sema: /usr/cids/idsRoot/tmp/
Feb  7 09:03:10 sensor user.notice root: removing master sema: /usr/cids/idsRoot/tmp/ipc/
Feb  7 09:03:10 sensor user.notice root: removing shared mem: /usr/cids/idsRoot/tmp/ipc/shm_ipsdebug_cidsInit
Feb  7 09:03:10 sensor user.notice /etc/init.d/S80cids: Clean up:
Feb  7 09:03:13 sensor user.notice /etc/init.d/S80cids: mainApp -d -c 0 startup
Feb  7 09:03:14 sensor user.notice root: mainApp (cids) started
Feb  7 09:03:14 sensor user.notice /etc/init.d/S80cids: Starting CIDS:
Feb  7 09:03:18 sensor daemon.info init: ^MStarting pid 384, console /dev/tty1: '/sbin/getty'
Feb  7 09:03:18 sensor daemon.info init: ^MStarting pid 385, console /dev/tty2: '/sbin/getty'
Feb  7 09:03:18 sensor daemon.info init: ^MStarting pid 386, console /dev/ttyS0: '/sbin/getty'
Feb  7 09:04:04 sensor daemon.notice ntpd[409]: ntpd 4.2.0@1.1161-r Mon Dec 15 18:07:30 UTC 2008 (1)
Feb  7 09:04:04 sensor daemon.debug ntpd[409]: signal_no_reset: signal 13 had flags 4000000
Feb  7 09:04:04 sensor daemon.info ntpd[409]: precision = 2.000 usec
Feb  7 09:04:04 sensor user.notice /etc/init.d/ntpd: ntpd startup
Feb  7 09:04:05 sensor daemon.err ntpd[409]: no IPv6 interfaces found
Feb  7 09:04:05 sensor daemon.info ntpd[409]: kernel time sync status 0040
Feb  7 09:04:05 sensor daemon.info ntpd[409]: frequency initialized 100.721 PPM from /etc/ntp/drift
Feb  7 09:04:05 sensor daemon.err ntpd[409]: configure: keyword "authenticate" unknown, line ignored
Feb  7 09:04:05 sensor daemon.notice ntpd[409]: ntpd exiting on signal 2
Feb  7 09:04:11 sensor daemon.notice ntpd[426]: ntpd 4.2.0@1.1161-r Mon Dec 15 18:07:30 UTC 2008 (1)
Feb  7 09:04:11 sensor daemon.debug ntpd[426]: signal_no_reset: signal 13 had flags 4000000
Feb  7 09:04:11 sensor user.notice /etc/init.d/ntpd: ntpd startup
Feb  7 09:04:11 sensor daemon.info ntpd[426]: precision = 2.000 usec
Feb  7 09:04:11 sensor daemon.err ntpd[426]: no IPv6 interfaces found
Feb  7 09:04:11 sensor daemon.info ntpd[426]: kernel time sync status 0040
Feb  7 09:04:11 sensor daemon.info ntpd[426]: frequency initialized 100.721 PPM from /etc/ntp/drift
Feb  7 09:04:11 sensor daemon.err ntpd[426]: configure: keyword "authenticate" unknown, line ignored
Feb  7 09:04:11 sensor user.debug platform[347]: error 19 opening lpc device
Feb  7 09:04:13 sensor user.debug platform[347]: error 19 opening lpc device
Feb  7 09:04:16 sensor user.debug platform[347]: error 19 opening lpc device
Feb  7 09:04:22 sensor auth.notice cid-auth(pam_unix)[347]: password changed for cids
Feb  7 09:07:25 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Feb  7 09:07:25 sensor daemon.notice ntpd[426]: kernel time sync disabled 0041
Feb  7 09:08:31 sensor daemon.notice ntpd[426]: kernel time sync enabled 0001
Feb  7 09:12:46 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Feb  9 17:04:03 sensor user.debug platform[27897]: error 19 opening lpc device
Feb 14 11:54:05 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Feb 14 12:11:10 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Feb 14 13:03:48 sensor user.debug platform[17213]: error 19 opening lpc device
Feb 16 01:03:48 sensor user.debug platform[19545]: error 19 opening lpc device
Feb 16 01:10:36 sensor auth.crit mainApp[451]: 16Feb2012 01:10:36.523 monitor[451] Syslog/F errSystemError threadStart catch(CIDS runtime exception) Failed to parse the default config info
Feb 21 14:48:40 sensor auth.err pam_tally[413]: pam_tally: pam_get_uid; no such user support
Feb 21 14:48:40 sensor auth.alert unix_chkpwd[26946]: check pass; user unknown
Feb 21 14:48:40 sensor auth.notice cid-auth(pam_unix)[413]: authentication failure; logname= uid=50 euid=50 tty= ruser= rhost=
Feb 23 15:03:44 sensor user.debug platform[30573]: error 19 opening lpc device
Feb 24 23:03:44 sensor user.debug platform[23412]: error 19 opening lpc device
Feb 28 21:21:38 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Feb 28 22:29:54 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Feb 28 22:48:13 sensor daemon.notice ntpd[426]: time reset -0.329883 s
Feb 28 22:52:34 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Feb 28 22:57:51 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Feb 28 23:18:30 sensor daemon.notice ntpd[426]: time reset +0.379397 s
Feb 28 23:22:50 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Feb 28 23:28:06 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Feb 28 23:45:28 sensor daemon.notice ntpd[426]: time reset +0.141550 s
Feb 28 23:49:46 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Feb 28 23:55:06 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Feb 29 00:12:16 sensor daemon.notice ntpd[426]: time reset -0.141978 s
Feb 29 00:16:30 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Feb 29 00:21:54 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Feb 29 13:03:53 sensor user.debug platform[29498]: error 19 opening lpc device
Mar  3 01:35:21 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar  3 01:52:27 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar  4 15:25:00 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar  4 15:42:05 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar  7 08:31:29 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar  7 09:05:36 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar  7 15:03:44 sensor user.debug platform[23079]: error 19 opening lpc device
Mar  7 21:52:12 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar  7 23:00:27 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar  8 09:56:38 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar  8 11:04:58 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar  9 05:25:46 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar  9 05:42:52 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar  9 22:23:25 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar  9 23:31:46 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 10 18:41:07 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 10 19:32:21 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 10 20:02:13 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 10 20:36:25 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 10 20:55:09 sensor daemon.notice ntpd[426]: time reset -0.154140 s
Mar 10 20:59:29 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 10 21:30:20 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 10 21:48:46 sensor daemon.notice ntpd[426]: time reset +0.415099 s
Mar 10 21:53:05 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 10 21:58:23 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 10 22:17:49 sensor daemon.notice ntpd[426]: time reset -0.297268 s
Mar 10 22:22:06 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 10 22:27:25 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 10 22:43:38 sensor daemon.notice ntpd[426]: time reset -0.183101 s
Mar 10 22:47:59 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 10 22:53:15 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 10 23:36:15 sensor daemon.notice ntpd[426]: time reset +0.350238 s
Mar 10 23:40:37 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 10 23:45:54 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 11 00:41:54 sensor daemon.notice ntpd[426]: time reset -0.350001 s
Mar 11 00:46:11 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 11 00:51:31 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 11 01:11:59 sensor daemon.notice ntpd[426]: time reset +0.167131 s
Mar 11 01:16:17 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 11 01:21:39 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 11 03:50:43 sensor daemon.notice ntpd[426]: time reset -0.162125 s
Mar 11 03:55:01 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 11 04:00:22 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 11 04:50:48 sensor daemon.notice ntpd[426]: time reset +0.132550 s
Mar 11 04:55:06 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 11 05:00:25 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 12 15:19:34 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 12 16:44:57 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 12 17:31:00 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 12 17:39:35 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 13 13:03:43 sensor user.debug platform[7457]: error 19 opening lpc device
Mar 13 22:44:33 sensor daemon.info ntpd[426]: synchronized to LOCAL(0), stratum=5
Mar 13 23:35:47 sensor daemon.info ntpd[426]: synchronized to 10.x.x.5, stratum=3
Mar 14 13:03:45 sensor user.debug platform[21021]: error 19 opening lpc device
Mar 15 07:59:56 sensor auth.err pam_tally[413]: pam_tally: pam_get_uid; no such user support
Mar 15 07:59:56 sensor auth.alert unix_chkpwd[27697]: check pass; user unknown
Mar 15 07:59:56 sensor auth.notice cid-auth(pam_unix)[413]: authentication failure; logname= uid=50 euid=50 tty= ruser= rhost=
Mar 15 09:42:33 sensor auth.info sshd[32127]: Accepted keyboard-interactive/pam for cisco from 10.x.x.69 port 4826 ssh2
Mar 15 09:42:33 sensor auth.info sshd(pam_unix)[32147]: session opened for user cisco by cisco(uid=0)
Mar 15 09:46:45 sensor user.warn kernel: MacUpdate
Mar 15 09:46:45 sensor user.warn kernel: RlmtUpdate
Mar 15 09:46:45 sensor user.warn kernel: SirqUpdate
Mar 15 09:46:45 sensor user.warn kernel: retrive values
Mar 15 09:46:45 sensor user.warn kernel: done
exec: cat /usr/cids/idsRoot/log/main.log
<<<<<<<<<<<<<<<<<<<<<<<<< Interprocess Logging Started >>>>>>>>>>>>>>>>>>>>>>>>>
17Oct2011 15:59:21.192 2.130 mainApp[345] IdsEventStore/W errWarning -- Event store open archive for input failed [IdsEventStore::Data::Data()]
-----Begin syslogReader----
17Oct2011 15:59:21.195 0.002 mainApp[345] IdsEventStore/W errWarning -- Event store set to default size [IdsEventStore::Data::Data()]
17Oct2011 15:59:21.212 0.016 mainApp[345] IdsEventStore/W errWarning Event store circular buffer may be in an invalid state, recovering ... [IdsEventStore::init()]
17Oct2011 16:00:10.716 49.504 mainApp[345] Cid/E errSystemError - ntpdate failed to set clock from NTP server after retrying for 45 seconds. Debug info:
Looking for host 10.x.x.5 and service ntp
17 Oct 11:00:06 ntpdate[401]: ntpdate 4.2.0@1.1161-r Mon Dec 15 18:07:31 UTC 2008 (1)
transmit(10.x.x.5)
transmit to 10.x.x.5
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit(10.x.x.5)
10.x.x.5: Server dropped: no data
server 10.x.x.5, port 123
stratum 0, precision 0, leap 00, trust 000
refid [10.x.x.5], delay 0.00000, dispersion 64.00000
transmitted 4, in filter 4
reference time:    00000000.00000000  Thu, Feb  7 2036  0:28:16.000
originate timestamp: 00000000.00000000  Thu, Feb  7 2036  0:28:16.000
transmit timestamp:  d246cf89.b5d25aab  Mon, Oct 17 2011 11:00:09.710
filter delay:  0.00000  0.00000  0.00000  0.00000
filter offset: 0.000000 0.000000 0.000000 0.000000
offset 0.000000
17Oct2011 16:00:59.886 49.170 mainApp[345] Cid/E errSystemError - ntpdate failed to set clock from NTP server after retrying for 45 seconds. Debug info:
17 Oct 11:00:55 ntpdate[435]: ntpdate 4.2.0@1.1161-r Mon Dec 15 18:07:31 UTC 2008 (1)
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit timestamp:  d246cfba.e158537e  Mon, Oct 17 2011 11:00:58.880
offset 0.000000
17Oct2011 16:01:04.531 0.000 logApp[448] Cid/W Disabled status event logging for status category: controlTransaction
17Oct2011 16:01:04.673 0.142 interface[345] Cid/E errSystemError - no matching interface descriptor found [PhysicalIntfcList::identifyInterface]
17Oct2011 16:01:05.136 0.463 interface[345] Cid/W Network interface GigabitEthernet0/0 has been added to the system
17Oct2011 16:01:05.137 0.001 interface[345] Cid/W Network interface Management0/0 has been added to the system
Begin syslogReader
17Oct2011 16:01:07.254 2.117 interface[450] Cid/W errWarning Inline data bypass has started.
17Oct2011 16:01:13.750 6.496 mainApp[345] watchdog/W Watchdog is enabled
17Oct2011 16:02:41.319 87.569 monitor[474] Monitor/W last update time=1318867287221914000
Messages, like this one, in the category - SensorApp status timed out - were logged 1 times in the last 0 seconds.
17Oct2011 11:03:48.188 68466.869 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
17Oct2011 11:11:39.539 471.351 sensorApp[509] Cid/W errWarning valueIgnored:cannot specify external-rate-limit-percentage for sig: 4004
17Oct2011 11:11:49.898 10.359 sensorApp[509] Cid/W errWarning invalidValue:Engine SMBAdvanced SigId 6946:0 Payload Source is ignored for MSRPC signatures on IPS hardware
17Oct2011 11:11:49.899 0.001 sensorApp[509] Cid/W errWarning invalidValue:Engine SMBAdvanced SigId 6946:0 Direction parameter ignored for MSRPC over SMB signature
17Oct2011 11:35:15.278 1405.379 sensorApp[509] sensorApp/W WARNING: Signature 1306.6 will continue to use the default settings and modify packets inline.
17Oct2011 11:35:15.278 0.000 sensorApp[509] sensorApp/W WARNING: Signature 1330.4 will continue to use the default settings and modify packets inline.
17Oct2011 11:35:15.278 0.000 sensorApp[509] sensorApp/W WARNING: Signature 1330.7 will continue to use the default settings and modify packets inline.
17Oct2011 11:35:15.278 0.000 sensorApp[509] sensorApp/W WARNING: Disabling, Removing deny packet, or Removing modify packet on Signature 1317.0 may cause Normalizer state issues and result in false positives.
17Oct2011 11:35:15.279 0.001 sensorApp[509] sensorApp/W WARNING: Signature 1330.19 will continue to use the default settings and modify packets inline.
17Oct2011 11:35:15.279 0.000 sensorApp[509] sensorApp/W WARNING: Signature 1330.20 will continue to use the default settings and modify packets inline.
17Oct2011 11:35:15.279 0.000 sensorApp[509] sensorApp/W WARNING: Signature 1330.21 will continue to use the default settings and modify packets inline.
17Oct2011 11:35:15.396 0.117 sensorApp[509] Cid/E errUnacceptableValue invalidValue:Anomaly Detection is not supported on this platform
17Oct2011 11:35:25.647 10.251 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
17Oct2011 16:35:25.707 18000.060 interface[450] Cid/W errWarning Inline data bypass has stopped.
17Oct2011 17:03:33.586 1687.879 mainApp[346] Cid/E errSystemError No installable auto update package found on server
17Oct2011 19:03:33.063 7199.477 mainApp[346] Cid/E errSystemError No installable auto update package found on server
17Oct2011 21:03:30.656 7197.593 mainApp[346] Cid/E errSystemError No installable auto update package found on server
17Oct2011 23:03:29.547 7198.891 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 01:03:31.390 7201.843 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 03:03:30.690 7199.300 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 05:03:31.029 7200.339 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 07:03:28.466 7197.437 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 09:03:30.327 7201.861 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 11:03:28.621 7198.294 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 13:03:30.890 7202.269 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 15:03:32.192 7201.302 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 17:03:30.524 7198.332 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 19:03:32.388 7201.864 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 21:03:30.156 7197.768 mainApp[346] Cid/E errSystemError No installable auto update package found on server
18Oct2011 23:03:28.621 7198.465 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 01:03:28.972 7200.351 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 03:03:29.099 7200.127 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 05:03:30.114 7201.015 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 07:03:29.999 7199.885 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 09:03:30.173 7200.174 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 11:03:29.966 7199.793 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 13:03:31.578 7201.612 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 15:03:30.988 7199.410 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 16:11:33.808 4082.820 interface[411] Cid/W errWarning Inline data bypass has started.
19Oct2011 11:11:53.577 68419.769 sensorApp[3352] sensorApp/W errWarning Bypass Mode no longer ON, resuming packet inspection.
19Oct2011 16:11:53.582 18000.005 interface[450] Cid/W errWarning Inline data bypass has stopped.
19Oct2011 16:18:44.909 411.327 interface[411] Cid/W errWarning Inline data bypass has started.
19Oct2011 11:18:55.860 68410.951 sensorApp[3352] sensorApp/W errWarning Bypass Mode no longer ON, resuming packet inspection.
19Oct2011 16:18:55.869 18000.009 interface[450] Cid/W errWarning Inline data bypass has stopped.
19Oct2011 17:11:20.997 3145.128 interface[450] Cid/W errWarning Inline data bypass has started.
19Oct2011 17:12:30.743 69.746 monitor[474] Monitor/W last update time=1319044279988365000
Messages, like this one, in the category - SensorApp status timed out - were logged 89 times in the last 176989 seconds.
19Oct2011 12:13:27.339 68456.596 sensorApp[527] Cid/W AnalysisEngine reconfiguration starting.
19Oct2011 12:18:27.728 300.389 sensorApp[3352] sensorApp/W DBMemoryResourcesCritical 1 Hits 1 Total.
Messages, like this one, in the category - DBMemoryResourcesCritical - were logged 1 times in the last 0 seconds.
19Oct2011 17:18:27.741 18000.013 interface[450] Cid/W errWarning Inline data bypass has stopped.
19Oct2011 12:18:27.774 68400.033 sensorApp[527] Cid/W AnalysisEngine reconfiguration complete.
19Oct2011 12:18:27.777 0.003 sensorApp[527] sensorApp/W Arena Excess growth of 24511140 detected at exit of CT editDefaultConfigSignatureDefinition.
19Oct2011 19:03:30.911 24303.134 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 21:03:29.667 7198.756 mainApp[346] Cid/E errSystemError No installable auto update package found on server
19Oct2011 23:03:29.043 7199.376 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 01:03:29.808 7200.765 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 03:03:29.821 7200.013 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 05:03:29.622 7199.801 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 07:03:30.020 7200.398 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 09:03:30.585 7200.565 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 11:03:30.743 7200.158 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 13:03:30.134 7199.391 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 15:03:32.237 7202.103 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 15:51:10.755 2858.518 interface[411] Cid/W errWarning Inline data bypass has started.
20Oct2011 10:51:19.259 68408.504 sensorApp[3352] sensorApp/W errWarning Bypass Mode no longer ON, resuming packet inspection.
20Oct2011 15:51:19.270 18000.011 interface[450] Cid/W errWarning Inline data bypass has stopped.
20Oct2011 17:03:31.994 4332.724 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 17:09:32.048 360.054 interface[411] Cid/W errWarning Inline data bypass has started.
20Oct2011 12:09:44.165 68412.117 sensorApp[3352] sensorApp/W errWarning Bypass Mode no longer ON, resuming packet inspection.
20Oct2011 17:09:44.171 18000.006 interface[450] Cid/W errWarning Inline data bypass has stopped.
20Oct2011 17:50:09.145 2424.974 interface[411] Cid/W errWarning Inline data bypass has started.
20Oct2011 12:50:45.103 68435.958 sensorApp[3352] sensorApp/W errWarning Bypass Mode no longer ON, resuming packet inspection.
20Oct2011 17:50:45.114 18000.011 interface[450] Cid/W errWarning Inline data bypass has stopped.
20Oct2011 19:03:33.819 4368.705 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 20:21:20.235 4666.416 cidwebserver[468] tls/W errTransport while sending a TLS warning alert close_notify, the following error occurred: socket error [3,32]
Messages, like this one, in the category - TLS socket failure - were logged 1 times in the last 0 seconds.
20Oct2011 21:03:33.423 2533.188 mainApp[346] Cid/E errSystemError No installable auto update package found on server
20Oct2011 23:03:31.237 7197.814 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 01:03:29.911 7198.674 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 03:03:29.921 7200.010 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 05:03:31.576 7201.655 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 07:03:30.924 7199.348 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 09:03:29.977 7199.053 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 11:03:29.341 7199.364 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 13:03:30.160 7200.819 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 15:03:38.105 7207.945 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 17:03:30.540 7192.435 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 19:03:31.782 7201.242 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 21:03:31.082 7199.300 mainApp[346] Cid/E errSystemError No installable auto update package found on server
21Oct2011 23:03:30.957 7199.875 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 01:03:29.818 7198.861 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 03:03:30.821 7201.003 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 05:03:31.444 7200.623 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 07:03:31.287 7199.843 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 09:03:30.941 7199.654 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 11:03:31.091 7200.150 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 13:03:30.702 7199.611 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 15:03:30.890 7200.188 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 17:03:31.017 7200.127 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 19:03:28.960 7197.943 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 21:03:31.195 7202.235 mainApp[346] Cid/E errSystemError No installable auto update package found on server
22Oct2011 23:03:30.453 7199.258 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 01:03:31.072 7200.619 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 03:03:29.609 7198.537 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 05:03:30.910 7201.301 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 07:03:29.493 7198.583 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 09:03:30.640 7201.147 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 11:03:30.869 7200.229 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 13:03:29.350 7198.481 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 15:03:29.492 7200.142 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 17:03:30.771 7201.279 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 19:03:30.315 7199.544 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 21:03:29.441 7199.126 mainApp[346] Cid/E errSystemError No installable auto update package found on server
23Oct2011 23:03:30.170 7200.729 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 01:03:30.549 7200.379 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 03:03:31.160 7200.611 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 05:03:29.271 7198.111 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 07:03:28.708 7199.437 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 09:03:31.363 7202.655 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 11:03:30.268 7198.905 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 13:03:29.160 7198.892 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 15:03:32.265 7203.105 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 17:03:31.236 7198.971 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 19:03:31.308 7200.072 mainApp[346] Cid/E errSystemError No installable auto update package found on server
24Oct2011 21:10:27.502 7616.194 interface[450] Cid/W errWarning Inline data bypass has started.
24Oct2011 21:11:30.438 62.936 monitor[474] Monitor/W last update time=1319490626460142000
Messages, like this one, in the category - SensorApp status timed out - were logged 8 times in the last 446339 seconds.
24Oct2011 16:12:27.388 68456.950 sensorApp[527] Cid/W AnalysisEngine reconfiguration starting.
24Oct2011 21:13:02.839 0.000 monitor[474] Syslog/F errSystemError threadStart catch(CIDS runtime exception) Failed to parse the default config info
24Oct2011 16:14:47.746 140.358 sensorApp[3352] sensorApp/W DBMemoryResourcesCritical 1 Hits 1 Total.
Messages, like this one, in the category - DBMemoryResourcesCritical - were logged 2 times in the last 446180 seconds.
24Oct2011 16:14:47.755 0.009 sensorApp[527] Cid/W AnalysisEngine reconfiguration complete.
24Oct2011 16:14:47.760 0.005 sensorApp[527] sensorApp/W Arena Excess growth of 4194304 detected at exit of CT editDefaultConfigSignatureDefinition.
24Oct2011 21:14:47.763 18000.003 interface[450] Cid/W errWarning Inline data bypass has stopped.
24Oct2011 23:03:29.560 6521.797 mainApp[346] Cid/E errSystemError No installable auto update package found on server
25Oct2011 01:03:28.400 7198.840 mainApp[346] Cid/E errSystemError No installable auto update package found on server
25Oct2011 03:03:28.869 7200.469 mainApp[346] Cid/E errSystemError No installable auto update package found on server
25Oct2011 05:03:28.677 7199.808 mainApp[346] Cid/E errSystemError No installable auto update package found on server
25Oct2011 07:03:28.840 7200.163 mainApp[346] Cid/E errSystemError No installable auto update package found on server
25Oct2011 09:03:28.489 7199.649 mainApp[346] Cid/E errSystemError No installable auto update package found on server
25Oct2011 11:03:28.305 7199.816 mainApp[346] Cid/E errSystemError No installable auto update package found on server
25Oct2011 12:50:39.782 6431.477 mainApp[412] cplane/E Error - accept() call returned -1
25Oct2011 12:50:39.815 0.033 mainApp[345] Cid/W errWarning - MainApp is exiting; reboot requested by user
25Oct2011 12:50:39.846 0.031 interface[450] Cid/W errWarning Inline data bypass has started.
25Oct2011 12:50:54.835 14.989 mainApp[345] Cid/E errSystemError AppManager::ApplicationEntry::stop - Could not stop application "AnalysisEngine" within 15 second timeout
25Oct2011 12:50:54.835 0.000 mainApp[345] Cid/E errSystemError MainApplication::run - One or more applications failed to terminate normally.
25Oct2011 07:53:46.216 51.558 mainApp[347] Cid/E errSystemError - ntpdate failed to set clock from NTP server after retrying for 45 seconds. Debug info:
25 Oct 07:53:42 ntpdate[403]: ntpdate 4.2.0@1.1161-r Mon Dec 15 18:07:31 UTC 2008 (1)
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit timestamp:  d2512fd9.35d2bf55  Tue, Oct 25 2011  7:53:45.210
offset 0.000000
25Oct2011 07:53:56.888 0.000 logApp[433] Cid/W Disabled status event logging for status category: controlTransaction
25Oct2011 07:53:57.059 0.171 interface[347] Cid/E errSystemError - no matching interface descriptor found [PhysicalIntfcList::identifyInterface]
Begin syslogReader
25Oct2011 07:54:00.101 3.042 interface[435] Cid/W errWarning Inline data bypass has started.
25Oct2011 07:54:04.943 4.842 mainApp[347] watchdog/W Watchdog is enabled
25Oct2011 07:55:32.573 87.630 monitor[451] Monitor/W last update time=1319547258643141000
25Oct2011 07:57:33.409 120.836 sensorApp[489] Cid/W AnalysisEngine reconfiguration starting.
25Oct2011 07:57:35.468 2.059 sensorApp[489] Cid/W errWarning valueIgnored:cannot specify external-rate-limit-percentage for sig: 4004
25Oct2011 07:57:43.309 7.841 sensorApp[489] Cid/W errWarning invalidValue:Engine SMBAdvanced SigId 6946:0 Payload Source is ignored for MSRPC signatures on IPS hardware
25Oct2011 07:57:43.310 0.001 sensorApp[489] Cid/W errWarning invalidValue:Engine SMBAdvanced SigId 6946:0 Direction parameter ignored for MSRPC over SMB signature
25Oct2011 07:59:36.917 113.607 sensorApp[489] sensorApp/W WARNING: Signature 1306.6 will continue to use the default settings and modify packets inline.
25Oct2011 07:59:36.917 0.000 sensorApp[489] sensorApp/W WARNING: Signature 1330.4 will continue to use the default settings and modify packets inline.
25Oct2011 07:59:36.918 0.001 sensorApp[489] sensorApp/W WARNING: Signature 1330.7 will continue to use the default settings and modify packets inline.
25Oct2011 07:59:36.918 0.000 sensorApp[489] sensorApp/W WARNING: Disabling, Removing deny packet, or Removing modify packet on Signature 1317.0 may cause Normalizer state issues and result in false positives.
25Oct2011 07:59:36.918 0.000 sensorApp[489] sensorApp/W WARNING: Signature 1330.19 will continue to use the default settings and modify packets inline.
25Oct2011 07:59:36.918 0.000 sensorApp[489] sensorApp/W WARNING: Signature 1330.20 will continue to use the default settings and modify packets inline.
25Oct2011 07:59:36.918 0.000 sensorApp[489] sensorApp/W WARNING: Signature 1330.21 will continue to use the default settings and modify packets inline.
25Oct2011 07:59:37.054 0.136 sensorApp[489] Cid/E errUnacceptableValue invalidValue:Anomaly Detection is not supported on this platform
25Oct2011 07:59:47.309 10.255 sensorApp[489] Cid/W AnalysisEngine reconfiguration complete.
25Oct2011 07:59:47.370 0.061 interface[435] Cid/W errWarning Inline data bypass has stopped.
25Oct2011 09:03:31.594 3824.224 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Oct2011 11:03:29.924 7198.330 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Oct2011 13:03:30.425 7200.501 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Oct2011 15:03:31.003 7200.578 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Oct2011 17:03:30.358 7199.355 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Oct2011 19:03:30.448 7200.090 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Oct2011 21:03:31.371 7200.923 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Oct2011 23:03:28.916 7197.545 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 01:03:31.517 7202.601 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 03:03:31.156 7199.639 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 05:03:30.214 7199.058 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 07:03:29.320 7199.106 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 09:03:29.813 7200.493 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 11:03:33.065 7203.252 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 13:03:50.433 7217.368 interface[435] Cid/W errWarning Inline data bypass has started.
26Oct2011 13:03:50.436 0.003 interface[435] Cid/W errWarning Inline data bypass has stopped.
26Oct2011 13:08:48.184 297.748 interface[435] Cid/W errWarning Inline data bypass has started.
26Oct2011 13:09:59.388 71.204 monitor[451] Monitor/W last update time=1319652527181962000
Messages, like this one, in the category - SensorApp status timed out - were logged 5 times in the last 105266 seconds.
26Oct2011 13:10:44.497 45.109 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
26Oct2011 13:18:22.105 457.608 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
26Oct2011 13:18:22.110 0.005 interface[435] Cid/W errWarning Inline data bypass has stopped.
26Oct2011 15:03:31.360 6309.250 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 17:03:28.573 7197.213 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 19:03:30.979 7202.406 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 21:03:31.672 7200.693 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Oct2011 23:03:31.666 7199.994 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 01:03:29.832 7198.166 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 03:03:29.983 7200.151 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 05:03:31.269 7201.286 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 07:03:28.810 7197.541 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 09:03:30.187 7201.377 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 11:03:31.155 7200.968 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 13:03:32.717 7201.562 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 15:03:30.427 7197.710 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 17:03:30.560 7200.133 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 19:03:29.366 7198.806 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 21:03:34.726 7205.360 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Oct2011 23:03:31.078 7196.352 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 01:03:30.412 7199.334 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 03:03:31.112 7200.700 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 05:03:30.477 7199.365 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 07:03:31.129 7200.652 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 09:03:32.310 7201.181 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 11:03:33.083 7200.773 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 13:03:31.168 7198.085 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 15:03:28.896 7197.728 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 17:03:29.846 7200.950 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 19:03:30.987 7201.141 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 21:03:30.640 7199.653 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Oct2011 23:03:31.083 7200.443 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 01:03:30.212 7199.129 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 03:03:30.864 7200.652 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 05:03:30.180 7199.316 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 07:03:28.710 7198.530 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 09:03:29.367 7200.657 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 11:03:30.825 7201.458 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 13:03:29.077 7198.252 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 15:03:28.744 7199.667 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 17:03:29.915 7201.171 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 19:03:32.070 7202.155 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 21:03:28.703 7196.633 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Oct2011 23:03:30.453 7201.750 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 01:03:30.752 7200.299 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 03:03:30.438 7199.686 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 05:03:29.548 7199.110 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 07:03:30.093 7200.545 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 09:03:30.788 7200.695 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 11:03:29.150 7198.362 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 13:03:30.853 7201.703 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 15:03:31.231 7200.378 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 17:03:20.832 7189.601 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
30Oct2011 19:03:31.128 7210.296 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 21:03:31.125 7199.997 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Oct2011 23:03:39.266 7208.141 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 01:03:28.780 7189.514 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 03:03:29.382 7200.602 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 05:03:30.697 7201.315 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 07:03:31.760 7201.063 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 09:03:28.813 7197.053 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 11:03:31.791 7202.978 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 13:03:31.803 7200.012 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 15:03:31.674 7199.871 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 17:03:28.926 7197.252 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 19:03:32.242 7203.316 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 21:03:30.637 7198.395 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Oct2011 23:03:29.860 7199.223 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 01:03:31.290 7201.430 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 03:03:29.293 7198.003 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 05:03:31.052 7201.759 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 07:03:31.311 7200.259 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 09:03:32.185 7200.874 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 11:03:33.739 7201.554 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 13:03:31.922 7198.183 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 15:03:31.986 7200.064 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 17:03:31.724 7199.738 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 19:03:29.564 7197.840 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 21:03:29.704 7200.140 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Nov2011 23:03:29.721 7200.017 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 01:03:31.752 7202.031 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 03:03:31.066 7199.314 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 05:03:29.454 7198.388 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 07:03:31.473 7202.019 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 09:03:30.343 7198.870 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 11:03:33.953 7203.610 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 13:09:28.825 7554.872 interface[435] Cid/W errWarning Inline data bypass has started.
02Nov2011 13:10:33.550 64.725 monitor[451] Monitor/W last update time=1320257367794130000
Messages, like this one, in the category - SensorApp status timed out - were logged 10 times in the last 604834 seconds.
02Nov2011 13:11:30.520 56.970 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
02Nov2011 13:15:06.599 216.079 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
02Nov2011 13:15:06.606 0.007 interface[435] Cid/W errWarning Inline data bypass has stopped.
02Nov2011 15:03:35.040 6508.434 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 17:03:29.433 7194.393 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 19:03:30.346 7200.913 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 21:03:28.586 7198.240 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Nov2011 23:03:31.540 7202.954 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 01:03:30.882 7199.342 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 03:03:29.961 7199.079 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 05:03:31.760 7201.799 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 07:03:30.029 7198.269 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 09:03:33.178 7203.149 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 11:03:31.817 7198.639 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 13:08:27.474 7495.657 interface[435] Cid/W errWarning Inline data bypass has started.
03Nov2011 13:09:33.904 66.430 monitor[451] Monitor/W last update time=1320343706480674000
Messages, like this one, in the category - SensorApp status timed out - were logged 7 times in the last 86340 seconds.
03Nov2011 13:10:24.299 50.395 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
03Nov2011 13:13:09.569 165.270 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
03Nov2011 13:13:09.576 0.007 interface[435] Cid/W errWarning Inline data bypass has stopped.
03Nov2011 15:03:31.646 6622.070 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 17:03:31.662 7200.016 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 19:03:31.772 7200.110 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 21:03:31.590 7199.818 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Nov2011 23:03:30.986 7199.396 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 01:03:31.351 7200.365 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 03:03:21.251 7189.900 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
04Nov2011 05:03:29.531 7208.280 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 07:03:31.388 7201.857 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 09:03:32.948 7201.560 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 11:03:35.518 7202.570 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 13:03:34.320 7198.802 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 15:03:29.388 7195.068 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 17:03:29.409 7200.021 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 19:03:30.695 7201.286 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 21:03:31.345 7200.650 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Nov2011 23:03:31.187 7199.842 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 01:03:30.881 7199.694 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 03:03:32.022 7201.141 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 05:03:28.617 7196.595 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 07:03:33.492 7204.875 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 09:03:29.967 7196.475 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 11:03:30.198 7200.231 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 13:03:30.597 7200.399 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 15:03:30.002 7199.405 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 17:03:30.886 7200.884 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 19:03:31.604 7200.718 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 21:03:30.765 7199.161 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Nov2011 23:03:29.339 7198.574 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 01:03:30.697 7201.358 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 02:03:28.941 3598.244 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 03:03:31.409 3602.468 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 05:03:29.586 7198.177 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 07:03:31.123 7201.537 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 09:03:31.278 7200.155 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 11:03:28.796 7197.518 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 13:03:30.329 7201.533 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 15:03:32.310 7201.981 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 17:03:34.400 7202.090 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 19:03:31.764 7197.364 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 21:03:32.047 7200.283 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Nov2011 23:03:39.866 7207.819 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 01:03:31.228 7191.362 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 03:03:31.405 7200.177 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 05:03:31.570 7200.165 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 07:03:30.948 7199.378 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 09:03:32.730 7201.782 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 11:03:30.181 7197.451 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 13:03:32.651 7202.470 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 15:03:32.587 7199.936 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 17:03:31.289 7198.702 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 19:03:30.998 7199.709 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 21:03:31.810 7200.812 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Nov2011 23:03:31.216 7199.406 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 01:03:29.607 7198.391 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 03:03:30.986 7201.379 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 05:03:32.057 7201.071 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 07:03:30.070 7198.013 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 09:03:31.488 7201.418 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 11:03:33.272 7201.784 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 13:08:36.491 7503.219 interface[435] Cid/W errWarning Inline data bypass has started.
08Nov2011 13:09:46.919 70.428 monitor[451] Monitor/W last update time=1320779315478163000
Messages, like this one, in the category - SensorApp status timed out - were logged 6 times in the last 435613 seconds.
08Nov2011 13:10:33.062 46.143 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
08Nov2011 13:14:53.042 259.980 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
08Nov2011 13:14:53.050 0.008 interface[435] Cid/W errWarning Inline data bypass has stopped.
08Nov2011 15:03:31.797 6518.747 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 17:03:31.273 7199.476 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 19:03:29.796 7198.523 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 21:03:33.442 7203.646 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Nov2011 23:03:28.764 7195.322 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 01:03:34.211 7205.447 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 03:03:30.011 7195.800 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 05:03:30.554 7200.543 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 07:03:28.112 7197.558 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 09:03:29.489 7201.377 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 11:03:30.979 7201.490 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 13:03:32.161 7201.182 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 15:03:29.306 7197.145 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 17:03:31.562 7202.256 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 19:03:32.165 7200.603 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 21:03:29.351 7197.186 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Nov2011 23:03:31.621 7202.270 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 01:03:31.215 7199.594 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 03:03:30.630 7199.415 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 05:03:31.425 7200.795 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 07:03:30.547 7199.122 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 09:03:32.971 7202.424 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 11:03:40.216 7207.245 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 13:03:35.039 7194.823 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 15:03:30.445 7195.406 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 17:03:30.349 7199.904 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 19:03:30.945 7200.596 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 21:03:31.613 7200.668 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Nov2011 23:03:31.104 7199.491 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 01:03:31.265 7200.161 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 03:03:30.764 7199.499 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 05:03:31.271 7200.507 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 07:03:31.966 7200.695 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 09:03:32.705 7200.739 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 11:03:35.903 7203.198 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 13:03:31.522 7195.619 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 15:03:28.945 7197.423 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 17:03:31.537 7202.592 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 19:03:31.276 7199.739 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 21:03:28.973 7197.697 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Nov2011 23:03:30.233 7201.260 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 01:03:30.873 7200.640 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 03:03:31.183 7200.310 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 05:03:31.281 7200.098 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 07:03:34.526 7203.245 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 09:03:30.455 7195.929 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 11:03:31.646 7201.191 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 13:03:31.771 7200.125 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 15:03:31.436 7199.665 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 17:03:31.133 7199.697 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 19:03:30.737 7199.604 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 21:03:31.028 7200.291 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Nov2011 23:03:29.634 7198.606 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 01:03:29.292 7199.658 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 03:03:29.442 7200.150 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 05:03:31.593 7202.151 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 07:03:31.366 7199.773 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 09:03:30.968 7199.602 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 11:03:31.582 7200.614 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 13:03:31.166 7199.584 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 15:03:30.758 7199.592 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 17:03:31.326 7200.568 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 19:03:30.961 7199.635 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 21:03:45.167 7214.206 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Nov2011 23:03:38.247 7193.080 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 01:03:30.175 7191.928 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 03:03:30.565 7200.390 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 05:03:30.041 7199.476 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 07:03:30.192 7200.151 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 09:03:32.108 7201.916 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 11:03:30.775 7198.667 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 13:03:31.112 7200.337 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 15:03:30.894 7199.782 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 17:03:31.430 7200.536 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 19:03:30.714 7199.284 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 21:03:32.130 7201.416 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Nov2011 23:03:30.670 7198.540 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 01:03:31.179 7200.509 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 03:03:31.121 7199.942 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 05:03:28.800 7197.679 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 07:03:29.974 7201.174 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 09:03:31.579 7201.605 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 11:03:31.845 7200.266 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 13:03:32.729 7200.884 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 15:03:29.630 7196.901 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 17:03:30.380 7200.750 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 19:03:30.175 7199.795 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 21:03:30.843 7200.668 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Nov2011 23:03:30.285 7199.442 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 01:03:30.308 7200.023 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 03:03:29.222 7198.914 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 05:03:30.340 7201.118 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 07:03:30.809 7200.469 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 09:03:31.607 7200.798 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 11:03:32.453 7200.846 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 13:03:35.041 7202.588 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 15:03:32.434 7197.393 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 17:03:31.091 7198.657 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 19:03:30.141 7199.050 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 21:03:30.776 7200.635 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Nov2011 23:03:31.273 7200.497 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 01:03:31.117 7199.844 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 03:03:30.685 7199.568 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 05:03:31.281 7200.596 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 07:03:32.488 7201.207 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 09:03:29.825 7197.337 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 11:03:31.591 7201.766 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 13:08:07.581 7475.990 interface[435] Cid/W errWarning Inline data bypass has started.
17Nov2011 13:09:07.668 60.087 monitor[451] Monitor/W last update time=1321556886581361000
Messages, like this one, in the category - SensorApp status timed out - were logged 9 times in the last 777560 seconds.
17Nov2011 13:10:10.643 62.975 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
17Nov2011 13:30:29.644 1219.001 sensorApp[955] sensorApp/W DBMemoryResourcesCritical 1 Hits 1 Total.
17Nov2011 13:30:29.654 0.010 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
17Nov2011 13:30:29.658 0.004 sensorApp[509] sensorApp/W Arena Excess growth of 16122532 detected at exit of CT editDefaultConfigSignatureDefinition.
17Nov2011 13:30:29.662 0.004 interface[435] Cid/W errWarning Inline data bypass has stopped.
17Nov2011 15:03:30.392 5580.730 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 17:03:31.353 7200.961 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 19:03:30.724 7199.371 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 21:03:29.212 7198.488 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Nov2011 23:03:31.235 7202.023 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 01:03:28.177 7196.942 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 03:03:28.920 7200.743 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 05:03:31.136 7202.216 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 07:03:29.182 7198.046 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 09:03:39.389 7210.207 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 11:03:34.360 7194.971 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 13:03:31.717 7197.357 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 15:03:32.713 7200.996 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 17:03:28.944 7196.231 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 19:03:30.142 7201.198 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 21:03:31.087 7200.945 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Nov2011 23:03:30.371 7199.284 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 01:03:30.949 7200.578 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 03:03:30.289 7199.340 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 05:03:30.856 7200.567 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 07:03:29.274 7198.418 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 09:03:30.495 7201.221 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 11:03:29.422 7198.927 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 13:03:28.511 7199.089 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 15:03:30.883 7202.372 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 17:03:31.375 7200.492 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 19:03:30.127 7198.752 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 21:03:30.384 7200.257 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Nov2011 23:03:28.950 7198.566 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 01:03:32.079 7203.129 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 03:03:28.296 7196.217 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 05:03:30.513 7202.217 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 07:03:30.267 7199.754 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 09:03:30.512 7200.245 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 11:03:29.908 7199.396 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 13:03:31.100 7201.192 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 15:03:30.923 7199.823 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 17:03:32.288 7201.365 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 19:03:31.290 7199.002 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 21:03:29.336 7198.046 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Nov2011 23:03:40.924 7211.588 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 01:03:31.134 7190.210 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 03:03:28.842 7197.708 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 05:03:31.256 7202.414 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 07:03:28.593 7197.337 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 09:03:31.828 7203.235 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 11:03:31.093 7199.265 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 13:03:32.270 7201.177 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 15:03:29.402 7197.132 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 17:03:28.984 7199.582 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 19:03:30.298 7201.314 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 21:03:30.672 7200.374 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Nov2011 23:03:30.985 7200.313 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 01:03:31.293 7200.308 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 03:03:30.948 7199.655 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 05:03:31.847 7200.899 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 07:03:29.941 7198.094 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 09:03:31.309 7201.368 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 11:03:33.766 7202.457 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 13:03:31.169 7197.403 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 15:03:29.596 7198.427 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 17:03:29.580 7199.984 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 19:03:31.207 7201.627 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 21:03:29.071 7197.864 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Nov2011 23:03:29.436 7200.365 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 01:03:29.390 7199.954 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 03:03:31.075 7201.685 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 05:03:29.754 7198.679 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 07:03:27.655 7197.901 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 09:03:31.956 7204.301 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 11:03:37.330 7205.374 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 13:03:33.268 7195.938 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 15:03:33.867 7200.599 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 17:03:31.606 7197.739 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 19:03:31.057 7199.451 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 21:03:30.995 7199.938 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Nov2011 23:03:29.508 7198.513 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 01:03:30.159 7200.651 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 03:03:28.467 7198.308 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 05:03:31.687 7203.220 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 07:03:30.002 7198.315 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 09:03:30.572 7200.570 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 11:03:31.369 7200.797 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 13:03:28.961 7197.592 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 15:03:31.537 7202.576 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 17:03:31.932 7200.395 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 19:03:31.958 7200.026 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 21:03:31.609 7199.651 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Nov2011 23:03:29.380 7197.771 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 01:03:30.935 7201.555 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 03:03:31.985 7201.050 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 05:03:31.020 7199.035 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 07:03:30.708 7199.688 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 09:03:30.297 7199.589 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 11:03:30.957 7200.660 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 13:03:31.625 7200.668 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 15:03:31.263 7199.638 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 17:03:30.383 7199.120 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 19:03:29.471 7199.088 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 21:03:29.554 7200.083 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Nov2011 23:03:31.369 7201.815 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 01:03:30.481 7199.112 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 03:03:29.193 7198.712 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 05:03:29.254 7200.061 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 07:03:28.655 7199.401 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 09:03:31.281 7202.626 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 11:03:30.895 7199.614 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 13:03:30.299 7199.404 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 15:03:30.286 7199.987 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 17:03:31.323 7201.037 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 19:03:30.988 7199.665 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 21:03:31.284 7200.296 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Nov2011 23:03:30.220 7198.936 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 01:03:31.279 7201.059 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 03:03:30.548 7199.269 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 05:03:29.705 7199.157 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 07:03:29.902 7200.197 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 09:03:31.476 7201.574 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 11:03:29.407 7197.931 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 13:03:31.405 7201.998 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 15:03:31.178 7199.773 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 17:03:30.760 7199.582 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 19:03:32.399 7201.639 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 21:03:31.172 7198.773 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Nov2011 23:03:39.209 7208.037 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 01:03:31.184 7191.975 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 03:03:30.361 7199.177 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 05:03:29.260 7198.899 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 07:03:29.660 7200.400 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 09:03:32.513 7202.853 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 11:03:32.757 7200.244 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 13:03:33.015 7200.258 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 15:03:31.984 7198.969 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 17:03:32.295 7200.311 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 19:08:15.095 7482.800 interface[435] Cid/W errWarning Inline data bypass has started.
28Nov2011 19:09:23.990 68.895 monitor[451] Monitor/W last update time=1322528894081773000
Messages, like this one, in the category - SensorApp status timed out - were logged 70 times in the last 972016 seconds.
28Nov2011 19:10:11.171 47.181 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
28Nov2011 19:14:06.556 235.385 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
28Nov2011 19:14:06.568 0.012 interface[435] Cid/W errWarning Inline data bypass has stopped.
28Nov2011 21:03:30.912 6564.344 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Nov2011 23:03:32.115 7201.203 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 01:03:28.919 7196.804 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 03:03:31.165 7202.246 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 05:03:29.362 7198.197 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 07:03:30.611 7201.249 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 09:03:31.267 7200.656 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 11:03:30.007 7198.740 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 13:03:31.551 7201.544 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 15:03:35.644 7204.093 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 17:03:31.308 7195.664 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 19:03:31.372 7200.064 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 21:03:31.069 7199.697 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Nov2011 23:03:29.019 7197.950 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 01:03:31.085 7202.066 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 03:03:31.914 7200.829 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 05:03:31.545 7199.631 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 07:02:13.987 7122.442 sensorApp[955] IdsEventStore/W errWarning - the event store wrapped around [IdsEventStore::writeEvent(), index = 19531]
30Nov2011 07:03:30.605 76.618 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 09:03:31.360 7200.755 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 11:03:32.440 7201.080 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 13:03:31.024 7198.584 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 15:03:29.827 7198.803 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 17:03:31.338 7201.511 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 19:03:31.019 7199.681 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 21:03:30.220 7199.201 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Nov2011 23:03:31.021 7200.801 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 01:03:29.483 7198.462 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 03:03:29.143 7199.660 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 05:03:29.866 7200.723 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 07:03:30.383 7200.517 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 09:03:30.074 7199.691 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 11:03:41.363 7211.289 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 13:03:29.558 7188.195 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 15:03:30.646 7201.088 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 17:03:30.251 7199.605 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 19:03:30.976 7200.725 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 21:03:30.178 7199.202 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Dec2011 23:03:30.857 7200.679 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 01:03:30.767 7199.910 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 03:03:29.956 7199.189 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 05:03:29.823 7199.867 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 07:03:28.638 7198.815 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 09:03:30.486 7201.848 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 11:03:33.610 7203.124 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 13:03:32.494 7198.884 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 15:03:31.605 7199.111 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 17:03:32.087 7200.482 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 19:03:30.732 7198.645 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 21:03:31.225 7200.493 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Dec2011 23:03:52.142 7220.917 mainApp[348] Cid/E errSystemError AutoUpdate exception: Receive HTTP response failed [3,212]
03Dec2011 01:03:52.063 7199.921 mainApp[348] Cid/E errSystemError AutoUpdate exception: Receive HTTP response failed [3,212]
03Dec2011 03:03:51.970 7199.907 mainApp[348] Cid/E errSystemError AutoUpdate exception: Receive HTTP response failed [3,212]
03Dec2011 05:03:31.720 7179.750 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Dec2011 07:03:30.036 7198.316 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Dec2011 09:03:29.848 7199.812 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Dec2011 11:03:31.922 7202.074 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Dec2011 13:03:31.928 7200.006 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Dec2011 15:03:30.885 7198.957 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Dec2011 17:03:29.656 7198.771 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Dec2011 19:03:31.397 7201.741 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Dec2011 21:03:29.243 7197.846 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Dec2011 23:03:31.284 7202.041 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 01:03:29.466 7198.182 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 03:03:31.157 7201.691 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 05:03:31.485 7200.328 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 07:03:29.936 7198.451 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 09:03:30.682 7200.746 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 11:03:32.129 7201.447 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 13:03:30.789 7198.660 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 15:03:30.215 7199.426 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 17:03:32.656 7202.441 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 19:03:31.398 7198.742 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 21:03:30.057 7198.659 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Dec2011 23:03:41.119 7211.062 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 01:03:30.673 7189.554 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 03:03:31.684 7201.011 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 05:03:31.311 7199.627 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 07:03:30.397 7199.086 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 09:03:31.826 7201.429 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 11:03:32.693 7200.867 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 13:03:31.529 7198.836 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 15:03:30.558 7199.029 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 17:03:32.178 7201.620 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 19:03:30.134 7197.956 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 21:03:30.836 7200.702 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Dec2011 23:03:31.531 7200.695 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 01:03:29.379 7197.848 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 03:03:30.729 7201.350 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 05:03:31.858 7201.129 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 07:03:28.551 7196.693 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 09:03:35.216 7206.665 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 11:03:34.591 7199.375 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 13:03:32.535 7197.944 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 15:08:38.154 7505.619 interface[435] Cid/W errWarning Inline data bypass has started.
06Dec2011 15:09:49.978 71.824 monitor[451] Monitor/W last update time=1323205717147300000
Messages, like this one, in the category - SensorApp status timed out - were logged 6 times in the last 676825 seconds.
06Dec2011 15:10:36.046 46.068 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
06Dec2011 15:35:53.014 1516.968 sensorApp[955] sensorApp/W DBMemoryResourcesCritical 1 Hits 1 Total.
Messages, like this one, in the category - DBMemoryResourcesCritical - were logged 2 times in the last 1649123 seconds.
06Dec2011 15:35:53.025 0.011 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
06Dec2011 15:35:53.030 0.005 sensorApp[509] sensorApp/W Arena Excess growth of 16777216 detected at exit of CT editDefaultConfigSignatureDefinition.
06Dec2011 15:35:53.059 0.029 interface[435] Cid/W errWarning Inline data bypass has stopped.
06Dec2011 17:03:29.148 5256.089 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 19:03:30.879 7201.731 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 21:03:31.662 7200.783 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Dec2011 23:03:32.220 7200.558 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 01:03:29.331 7197.111 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 03:03:30.964 7201.633 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 05:03:32.058 7201.094 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 07:03:31.550 7199.492 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 09:03:30.694 7199.144 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 11:03:32.217 7201.523 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 13:03:32.926 7200.709 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 15:03:34.104 7201.178 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 17:03:29.764 7195.660 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 19:03:31.851 7202.087 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 21:03:31.607 7199.756 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Dec2011 23:03:30.347 7198.740 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 01:03:31.365 7201.018 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 03:03:30.984 7199.619 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 05:03:31.893 7200.909 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 07:03:29.394 7197.501 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 09:03:30.788 7201.394 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 11:03:30.830 7200.042 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 13:03:31.551 7200.721 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 15:03:31.988 7200.437 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 17:03:32.269 7200.281 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 19:03:31.705 7199.436 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 21:03:31.726 7200.021 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Dec2011 23:03:29.811 7198.085 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 01:03:31.500 7201.689 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 03:03:31.384 7199.884 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 05:03:31.216 7199.832 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 07:03:30.164 7198.948 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 09:03:31.004 7200.840 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 11:03:32.547 7201.543 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 13:03:30.740 7198.193 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 15:03:31.293 7200.553 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 17:03:29.451 7198.158 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 19:03:30.926 7201.475 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 21:03:32.301 7201.375 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Dec2011 23:03:30.952 7198.651 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 01:03:32.027 7201.075 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 03:03:31.126 7199.099 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 05:03:30.843 7199.717 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 07:03:31.457 7200.614 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 09:03:31.184 7199.727 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 11:03:31.337 7200.153 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 13:03:31.033 7199.696 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 15:03:30.753 7199.720 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 17:03:31.792 7201.039 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 19:03:31.623 7199.831 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 21:03:31.434 7199.811 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Dec2011 23:03:31.793 7200.359 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 01:03:31.463 7199.670 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 03:03:31.699 7200.236 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 05:03:30.404 7198.705 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 07:03:30.761 7200.357 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 09:03:32.462 7201.701 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 11:03:30.824 7198.362 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 13:03:31.807 7200.983 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 15:03:31.736 7199.929 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 17:03:30.294 7198.558 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 19:03:30.801 7200.507 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 21:03:32.339 7201.538 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Dec2011 23:03:37.200 7204.861 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 01:03:30.907 7193.707 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 03:03:31.983 7201.076 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 05:03:31.831 7199.848 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 07:03:28.674 7196.843 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 09:03:31.333 7202.659 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 11:03:32.594 7201.261 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 13:03:31.397 7198.803 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 15:03:29.413 7198.016 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 17:03:30.781 7201.368 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 19:03:32.456 7201.675 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 21:03:30.534 7198.078 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Dec2011 23:03:31.885 7201.351 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 01:03:31.556 7199.671 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 03:03:30.742 7199.186 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 05:03:31.938 7201.196 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 07:03:28.609 7196.671 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 09:03:31.925 7203.316 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 11:03:33.870 7201.945 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 13:03:32.466 7198.596 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 15:08:18.032 7485.566 interface[435] Cid/W errWarning Inline data bypass has started.
13Dec2011 15:09:23.164 65.132 monitor[451] Monitor/W last update time=1323810496988354000
Messages, like this one, in the category - SensorApp status timed out - were logged 81 times in the last 604773 seconds.
13Dec2011 15:10:18.176 55.012 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
13Dec2011 15:27:01.987 1003.811 sensorApp[955] sensorApp/W DBMemoryResourcesCritical 1 Hits 1 Total.
Messages, like this one, in the category - DBMemoryResourcesCritical - were logged 2 times in the last 604268 seconds.
13Dec2011 15:27:01.993 0.006 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
13Dec2011 15:27:02.001 0.008 sensorApp[509] sensorApp/W Arena Excess growth of 16777216 detected at exit of CT editDefaultConfigSignatureDefinition.
13Dec2011 15:27:02.006 0.005 interface[435] Cid/W errWarning Inline data bypass has stopped.
13Dec2011 17:03:31.625 5789.619 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 19:03:31.215 7199.590 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 21:03:31.436 7200.221 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Dec2011 23:03:30.053 7198.617 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 01:03:29.481 7199.428 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 03:03:30.140 7200.659 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 05:03:30.664 7200.524 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 07:03:30.196 7199.532 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 09:03:32.408 7202.212 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 11:03:30.915 7198.507 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 13:03:32.485 7201.570 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 15:03:31.397 7198.912 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 17:03:31.540 7200.143 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 19:03:31.351 7199.811 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 21:03:30.935 7199.584 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Dec2011 23:03:31.683 7200.748 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 01:03:30.549 7198.866 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 03:03:31.919 7201.370 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 05:03:30.096 7198.177 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 07:03:30.374 7200.278 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 09:03:31.123 7200.749 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 11:03:31.273 7200.150 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 13:03:36.504 7205.231 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 15:03:48.119 7211.615 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 17:03:31.698 7183.579 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 19:03:30.097 7198.399 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 21:03:31.390 7201.293 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Dec2011 23:03:30.170 7198.780 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 01:03:30.846 7200.676 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 03:03:31.472 7200.626 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 05:03:29.660 7198.188 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 07:03:30.395 7200.735 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 09:03:34.670 7204.275 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 11:03:30.093 7195.423 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 13:03:30.460 7200.367 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 15:03:33.169 7202.709 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 17:03:31.699 7198.530 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 19:03:35.181 7203.482 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 21:03:29.144 7193.963 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Dec2011 23:03:29.237 7200.093 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 01:03:30.753 7201.516 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 03:03:31.923 7201.170 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 05:03:32.102 7200.179 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 07:03:30.694 7198.592 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 09:03:32.251 7201.557 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 11:03:29.033 7196.782 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 13:03:29.102 7200.069 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 15:03:29.993 7200.891 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 17:03:32.333 7202.340 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 19:03:29.063 7196.730 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 21:03:29.988 7200.925 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Dec2011 23:03:32.094 7202.106 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 01:03:30.825 7198.731 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 03:03:31.544 7200.719 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 05:03:31.976 7200.432 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 07:03:30.460 7198.484 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 09:03:31.277 7200.817 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 11:03:31.012 7199.735 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 13:03:30.739 7199.727 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 15:03:29.987 7199.248 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 17:03:30.966 7200.979 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 19:03:32.355 7201.389 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 21:03:31.411 7199.056 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Dec2011 23:03:40.731 7209.320 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 01:03:32.122 7191.391 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 03:03:31.311 7199.189 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 05:03:29.121 7197.810 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 07:03:30.386 7201.265 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 09:03:31.112 7200.726 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 11:03:33.575 7202.463 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 13:03:32.183 7198.608 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 15:03:32.300 7200.117 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 17:03:29.963 7197.663 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 19:03:31.985 7202.022 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 21:03:32.896 7200.911 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Dec2011 23:03:29.791 7196.895 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Dec2011 01:03:31.958 7202.167 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Dec2011 03:03:31.991 7200.033 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Dec2011 05:03:31.220 7199.229 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Dec2011 07:03:31.533 7200.313 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Dec2011 09:03:42.123 7210.590 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Dec2011 11:03:31.838 7189.715 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Dec2011 13:03:33.817 7201.979 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Dec2011 15:03:33.009 7199.192 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Dec2011 17:08:02.379 7469.370 interface[435] Cid/W errWarning Inline data bypass has started.
20Dec2011 17:09:06.674 64.295 monitor[451] Monitor/W last update time=1324422481336928000
Messages, like this one, in the category - SensorApp status timed out - were logged 59 times in the last 611983 seconds.
20Dec2011 17:10:02.090 55.416 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
20Dec2011 17:21:00.070 657.980 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
20Dec2011 17:21:00.075 0.005 interface[435] Cid/W errWarning Inline data bypass has stopped.
20Dec2011 19:03:31.536 6151.461 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Dec2011 21:03:19.244 7187.708 mainApp[348] Cid/E errSystemError http error response: 500
20Dec2011 23:03:18.948 7199.704 mainApp[348] Cid/E errSystemError http error response: 500
21Dec2011 01:03:31.761 7212.813 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 03:03:31.443 7199.682 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 05:03:31.194 7199.751 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 07:03:29.325 7198.131 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 09:03:31.797 7202.472 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 11:03:29.806 7198.009 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 13:03:31.560 7201.754 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 15:03:30.731 7199.171 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 17:03:32.396 7201.665 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 19:03:29.799 7197.403 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 21:03:30.485 7200.686 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Dec2011 23:03:31.299 7200.814 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 01:03:29.465 7198.166 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 03:03:31.346 7201.881 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 05:03:31.067 7199.721 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 07:03:32.688 7201.621 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 09:03:32.699 7200.011 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 11:03:30.402 7197.703 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 13:03:31.603 7201.201 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 15:03:29.514 7197.911 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 17:03:30.352 7200.838 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 19:03:31.546 7201.194 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 21:03:30.087 7198.541 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Dec2011 23:03:31.533 7201.446 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 01:03:31.228 7199.695 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 03:03:29.723 7198.495 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 05:03:31.791 7202.068 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 07:03:31.235 7199.444 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 09:03:31.045 7199.810 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 11:03:31.413 7200.368 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 13:03:31.617 7200.204 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 15:03:31.565 7199.948 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 17:03:30.341 7198.776 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 19:03:29.467 7199.126 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Dec2011 21:07:57.252 7467.785 interface[435] Cid/W errWarning Inline data bypass has started.
23Dec2011 21:09:03.003 65.751 monitor[451] Monitor/W last update time=1324696076236433000
Messages, like this one, in the category - SensorApp status timed out - were logged 17 times in the last 273596 seconds.
23Dec2011 21:09:57.542 54.539 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
23Dec2011 21:16:06.654 369.112 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
23Dec2011 21:16:06.664 0.010 interface[435] Cid/W errWarning Inline data bypass has stopped.
23Dec2011 23:03:30.409 6443.745 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 01:03:31.468 7201.059 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 03:03:30.721 7199.253 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 05:03:31.691 7200.970 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 07:03:30.470 7198.779 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 09:03:31.135 7200.665 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 11:03:29.735 7198.600 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 13:03:30.684 7200.949 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 15:03:32.003 7201.319 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 17:03:29.299 7197.296 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 19:03:31.075 7201.776 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 21:03:31.079 7200.004 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Dec2011 23:03:30.802 7199.723 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 01:03:29.428 7198.626 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 03:03:28.999 7199.571 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 05:03:31.707 7202.708 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 07:03:29.809 7198.102 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 09:03:30.328 7200.519 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 11:03:28.870 7198.542 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 13:03:30.081 7201.211 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 15:03:31.216 7201.135 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 17:03:31.235 7200.019 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 19:03:28.888 7197.653 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 21:03:30.821 7201.933 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Dec2011 23:03:40.543 7209.722 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 01:03:31.608 7191.065 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 03:03:31.688 7200.080 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 05:03:31.337 7199.649 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 07:03:31.489 7200.152 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 09:03:31.894 7200.405 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 11:03:32.358 7200.464 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 13:03:31.070 7198.712 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 15:03:29.943 7198.873 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 17:03:32.407 7202.464 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 19:03:31.142 7198.735 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 21:03:30.940 7199.798 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Dec2011 23:03:33.251 7202.311 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 01:03:30.997 7197.746 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 03:03:32.069 7201.072 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 05:03:31.473 7199.404 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 07:03:30.678 7199.205 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 09:03:31.481 7200.803 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 11:03:34.097 7202.616 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 13:03:29.837 7195.740 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 15:03:31.467 7201.630 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 17:03:31.772 7200.305 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 19:03:31.549 7199.777 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 21:03:31.676 7200.127 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Dec2011 23:03:32.135 7200.459 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 01:03:31.540 7199.405 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 03:03:29.743 7198.203 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 05:03:31.828 7202.085 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 07:03:28.889 7197.061 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 09:03:33.085 7204.196 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 11:03:30.352 7197.267 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 13:03:31.537 7201.185 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 15:03:29.463 7197.926 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 17:03:31.857 7202.394 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 19:03:31.582 7199.725 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 21:03:30.922 7199.340 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Dec2011 23:03:29.933 7199.011 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 01:03:30.597 7200.664 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 03:03:31.552 7200.955 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 05:03:29.972 7198.420 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 07:03:30.763 7200.791 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 09:03:32.115 7201.352 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 11:03:28.975 7196.860 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 13:03:30.636 7201.661 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 13:40:00.570 2189.934 sensorApp[955] IdsEventStore/W errWarning - the event store wrapped around [IdsEventStore::writeEvent(), index = 19526]
29Dec2011 15:03:29.354 5008.784 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 17:03:31.224 7201.870 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 19:03:31.244 7200.020 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 21:03:29.723 7198.479 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Dec2011 23:03:31.564 7201.841 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 01:03:31.041 7199.477 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 03:03:29.559 7198.518 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 05:03:31.540 7201.981 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 07:03:31.337 7199.797 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 09:03:34.590 7203.253 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 11:03:30.454 7195.864 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 13:03:34.091 7203.637 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 15:03:28.565 7194.474 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 17:03:29.112 7200.547 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 19:03:29.524 7200.412 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 21:03:29.797 7200.273 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Dec2011 23:03:31.199 7201.402 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 01:03:30.553 7199.354 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 03:03:31.000 7200.447 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 05:03:30.835 7199.835 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 07:03:31.296 7200.461 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 09:03:29.751 7198.455 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 11:03:29.820 7200.069 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 13:03:29.964 7200.144 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 15:03:31.327 7201.363 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 17:03:29.672 7198.345 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 19:03:29.565 7199.893 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 21:03:29.025 7199.460 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Dec2011 23:03:30.834 7201.809 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 01:03:29.365 7198.531 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 03:03:30.638 7201.273 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 05:03:30.700 7200.062 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 07:03:31.740 7201.040 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 09:03:29.510 7197.770 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 11:03:30.972 7201.462 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 13:03:31.364 7200.392 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 15:03:29.593 7198.229 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 17:03:31.326 7201.733 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 19:03:30.537 7199.211 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Jan2012 21:03:18.976 7188.439 mainApp[348] Cid/E errSystemError AutoUpdate exception: Receive HTTP response failed [3,212]
01Jan2012 23:03:20.079 7201.103 mainApp[348] Cid/E errSystemError http error response: 404
02Jan2012 01:03:28.948 7208.869 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 03:03:33.054 7204.106 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 05:03:31.470 7198.416 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 07:03:30.866 7199.396 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 09:03:29.770 7198.904 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 11:03:34.652 7204.882 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 13:03:31.720 7197.068 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 15:03:31.112 7199.392 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 17:03:30.783 7199.671 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 19:03:31.217 7200.434 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 21:03:30.605 7199.388 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Jan2012 23:03:31.749 7201.144 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 01:03:31.498 7199.749 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 03:03:30.303 7198.805 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 05:03:28.454 7198.151 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 07:03:30.580 7202.126 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 09:03:29.401 7198.821 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 11:03:32.426 7203.025 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 13:03:29.756 7197.330 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 15:03:31.267 7201.511 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 17:03:32.480 7201.213 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 19:03:30.388 7197.908 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 21:03:29.295 7198.907 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Jan2012 23:03:29.332 7200.037 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 01:03:31.703 7202.371 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 03:03:29.008 7197.305 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 05:03:31.020 7202.012 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 07:03:30.349 7199.329 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 09:03:29.533 7199.184 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 11:03:33.364 7203.831 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 13:03:32.187 7198.823 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 15:03:32.927 7200.740 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 17:03:31.391 7198.464 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 19:03:30.470 7199.079 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 21:03:31.355 7200.885 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Jan2012 23:03:31.178 7199.823 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 01:03:31.454 7200.276 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 03:03:31.962 7200.508 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 05:03:31.692 7199.730 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 07:03:30.922 7199.230 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 09:03:35.206 7204.284 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 11:03:30.369 7195.163 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 13:03:32.684 7202.315 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 15:08:07.752 7475.068 interface[435] Cid/W errWarning Inline data bypass has started.
05Jan2012 15:09:13.649 65.897 monitor[451] Monitor/W last update time=1325797686727288000
Messages, like this one, in the category - SensorApp status timed out - were logged 9 times in the last 1101610 seconds.
05Jan2012 15:10:07.690 54.041 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
05Jan2012 15:33:44.280 1416.590 sensorApp[955] sensorApp/W DBMemoryResourcesCritical 1 Hits 1 Total.
Messages, like this one, in the category - DBMemoryResourcesCritical - were logged 2 times in the last 1987602 seconds.
05Jan2012 15:33:44.287 0.007 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
05Jan2012 15:33:44.296 0.009 sensorApp[509] sensorApp/W Arena Excess growth of 16777216 detected at exit of CT editDefaultConfigSignatureDefinition.
05Jan2012 15:33:44.316 0.020 interface[435] Cid/W errWarning Inline data bypass has stopped.
05Jan2012 17:03:31.056 5386.740 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 19:03:31.068 7200.012 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 21:03:31.370 7200.302 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Jan2012 23:03:30.247 7198.877 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 01:03:31.410 7201.163 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 03:03:30.761 7199.351 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 05:03:31.858 7201.097 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 07:03:29.312 7197.454 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 09:03:31.830 7202.518 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 11:03:32.163 7200.333 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 13:03:31.559 7199.396 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 15:03:31.396 7199.837 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 17:03:31.931 7200.535 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 19:03:30.805 7198.874 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 21:03:30.920 7200.115 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Jan2012 23:03:31.835 7200.915 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 01:03:30.205 7198.370 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 03:03:29.637 7199.432 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 05:03:32.705 7203.068 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 07:03:31.561 7198.856 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 09:03:30.901 7199.340 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 11:03:31.776 7200.875 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 13:03:31.981 7200.205 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 15:03:32.186 7200.205 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 17:03:30.952 7198.766 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 19:03:31.908 7200.956 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 21:03:31.677 7199.769 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Jan2012 23:03:31.203 7199.526 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 01:03:31.042 7199.839 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 03:03:31.151 7200.109 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 05:03:29.491 7198.340 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 07:03:31.251 7201.760 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 09:03:30.880 7199.629 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 11:03:32.258 7201.378 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 13:03:30.606 7198.348 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 15:03:31.515 7200.909 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 17:03:30.610 7199.095 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 19:03:31.138 7200.528 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 21:03:31.234 7200.096 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Jan2012 23:03:41.057 7209.823 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 01:03:29.688 7188.631 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 03:03:29.662 7199.974 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 05:03:30.139 7200.477 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 07:03:32.171 7202.032 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 09:03:32.363 7200.192 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 11:03:30.753 7198.390 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 13:03:32.734 7201.981 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 15:03:31.748 7199.014 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 17:03:33.098 7201.350 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 19:03:31.090 7197.992 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 21:03:30.977 7199.887 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Jan2012 23:03:32.448 7201.471 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 01:03:31.237 7198.789 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 03:03:32.012 7200.775 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 05:03:31.320 7199.308 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 07:03:30.136 7198.816 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 09:03:30.855 7200.719 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 11:03:34.096 7203.241 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 13:08:27.532 7493.436 interface[435] Cid/W errWarning Inline data bypass has started.
10Jan2012 13:09:36.556 69.024 monitor[451] Monitor/W last update time=1326222506521687000
Messages, like this one, in the category - SensorApp status timed out - were logged 81 times in the last 424822 seconds.
10Jan2012 13:10:28.647 52.091 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
10Jan2012 13:29:52.090 1163.443 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
10Jan2012 13:29:52.110 0.020 interface[435] Cid/W errWarning Inline data bypass has stopped.
10Jan2012 15:03:33.089 5620.979 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 17:03:30.900 7197.811 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 19:03:30.347 7199.447 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 21:03:32.681 7202.334 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Jan2012 23:03:32.142 7199.461 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 01:03:31.361 7199.219 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 03:03:30.663 7199.302 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 05:03:31.760 7201.097 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 07:03:31.935 7200.175 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 09:03:32.069 7200.134 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 11:03:31.007 7198.938 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 13:03:34.888 7203.881 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 15:03:32.099 7197.211 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 17:03:31.711 7199.612 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 19:03:32.521 7200.810 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 21:03:30.767 7198.246 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Jan2012 23:03:31.706 7200.939 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 01:03:30.137 7198.431 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 03:03:31.096 7200.959 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 05:03:31.957 7200.861 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 07:03:30.448 7198.491 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 09:03:29.742 7199.294 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 11:03:33.391 7203.649 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 13:03:32.114 7198.723 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 15:03:34.296 7202.182 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 17:03:31.993 7197.697 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 19:08:09.445 7477.452 interface[435] Cid/W errWarning Inline data bypass has started.
12Jan2012 19:09:21.620 72.175 monitor[451] Monitor/W last update time=1326416888436802000
Messages, like this one, in the category - SensorApp status timed out - were logged 66 times in the last 194385 seconds.
12Jan2012 19:10:11.310 49.690 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
12Jan2012 19:16:25.160 373.850 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
12Jan2012 19:16:25.191 0.031 interface[435] Cid/W errWarning Inline data bypass has stopped.
12Jan2012 21:03:32.121 6426.930 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Jan2012 23:03:37.722 7205.601 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 01:03:32.279 7194.557 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 03:03:32.063 7199.784 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 05:03:30.455 7198.392 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 07:03:29.849 7199.394 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 09:03:33.318 7203.469 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 11:03:31.548 7198.230 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 13:03:31.534 7199.986 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 15:03:31.201 7199.667 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 17:03:38.996 7207.795 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 19:03:31.880 7192.884 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Jan2012 21:08:07.468 7475.588 interface[435] Cid/W errWarning Inline data bypass has started.
13Jan2012 21:09:12.268 64.800 monitor[451] Monitor/W last update time=1326510486436312000
Messages, like this one, in the category - SensorApp status timed out - were logged 12 times in the last 93590 seconds.
13Jan2012 21:10:08.443 56.175 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
13Jan2012 21:17:22.961 434.518 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
13Jan2012 21:17:23.033 0.072 interface[435] Cid/W errWarning Inline data bypass has stopped.
13Jan2012 23:03:31.878 6368.845 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 01:03:32.500 7200.622 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 03:03:30.649 7198.149 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 05:03:30.133 7199.484 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 07:03:30.000 7199.867 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 09:03:31.593 7201.593 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 11:03:34.593 7203.000 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 13:03:30.576 7195.983 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 15:03:31.881 7201.305 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 17:03:32.578 7200.697 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 19:03:30.289 7197.711 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 21:03:29.905 7199.616 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Jan2012 23:03:32.034 7202.129 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 01:03:36.499 7204.465 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 03:03:36.268 7199.769 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 05:03:31.800 7195.532 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 07:03:30.753 7198.953 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 09:03:30.770 7200.017 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 11:03:31.852 7201.082 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 13:03:30.543 7198.691 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 15:03:31.465 7200.922 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 17:03:30.070 7198.605 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 19:03:29.643 7199.573 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 21:03:31.691 7202.048 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Jan2012 23:03:39.377 7207.686 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 01:03:31.373 7191.996 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 03:03:29.286 7197.913 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 05:03:30.536 7201.250 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 07:03:32.384 7201.848 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 09:03:31.600 7199.216 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 11:03:30.916 7199.316 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 13:03:33.015 7202.099 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 15:03:31.375 7198.360 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 17:03:30.352 7198.977 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 19:03:30.799 7200.447 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 21:03:32.062 7201.263 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Jan2012 23:03:31.682 7199.620 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Jan2012 01:03:30.312 7198.630 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Jan2012 03:03:31.485 7201.173 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Jan2012 05:03:31.392 7199.907 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Jan2012 07:03:41.873 7210.481 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Jan2012 09:03:30.856 7188.983 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Jan2012 11:03:33.300 7202.444 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Jan2012 13:03:31.440 7198.140 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Jan2012 15:03:21.734 7190.294 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
17Jan2012 17:03:34.806 7213.072 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Jan2012 19:03:33.207 7198.401 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Jan2012 21:07:54.598 7461.391 interface[435] Cid/W errWarning Inline data bypass has started.
17Jan2012 21:09:05.412 70.814 monitor[451] Monitor/W last update time=1326856073593368000
Messages, like this one, in the category - SensorApp status timed out - were logged 11 times in the last 345593 seconds.
17Jan2012 21:10:00.686 55.274 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
17Jan2012 21:17:02.648 421.962 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
17Jan2012 21:17:02.689 0.041 interface[435] Cid/W errWarning Inline data bypass has stopped.
17Jan2012 23:03:29.714 6387.025 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 01:03:31.403 7201.689 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 03:03:31.831 7200.428 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 05:03:32.231 7200.400 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 07:03:31.384 7199.153 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 09:03:32.345 7200.961 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 11:03:30.285 7197.940 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 13:03:31.314 7201.029 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 15:03:30.583 7199.269 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 17:03:32.100 7201.517 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 19:03:33.239 7201.139 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 21:03:31.119 7197.880 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Jan2012 23:03:31.538 7200.419 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 01:03:32.168 7200.630 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 03:03:29.290 7197.122 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 05:03:32.495 7203.205 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 07:03:31.501 7199.006 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 09:03:33.799 7202.298 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 11:03:31.184 7197.385 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 13:03:31.466 7200.282 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 15:08:15.861 7484.395 interface[435] Cid/W errWarning Inline data bypass has started.
19Jan2012 15:09:27.455 71.594 monitor[451] Monitor/W last update time=1327007294843734000
Messages, like this one, in the category - SensorApp status timed out - were logged 11 times in the last 151222 seconds.
19Jan2012 15:10:15.308 47.853 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
19Jan2012 15:17:08.398 413.090 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
19Jan2012 15:17:08.472 0.074 interface[435] Cid/W errWarning Inline data bypass has stopped.
19Jan2012 17:03:32.057 6383.585 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 19:03:31.059 7199.002 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 21:03:29.139 7198.080 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Jan2012 23:03:31.710 7202.571 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 01:03:31.987 7200.277 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 03:03:31.983 7199.996 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 05:03:33.155 7201.172 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 07:03:31.794 7198.639 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 09:03:32.405 7200.611 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 11:03:32.155 7199.750 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 13:03:33.072 7200.917 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 15:03:32.021 7198.949 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 17:03:31.454 7199.433 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 19:03:30.867 7199.413 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Jan2012 21:07:59.430 7468.563 interface[435] Cid/W errWarning Inline data bypass has started.
20Jan2012 21:09:08.676 69.246 monitor[451] Monitor/W last update time=1327115278429238000
Messages, like this one, in the category - SensorApp status timed out - were logged 11 times in the last 107981 seconds.
20Jan2012 21:10:02.745 54.069 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
20Jan2012 21:17:14.096 431.351 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
20Jan2012 21:17:14.122 0.026 interface[435] Cid/W errWarning Inline data bypass has stopped.
20Jan2012 23:03:30.911 6376.789 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 01:03:31.677 7200.766 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 03:03:30.033 7198.356 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 05:03:30.416 7200.383 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 07:03:32.824 7202.408 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 09:03:30.591 7197.767 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 11:03:30.393 7199.802 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 13:03:31.478 7201.085 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 15:03:31.534 7200.056 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 17:03:30.550 7199.016 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 19:03:32.398 7201.848 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 21:03:32.088 7199.690 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Jan2012 23:03:31.468 7199.380 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 01:03:31.508 7200.040 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 03:03:31.036 7199.528 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 05:03:30.912 7199.876 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 07:03:32.629 7201.717 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 09:03:31.623 7198.994 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 11:03:32.413 7200.790 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 13:03:31.472 7199.059 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 15:03:31.513 7200.041 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 17:03:34.373 7202.860 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 19:03:32.338 7197.965 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 21:03:30.386 7198.048 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Jan2012 23:03:40.364 7209.978 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 01:03:31.066 7190.702 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 03:03:31.176 7200.110 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 05:03:31.217 7200.041 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 07:03:31.709 7200.492 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 09:03:32.285 7200.576 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 11:03:32.512 7200.227 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 13:03:32.848 7200.336 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 15:03:31.420 7198.572 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 17:03:32.374 7200.954 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 19:03:30.858 7198.484 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 21:03:44.751 7213.893 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Jan2012 23:03:32.505 7187.754 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 01:03:31.355 7198.850 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 03:03:32.580 7201.225 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 05:03:30.430 7197.850 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 07:03:32.382 7201.952 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 09:03:31.942 7199.560 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 11:03:34.036 7202.094 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 13:03:31.143 7197.107 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 15:03:31.138 7199.995 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 17:03:32.356 7201.218 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 19:03:31.637 7199.281 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 21:03:32.064 7200.427 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Jan2012 23:03:31.494 7199.430 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 01:03:32.173 7200.679 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 03:03:31.249 7199.076 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 05:03:31.733 7200.484 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 07:03:32.917 7201.184 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 09:03:32.005 7199.088 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 11:03:34.603 7202.598 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 13:03:33.079 7198.476 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 15:03:35.225 7202.146 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 17:03:30.730 7195.505 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 19:03:20.821 7190.091 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
25Jan2012 21:03:30.684 7209.863 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Jan2012 23:03:32.241 7201.557 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Jan2012 01:03:30.347 7198.106 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Jan2012 03:03:31.783 7201.436 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Jan2012 05:03:30.024 7198.241 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Jan2012 07:03:31.768 7201.744 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Jan2012 09:03:30.773 7199.005 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Jan2012 11:03:31.669 7200.896 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Jan2012 13:03:34.024 7202.355 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Jan2012 15:08:14.614 7480.590 interface[435] Cid/W errWarning Inline data bypass has started.
26Jan2012 15:09:18.611 63.997 monitor[451] Monitor/W last update time=1327612093573968000
Messages, like this one, in the category - SensorApp status timed out - were logged 10 times in the last 496809 seconds.
26Jan2012 15:10:15.039 56.428 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
26Jan2012 15:13:44.241 209.202 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
26Jan2012 15:13:44.360 0.119 interface[435] Cid/W errWarning Inline data bypass has stopped.
26Jan2012 17:03:20.213 6575.853 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
26Jan2012 19:03:31.484 7211.271 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Jan2012 21:03:32.219 7200.735 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Jan2012 23:03:31.332 7199.113 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 01:03:31.796 7200.464 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 03:03:32.226 7200.430 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 05:03:32.184 7199.958 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 07:03:31.643 7199.459 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 09:03:33.331 7201.688 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 11:03:33.309 7199.978 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 13:03:31.581 7198.272 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 15:03:31.618 7200.037 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 17:03:31.130 7199.512 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 19:03:30.765 7199.635 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 21:03:33.194 7202.429 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Jan2012 23:03:31.739 7198.545 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 01:03:31.858 7200.119 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 03:03:30.491 7198.633 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 05:03:30.514 7200.023 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 07:03:31.663 7201.149 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 09:03:31.705 7200.042 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 11:03:30.036 7198.331 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 13:03:33.450 7203.414 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 15:03:31.535 7198.085 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 17:03:30.472 7198.937 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 19:03:31.479 7201.007 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 21:03:29.967 7198.488 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Jan2012 23:03:30.755 7200.788 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 01:03:32.290 7201.535 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 03:03:32.165 7199.875 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 05:03:31.627 7199.462 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 07:03:32.596 7200.969 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 09:03:31.981 7199.385 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 11:03:32.303 7200.322 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 13:03:31.662 7199.359 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 15:03:31.999 7200.337 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 17:03:31.933 7199.934 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 19:03:30.893 7198.960 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 21:03:32.997 7202.104 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Jan2012 23:03:41.509 7208.512 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 01:03:31.538 7190.029 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 03:03:31.047 7199.509 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 05:03:31.586 7200.539 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 07:03:31.064 7199.478 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 09:03:32.380 7201.316 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 11:03:32.284 7199.904 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 13:03:33.719 7201.435 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 15:03:32.748 7199.029 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 17:03:31.153 7198.405 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 19:03:34.971 7203.818 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 21:03:32.260 7197.289 mainApp[348] Cid/E errSystemError No installable auto update package found on server
30Jan2012 23:03:31.373 7199.113 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 01:03:30.896 7199.523 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 03:03:30.758 7199.862 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 05:03:32.273 7201.515 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 07:03:32.520 7200.247 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 09:03:33.366 7200.846 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 11:03:40.808 7207.442 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 13:03:32.281 7191.473 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 15:03:32.584 7200.303 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 17:03:32.277 7199.693 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 19:03:32.726 7200.449 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 21:03:31.850 7199.124 mainApp[348] Cid/E errSystemError No installable auto update package found on server
31Jan2012 23:03:31.581 7199.731 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 01:03:31.752 7200.171 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 03:03:31.964 7200.212 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 05:03:32.206 7200.242 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 07:03:33.700 7201.494 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 09:03:31.830 7198.130 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 11:03:34.352 7202.522 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 13:03:34.180 7199.828 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 15:03:32.650 7198.470 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 17:03:30.917 7198.267 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 19:03:30.583 7199.666 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 21:03:33.941 7203.358 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Feb2012 23:03:31.419 7197.478 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 01:03:30.968 7199.549 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 03:03:32.031 7201.063 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 05:03:30.316 7198.285 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 07:03:33.266 7202.950 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 09:03:30.539 7197.273 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 11:03:30.690 7200.151 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 13:03:30.546 7199.856 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 15:08:19.247 7488.701 interface[435] Cid/W errWarning Inline data bypass has started.
02Feb2012 15:09:28.030 68.783 monitor[451] Monitor/W last update time=1328216898239272000
Messages, like this one, in the category - SensorApp status timed out - were logged 6 times in the last 604809 seconds.
02Feb2012 15:10:26.285 58.255 sensorApp[509] Cid/W AnalysisEngine reconfiguration starting.
02Feb2012 15:10:26.475 0.190 sensorApp[509] sensorApp/W errWarning unspecifiedWarning:Editing signature 3793:1 for engine has NO effect in this version. Please contact your Cisco representative for versions that support this signature
02Feb2012 15:11:02.617 0.000 monitor[451] Syslog/F errSystemError threadStart catch(CIDS runtime exception) Failed to parse the default config info
02Feb2012 15:18:53.454 506.979 sensorApp[509] Cid/W AnalysisEngine reconfiguration complete.
02Feb2012 15:18:53.465 0.011 interface[435] Cid/W errWarning Inline data bypass has stopped.
02Feb2012 17:03:29.149 6275.684 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 19:03:28.863 7199.714 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 21:03:29.423 7200.560 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Feb2012 23:03:29.702 7200.279 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 01:03:29.339 7199.637 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 03:03:32.186 7202.847 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 05:03:29.318 7197.132 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 07:03:29.611 7200.293 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 09:03:31.341 7201.730 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 11:03:31.267 7199.926 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 13:03:29.702 7198.435 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 15:03:30.484 7200.782 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 17:03:29.360 7198.876 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 19:03:28.977 7199.617 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 21:03:19.710 7190.733 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Feb2012 23:03:19.480 7199.770 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 01:03:29.065 7209.585 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 03:03:29.088 7200.023 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 05:03:29.334 7200.246 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 07:03:28.923 7199.589 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 09:03:29.926 7201.003 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 11:03:29.624 7199.698 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 13:03:29.623 7199.999 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 15:03:29.332 7199.709 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 17:03:29.906 7200.574 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 19:03:29.474 7199.568 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 21:03:29.304 7199.830 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Feb2012 23:03:28.873 7199.569 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Feb2012 01:03:52.764 7223.891 mainApp[348] Cid/E errSystemError AutoUpdate exception: Receive HTTP response failed [3,212]
05Feb2012 03:03:30.415 7177.651 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Feb2012 05:03:28.972 7198.557 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Feb2012 07:03:29.535 7200.563 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Feb2012 09:03:28.952 7199.417 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Feb2012 11:03:29.518 7200.566 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Feb2012 13:03:29.132 7199.614 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Feb2012 15:03:29.889 7200.757 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Feb2012 17:03:19.420 7189.531 mainApp[348] Cid/E errSystemError http error response: 503
05Feb2012 19:03:29.041 7209.621 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Feb2012 21:03:28.665 7199.624 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Feb2012 23:03:38.133 7209.468 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 01:03:28.957 7190.824 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 03:03:29.584 7200.627 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 05:03:29.239 7199.655 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 07:03:28.904 7199.665 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 09:03:29.935 7201.031 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 11:03:30.059 7200.124 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 13:03:29.380 7199.321 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 13:22:33.110 1143.730 monitor[452] IdsEventStore/W errWarning - the event store wrapped around [IdsEventStore::writeEvent(), index = 19531]
06Feb2012 15:03:30.459 6057.349 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 17:03:33.803 7203.344 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 19:03:29.528 7195.725 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 21:03:29.508 7199.980 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Feb2012 23:03:29.140 7199.632 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 01:03:29.353 7200.213 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 03:03:29.258 7199.905 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 05:03:28.931 7199.673 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 07:03:29.714 7200.783 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 09:00:52.373 7042.659 mainApp[414] cplane/E Error - accept() call returned -1
07Feb2012 09:00:52.407 0.034 mainApp[347] Cid/W errWarning - MainApp is exiting; reboot requested by user
07Feb2012 09:00:52.434 0.027 interface[435] Cid/W errWarning Inline data bypass has started.
07Feb2012 09:01:03.082 10.648 cidwebserver[446] IoPipe/E errSystemError connect timed out [ClientPipe::connect]
07Feb2012 09:01:03.093 0.011 cidwebserver[446] Cid/E errSystemError - ct-mainApp.343 not responding, please check system processes - The connect to the specified Io::ClientPipe failed.
07Feb2012 09:01:07.433 4.340 mainApp[347] Cid/E errSystemError AppManager::ApplicationEntry::stop - Could not stop application "AnalysisEngine" within 15 second timeout
07Feb2012 09:01:07.433 0.000 mainApp[347] Cid/E errSystemError MainApplication::run - One or more applications failed to terminate normally.
07Feb2012 09:01:19.244 11.811 cidwebserver[443] IoPipe/E errSystemError connect timed out [ClientPipe::connect]
07Feb2012 09:01:19.246 0.002 cidwebserver[443] Cid/E errSystemError - ct-mainApp.343 not responding, please check system processes - The connect to the specified Io::ClientPipe failed.
<<<<<<<<<<<<<<<<<<<<<<<<< Interprocess Logging Started >>>>>>>>>>>>>>>>>>>>>>>>>
07Feb2012 09:04:04.536 51.555 mainApp[347] Cid/E errSystemError - ntpdate failed to set clock from NTP server after retrying for 45 seconds. Debug info:
Looking for host 10.x.x.5 and service ntp
7 Feb 09:04:00 ntpdate[403]: ntpdate 4.2.0@1.1161-r Mon Dec 15 18:07:31 UTC 2008 (1)
transmit(10.x.x.5)
transmit to 10.x.x.5
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit(10.x.x.5)
transmit(10.x.x.5)
10.x.x.5: Server dropped: no data
server 10.x.x.5, port 123
stratum 0, precision 0, leap 00, trust 000
refid [10.x.x.5], delay 0.00000, dispersion 64.00000
transmitted 4, in filter 4
reference time:    00000000.00000000  Thu, Feb  7 2036  0:28:16.000
originate timestamp: 00000000.00000000  Thu, Feb  7 2036  0:28:16.000
transmit timestamp:  d2dbbbe3.87c158fb  Tue, Feb  7 2012  9:04:03.530
filter delay:  0.00000  0.00000  0.00000  0.00000
filter offset: 0.000000 0.000000 0.000000 0.000000
offset 0.000000
-----Begin syslogReader----
Begin syslogReader
07Feb2012 09:04:17.937 0.000 logApp[433] Cid/W Disabled status event logging for status category: controlTransaction
07Feb2012 09:04:18.113 0.176 interface[347] Cid/E errSystemError - no matching interface descriptor found [PhysicalIntfcList::identifyInterface]
07Feb2012 09:04:21.337 3.224 interface[435] Cid/W errWarning Inline data bypass has started.
07Feb2012 09:04:26.657 5.320 mainApp[347] watchdog/W Watchdog is enabled
07Feb2012 09:05:54.427 87.770 monitor[451] Monitor/W last update time=1328627080246377000
Messages, like this one, in the category - SensorApp status timed out - were logged 1 times in the last 0 seconds.
07Feb2012 09:07:48.158 113.731 sensorApp[488] Cid/W AnalysisEngine reconfiguration starting.
07Feb2012 09:15:36.331 468.173 sensorApp[488] Cid/W errWarning valueIgnored:cannot specify external-rate-limit-percentage for sig: 4004
07Feb2012 09:19:30.832 234.501 sensorApp[488] sensorApp/W WARNING: Signature 1306.6 will continue to use the default settings and modify packets inline.
07Feb2012 09:19:30.832 0.000 sensorApp[488] sensorApp/W WARNING: Signature 1330.4 will continue to use the default settings and modify packets inline.
07Feb2012 09:19:30.833 0.001 sensorApp[488] sensorApp/W WARNING: Signature 1330.7 will continue to use the default settings and modify packets inline.
07Feb2012 09:19:30.833 0.000 sensorApp[488] sensorApp/W WARNING: Disabling, Removing deny packet, or Removing modify packet on Signature 1317.0 may cause Normalizer state issues and result in false positives.
07Feb2012 09:19:30.833 0.000 sensorApp[488] sensorApp/W WARNING: Signature 1330.19 will continue to use the default settings and modify packets inline.
07Feb2012 09:19:30.833 0.000 sensorApp[488] sensorApp/W WARNING: Signature 1330.20 will continue to use the default settings and modify packets inline.
07Feb2012 09:19:30.833 0.000 sensorApp[488] sensorApp/W WARNING: Signature 1330.21 will continue to use the default settings and modify packets inline.
07Feb2012 09:19:30.968 0.135 sensorApp[488] Cid/E errUnacceptableValue invalidValue:Anomaly Detection is not supported on this platform
07Feb2012 09:19:41.227 10.259 sensorApp[488] Cid/W AnalysisEngine reconfiguration complete.
07Feb2012 09:19:41.278 0.051 interface[435] Cid/W errWarning Inline data bypass has stopped.
07Feb2012 11:03:36.083 6234.805 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 13:03:29.897 7193.814 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 15:03:32.678 7202.781 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 17:03:32.032 7199.354 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 19:03:31.148 7199.116 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 21:03:29.587 7198.439 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Feb2012 23:03:30.237 7200.650 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 01:03:29.438 7199.201 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 03:03:30.166 7200.728 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 05:03:29.972 7199.806 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 07:03:31.160 7201.188 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 09:03:31.704 7200.544 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 11:03:32.616 7200.912 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 13:03:32.711 7200.095 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 15:03:31.298 7198.587 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 17:03:31.429 7200.131 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 19:03:30.906 7199.477 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 21:03:30.720 7199.814 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Feb2012 23:03:29.708 7198.988 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 01:03:29.698 7199.990 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 03:03:30.875 7201.177 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 05:03:31.636 7200.761 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 07:03:29.618 7197.982 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 09:03:33.953 7204.335 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 11:03:34.429 7200.476 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 13:03:31.947 7197.518 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 15:03:37.519 7205.572 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 17:10:38.235 7620.716 interface[435] Cid/W errWarning Inline data bypass has started.
09Feb2012 17:11:47.498 69.263 monitor[451] Monitor/W last update time=1328829037213280000
Messages, like this one, in the category - SensorApp status timed out - were logged 33 times in the last 201953 seconds.
09Feb2012 17:12:38.675 51.177 sensorApp[505] Cid/W AnalysisEngine reconfiguration starting.
09Feb2012 17:20:40.263 481.588 sensorApp[1656] sensorApp/W DBMemoryResourcesCritical 1 Hits 1 Total.
Messages, like this one, in the category - DBMemoryResourcesCritical - were logged 1 times in the last 0 seconds.
09Feb2012 17:20:40.282 0.019 sensorApp[505] Cid/W AnalysisEngine reconfiguration complete.
09Feb2012 17:20:40.286 0.004 sensorApp[505] sensorApp/W Arena Excess growth of 3178496 detected at exit of CT editDefaultConfigSignatureDefinition.
09Feb2012 17:20:40.290 0.004 interface[435] Cid/W errWarning Inline data bypass has stopped.
09Feb2012 19:03:31.020 6170.730 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 21:03:30.760 7199.740 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Feb2012 23:03:30.935 7200.175 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 01:03:30.077 7199.142 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 03:03:37.350 7207.273 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 05:03:30.196 7192.846 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 07:03:30.986 7200.790 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 09:03:32.164 7201.178 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 11:03:36.306 7204.142 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 13:03:31.756 7195.450 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 15:03:31.290 7199.534 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 17:03:31.072 7199.782 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 19:03:30.776 7199.704 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 21:03:31.546 7200.770 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Feb2012 23:03:31.206 7199.660 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 01:03:28.865 7197.659 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 03:03:30.175 7201.310 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 05:03:30.910 7200.735 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 07:03:30.086 7199.176 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 09:03:30.290 7200.204 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 11:03:30.450 7200.160 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 13:03:29.607 7199.157 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 15:03:30.057 7200.450 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 17:03:30.192 7200.135 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 19:03:30.992 7200.800 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 21:03:31.713 7200.721 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Feb2012 23:03:29.929 7198.216 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 01:03:29.758 7199.829 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 03:03:30.344 7200.586 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 05:03:31.119 7200.775 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 07:03:30.854 7199.735 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 09:03:31.557 7200.703 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 11:03:30.095 7198.538 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 13:03:30.893 7200.798 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 15:03:31.544 7200.651 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 17:03:29.729 7198.185 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 19:03:29.759 7200.030 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 21:03:30.495 7200.736 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Feb2012 23:03:39.663 7209.168 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 01:03:31.369 7191.706 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 03:03:31.125 7199.756 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 05:03:30.155 7199.030 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 07:03:29.527 7199.372 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 09:03:30.500 7200.973 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 11:03:31.344 7200.844 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 13:03:31.259 7199.915 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 15:03:29.849 7198.590 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 17:03:30.278 7200.429 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 19:03:31.044 7200.766 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 21:03:29.659 7198.615 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Feb2012 23:03:31.406 7201.747 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 01:03:31.164 7199.758 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 03:03:29.380 7198.216 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 05:03:29.376 7199.996 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 07:03:31.041 7201.665 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 09:03:40.627 7209.586 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 11:03:46.595 7205.968 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 13:08:05.334 7458.739 interface[435] Cid/W errWarning Inline data bypass has started.
14Feb2012 13:09:16.639 71.305 monitor[451] Monitor/W last update time=1329246484313769000
Messages, like this one, in the category - SensorApp status timed out - were logged 8 times in the last 417449 seconds.
14Feb2012 13:10:04.232 47.593 sensorApp[505] Cid/W AnalysisEngine reconfiguration starting.
14Feb2012 13:31:55.914 1311.682 sensorApp[1656] sensorApp/W DBMemoryResourcesCritical 1 Hits 1 Total.
Messages, like this one, in the category - DBMemoryResourcesCritical - were logged 2 times in the last 418275 seconds.
14Feb2012 13:31:55.925 0.011 sensorApp[505] Cid/W AnalysisEngine reconfiguration complete.
14Feb2012 13:31:55.929 0.004 sensorApp[505] sensorApp/W Arena Excess growth of 8749732 detected at exit of CT editDefaultConfigSignatureDefinition.
14Feb2012 13:31:55.933 0.004 interface[435] Cid/W errWarning Inline data bypass has stopped.
14Feb2012 15:03:32.317 5496.384 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 17:03:31.243 7198.926 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 19:03:30.946 7199.703 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 21:03:30.606 7199.660 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Feb2012 23:03:31.467 7200.861 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 01:03:30.594 7199.127 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 03:03:30.869 7200.275 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 05:03:31.613 7200.744 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 07:03:31.724 7200.111 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 09:03:31.916 7200.192 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 11:03:30.793 7198.877 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 13:03:31.620 7200.827 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 15:03:33.289 7201.669 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 17:03:31.405 7198.116 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 19:03:31.366 7199.961 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 21:03:31.242 7199.876 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Feb2012 23:03:31.166 7199.924 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Feb2012 01:08:04.006 7472.840 interface[435] Cid/W errWarning Inline data bypass has started.
16Feb2012 01:09:03.542 59.536 monitor[451] Monitor/W last update time=1329376083004279000
Messages, like this one, in the category - SensorApp status timed out - were logged 71 times in the last 129586 seconds.
16Feb2012 01:10:01.823 58.281 sensorApp[505] Cid/W AnalysisEngine reconfiguration starting.
16Feb2012 01:10:01.846 0.023 sensorApp[505] sensorApp/W errWarning unspecifiedWarning:Editing signature 3793:1 for engine has NO effect in this version. Please contact your Cisco representative for versions that support this signature
16Feb2012 01:10:36.523 0.000 monitor[451] Syslog/F errSystemError threadStart catch(CIDS runtime exception) Failed to parse the default config info
16Feb2012 01:13:31.343 209.497 sensorApp[505] Cid/W AnalysisEngine reconfiguration complete.
16Feb2012 01:13:31.348 0.005 interface[435] Cid/W errWarning Inline data bypass has stopped.
16Feb2012 03:03:28.467 6597.119 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Feb2012 05:03:28.804 7200.337 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Feb2012 07:03:29.102 7200.298 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Feb2012 09:03:28.801 7199.699 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Feb2012 11:03:29.192 7200.391 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Feb2012 13:03:28.557 7199.365 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Feb2012 15:03:29.246 7200.689 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Feb2012 17:03:20.162 7190.916 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
16Feb2012 19:03:29.512 7209.350 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Feb2012 21:03:29.265 7199.753 mainApp[348] Cid/E errSystemError No installable auto update package found on server
16Feb2012 23:03:28.638 7199.373 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 01:03:29.451 7200.813 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 03:03:28.769 7199.318 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 05:03:29.043 7200.274 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 07:03:28.816 7199.773 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 09:03:29.734 7200.918 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 11:03:31.372 7201.638 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 13:03:28.755 7197.383 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 15:03:29.039 7200.284 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 17:03:28.344 7199.305 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 19:03:28.684 7200.340 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 21:03:28.938 7200.254 mainApp[348] Cid/E errSystemError No installable auto update package found on server
17Feb2012 23:03:29.214 7200.276 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 01:03:28.466 7199.252 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 03:03:28.798 7200.332 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 05:03:29.116 7200.318 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 07:03:28.416 7199.300 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 09:03:28.889 7200.473 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 11:03:28.640 7199.751 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 13:03:28.955 7200.315 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 15:03:29.498 7200.543 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 17:03:28.887 7199.389 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 19:03:29.157 7200.270 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 21:03:28.531 7199.374 mainApp[348] Cid/E errSystemError No installable auto update package found on server
18Feb2012 23:03:28.879 7200.348 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 01:03:29.153 7200.274 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 03:03:28.450 7199.297 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 05:03:20.349 7191.899 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
19Feb2012 07:03:28.674 7208.325 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 09:03:29.083 7200.409 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 11:03:28.727 7199.644 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 13:03:30.338 7201.611 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 15:03:28.884 7198.546 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 17:03:29.286 7200.402 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 19:03:28.647 7199.361 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 21:03:29.049 7200.402 mainApp[348] Cid/E errSystemError No installable auto update package found on server
19Feb2012 23:03:37.766 7208.717 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 01:03:29.056 7191.290 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 03:03:28.295 7199.239 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 05:03:28.839 7200.544 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 07:03:29.113 7200.274 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 09:03:28.680 7199.567 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 11:03:29.147 7200.467 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 13:03:28.621 7199.474 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 15:03:41.648 7213.027 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 17:03:37.245 7195.597 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 19:03:28.722 7191.477 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 21:03:29.016 7200.294 mainApp[348] Cid/E errSystemError No installable auto update package found on server
20Feb2012 23:03:28.402 7199.386 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 01:03:28.725 7200.323 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 03:03:28.981 7200.256 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 05:03:29.510 7200.529 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 07:03:29.002 7199.492 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 09:03:38.962 7209.960 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 11:03:29.110 7190.148 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 13:03:28.763 7199.653 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 15:03:29.530 7200.767 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 17:03:29.430 7199.900 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 19:03:28.791 7199.361 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 21:03:29.127 7200.336 mainApp[348] Cid/E errSystemError No installable auto update package found on server
21Feb2012 23:03:28.437 7199.310 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 01:03:28.752 7200.315 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 03:03:29.090 7200.338 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 05:03:28.353 7199.263 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 07:03:31.601 7203.248 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 09:03:29.329 7197.728 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 11:03:28.826 7199.497 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 13:03:33.199 7204.373 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 15:03:29.052 7195.853 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 17:03:30.717 7201.665 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 19:03:29.379 7198.662 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 21:03:28.669 7199.290 mainApp[348] Cid/E errSystemError No installable auto update package found on server
22Feb2012 23:03:29.403 7200.734 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 01:03:29.197 7199.794 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 03:03:29.077 7199.880 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 05:03:28.974 7199.897 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 07:03:29.961 7200.987 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 09:03:29.900 7199.939 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 11:03:28.921 7199.021 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 13:03:30.149 7201.228 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 15:07:42.283 7452.134 interface[435] Cid/W errWarning Inline data bypass has started.
23Feb2012 15:09:23.998 101.715 sensorApp[505] Cid/W AnalysisEngine reconfiguration starting.
23Feb2012 15:13:50.580 266.582 sensorApp[505] Cid/W AnalysisEngine reconfiguration complete.
23Feb2012 15:13:50.586 0.006 interface[435] Cid/W errWarning Inline data bypass has stopped.
23Feb2012 17:03:32.141 6581.555 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 19:03:34.929 7202.788 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 21:03:29.932 7195.003 mainApp[348] Cid/E errSystemError No installable auto update package found on server
23Feb2012 23:03:30.798 7200.866 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 01:03:29.696 7198.898 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 03:03:29.610 7199.914 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 05:03:29.758 7200.148 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 07:03:29.672 7199.914 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 09:03:29.804 7200.132 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 11:03:30.068 7200.264 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 13:03:29.943 7199.875 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 15:03:29.953 7200.010 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 17:03:29.817 7199.864 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 19:03:29.719 7199.902 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 21:03:29.688 7199.969 mainApp[348] Cid/E errSystemError No installable auto update package found on server
24Feb2012 23:07:12.840 7423.152 interface[435] Cid/W errWarning Inline data bypass has started.
24Feb2012 23:08:53.022 100.182 sensorApp[505] Cid/W AnalysisEngine reconfiguration starting.
24Feb2012 23:16:35.762 462.740 sensorApp[1656] sensorApp/W DBMemoryResourcesCritical 1 Hits 1 Total.
Messages, like this one, in the category - DBMemoryResourcesCritical - were logged 2 times in the last 899079 seconds.
24Feb2012 23:16:35.772 0.010 sensorApp[505] Cid/W AnalysisEngine reconfiguration complete.
24Feb2012 23:16:35.776 0.004 sensorApp[505] sensorApp/W Arena Excess growth of 8388608 detected at exit of CT editDefaultConfigSignatureDefinition.
24Feb2012 23:16:35.780 0.004 interface[435] Cid/W errWarning Inline data bypass has stopped.
25Feb2012 01:03:30.024 6414.244 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 03:03:28.991 7198.967 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 05:03:30.007 7201.016 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 07:03:28.951 7198.944 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 09:03:29.952 7201.001 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 11:03:29.453 7199.501 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 13:03:29.474 7200.021 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 15:03:29.515 7200.041 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 17:03:29.679 7200.164 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 19:03:29.632 7199.953 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 21:03:29.567 7199.935 mainApp[348] Cid/E errSystemError No installable auto update package found on server
25Feb2012 23:03:29.544 7199.977 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 01:03:29.482 7199.938 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 03:03:29.437 7199.955 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 05:03:29.370 7199.933 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 07:03:29.368 7199.998 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 09:03:29.420 7200.052 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 11:03:29.246 7199.826 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 13:03:29.452 7200.206 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 15:03:29.363 7199.911 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 17:03:29.265 7199.902 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 19:03:30.855 7201.590 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 21:03:30.755 7199.900 mainApp[348] Cid/E errSystemError No installable auto update package found on server
26Feb2012 23:03:37.237 7206.482 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 01:03:29.128 7191.891 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 03:03:29.052 7199.924 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 05:03:28.971 7199.919 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 07:03:31.557 7202.586 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 09:03:29.627 7198.070 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 11:03:30.647 7201.020 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 13:03:29.483 7198.836 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 15:03:29.596 7200.113 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 17:03:29.568 7199.972 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 19:03:29.895 7200.327 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 21:03:29.914 7200.019 mainApp[348] Cid/E errSystemError No installable auto update package found on server
27Feb2012 23:03:29.904 7199.990 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 01:03:29.789 7199.885 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 03:03:29.776 7199.987 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 05:03:29.647 7199.871 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 07:03:29.622 7199.975 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 09:03:30.978 7201.356 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 11:03:29.867 7198.889 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 13:03:36.803 7206.936 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 15:03:30.761 7193.958 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 17:03:29.964 7199.203 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 19:03:29.934 7199.970 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 21:03:29.934 7200.000 mainApp[348] Cid/E errSystemError No installable auto update package found on server
28Feb2012 23:03:29.426 7199.492 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 01:03:29.562 7200.136 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 03:03:29.605 7200.043 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 05:03:29.494 7199.889 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 07:03:29.527 7200.033 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 09:03:34.499 7204.972 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 11:03:29.668 7195.169 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 13:08:33.797 7504.129 interface[435] Cid/W errWarning Inline data bypass has started.
29Feb2012 13:10:15.944 102.147 sensorApp[505] Cid/W AnalysisEngine reconfiguration starting.
29Feb2012 13:12:21.990 126.046 sensorApp[505] Cid/W AnalysisEngine reconfiguration complete.
29Feb2012 13:12:21.997 0.007 interface[435] Cid/W errWarning Inline data bypass has stopped.
29Feb2012 15:03:29.652 6667.655 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 17:03:34.415 7204.763 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 19:03:29.587 7195.172 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 21:03:29.910 7200.323 mainApp[348] Cid/E errSystemError No installable auto update package found on server
29Feb2012 23:03:29.873 7199.963 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 01:03:29.740 7199.867 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 03:03:29.650 7199.910 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 05:03:29.583 7199.933 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 07:03:30.767 7201.184 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 09:03:30.456 7199.689 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 11:03:29.104 7198.648 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 13:03:29.511 7200.407 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 15:03:32.521 7203.010 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 17:03:29.453 7196.932 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 19:03:29.406 7199.953 mainApp[348] Cid/E errSystemError No installable auto update package found on server
01Mar2012 21:03:20.307 7190.901 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
01Mar2012 23:03:29.223 7208.916 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 01:03:29.037 7199.814 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 03:03:28.991 7199.954 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 05:03:46.037 7217.046 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 07:03:29.744 7183.707 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 09:03:30.354 7200.610 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 11:03:30.676 7200.322 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 13:03:29.743 7199.067 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 15:03:30.265 7200.522 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 17:03:29.201 7198.936 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 19:03:29.111 7199.910 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 21:03:29.019 7199.908 mainApp[348] Cid/E errSystemError No installable auto update package found on server
02Mar2012 23:03:29.007 7199.988 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 01:03:29.308 7200.301 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 03:03:29.333 7200.025 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 05:03:29.288 7199.955 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 07:03:29.237 7199.949 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 09:03:29.242 7200.005 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 11:03:29.560 7200.318 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 13:03:29.668 7200.108 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 15:03:20.640 7190.972 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
03Mar2012 17:03:30.408 7209.768 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 19:03:29.352 7198.944 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 21:03:29.390 7200.038 mainApp[348] Cid/E errSystemError No installable auto update package found on server
03Mar2012 23:03:29.366 7199.976 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 01:03:29.554 7200.188 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 03:03:29.426 7199.872 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 05:03:29.341 7199.915 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 07:03:29.291 7199.950 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 09:03:48.821 7219.530 mainApp[348] Cid/E errSystemError AutoUpdate exception: Receive HTTP response failed [3,212]
04Mar2012 11:03:29.326 7180.505 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 13:03:29.224 7199.898 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 15:03:29.134 7199.910 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 17:03:29.072 7199.938 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 19:03:28.982 7199.910 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 21:03:29.901 7200.919 mainApp[348] Cid/E errSystemError No installable auto update package found on server
04Mar2012 23:03:37.311 7207.410 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 01:03:29.197 7191.886 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 03:03:29.201 7200.004 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 05:03:29.219 7200.018 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 07:03:29.337 7200.118 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 09:03:31.988 7202.651 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 11:03:31.740 7199.752 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 13:03:30.984 7199.244 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 15:03:42.878 7211.894 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 17:03:39.154 7196.276 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 19:03:30.861 7191.707 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 21:03:29.854 7198.993 mainApp[348] Cid/E errSystemError No installable auto update package found on server
05Mar2012 23:03:30.681 7200.827 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 01:03:31.551 7200.870 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 03:03:29.492 7197.941 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 05:03:29.437 7199.945 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 07:03:29.641 7200.204 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 09:03:37.963 7208.322 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 11:03:29.871 7191.908 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 13:03:41.428 7211.557 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 15:03:29.896 7188.468 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 17:03:21.930 7192.034 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
06Mar2012 19:03:29.978 7208.048 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 21:03:30.068 7200.090 mainApp[348] Cid/E errSystemError No installable auto update package found on server
06Mar2012 23:03:28.949 7198.881 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 01:03:29.830 7200.881 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 03:03:29.715 7199.885 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 05:03:29.661 7199.946 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 07:03:29.680 7200.019 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 09:03:30.101 7200.421 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 11:03:30.095 7199.994 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 13:03:29.302 7199.207 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 15:07:28.771 7439.469 interface[435] Cid/W errWarning Inline data bypass has started.
07Mar2012 15:09:11.948 103.177 sensorApp[505] Cid/W AnalysisEngine reconfiguration starting.
07Mar2012 15:14:19.975 308.027 sensorApp[505] Cid/W AnalysisEngine reconfiguration complete.
07Mar2012 15:14:19.981 0.006 interface[435] Cid/W errWarning Inline data bypass has stopped.
07Mar2012 17:03:29.872 6549.891 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 19:03:29.851 7199.979 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 21:03:29.778 7199.927 mainApp[348] Cid/E errSystemError No installable auto update package found on server
07Mar2012 23:03:29.734 7199.956 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 01:03:29.714 7199.980 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 03:03:29.509 7199.795 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 05:03:29.577 7200.068 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 07:03:29.537 7199.960 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 09:03:29.658 7200.121 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 11:03:30.525 7200.867 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 13:03:29.855 7199.330 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 15:03:29.904 7200.049 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 17:03:30.052 7200.148 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 19:03:28.988 7198.936 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 21:03:30.050 7201.062 mainApp[348] Cid/E errSystemError No installable auto update package found on server
08Mar2012 23:03:28.992 7198.942 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 01:03:29.880 7200.888 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 03:03:29.906 7200.026 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 05:03:29.831 7199.925 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 07:03:29.795 7199.964 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 09:03:29.805 7200.010 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 11:03:30.779 7200.974 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 13:03:31.794 7201.015 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 15:03:31.010 7199.216 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 17:03:28.985 7197.975 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 19:03:29.959 7200.974 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 21:03:30.095 7200.136 mainApp[348] Cid/E errSystemError No installable auto update package found on server
09Mar2012 23:03:29.925 7199.830 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 01:03:29.863 7199.938 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 03:03:29.892 7200.029 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 05:03:29.844 7199.952 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 07:03:29.777 7199.933 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 09:03:29.817 7200.040 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 11:03:29.618 7199.801 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 13:03:29.657 7200.039 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 15:03:29.611 7199.954 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 17:03:29.666 7200.055 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 19:03:29.647 7199.981 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 21:03:29.631 7199.984 mainApp[348] Cid/E errSystemError No installable auto update package found on server
10Mar2012 23:03:29.524 7199.893 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 01:03:29.557 7200.033 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 04:03:29.509 10799.952 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 05:03:29.101 3599.592 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 07:03:29.160 7200.059 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 09:03:29.035 7199.875 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 11:03:28.939 7199.904 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 13:03:29.989 7201.050 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 15:03:30.093 7200.104 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 17:03:29.133 7199.040 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 19:03:29.066 7199.933 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 21:03:29.001 7199.935 mainApp[348] Cid/E errSystemError No installable auto update package found on server
11Mar2012 23:03:35.755 7206.754 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 01:03:29.666 7193.911 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 03:03:29.622 7199.956 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 05:03:29.541 7199.919 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 07:03:29.539 7199.998 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 09:03:29.592 7200.053 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 11:03:35.211 7205.619 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 13:03:29.931 7194.720 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 15:03:30.812 7200.881 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 17:03:29.881 7199.069 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 19:03:30.619 7200.738 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 21:03:29.575 7198.956 mainApp[348] Cid/E errSystemError No installable auto update package found on server
12Mar2012 23:03:29.404 7199.829 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Mar2012 01:03:29.381 7199.977 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Mar2012 03:03:29.415 7200.034 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Mar2012 05:03:29.485 7200.070 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Mar2012 07:03:29.484 7199.999 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Mar2012 09:03:29.415 7199.931 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Mar2012 11:03:32.247 7202.832 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Mar2012 12:57:59.642 6867.395 cidwebserver[438] tls/W errTransport while sending a TLS warning alert close_notify, the following error occurred: socket error [3,32]
Messages, like this one, in the category - TLS socket failure - were logged 1 times in the last 0 seconds.
13Mar2012 13:07:29.348 569.706 interface[435] Cid/W errWarning Inline data bypass has started.
13Mar2012 13:09:10.317 100.969 sensorApp[505] Cid/W AnalysisEngine reconfiguration starting.
13Mar2012 13:09:10.402 0.085 sensorApp[505] sensorApp/W errWarning unspecifiedWarning:Editing signature 31560:1 for engine has NO effect in this version. Please contact your Cisco representative for versions that support this signature
13Mar2012 13:15:21.112 370.710 sensorApp[505] Cid/W AnalysisEngine reconfiguration complete.
13Mar2012 13:15:21.118 0.006 interface[435] Cid/W errWarning Inline data bypass has stopped.
13Mar2012 15:03:31.604 6490.486 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Mar2012 17:03:29.524 7197.920 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Mar2012 19:03:29.640 7200.116 mainApp[348] Cid/E errSystemError No installable auto update package found on server
13Mar2012 21:03:20.469 7190.829 mainApp[348] Cid/E errSystemError could not parse cisco-locator-server response
13Mar2012 23:03:29.466 7208.997 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 01:03:29.401 7199.935 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 03:03:29.352 7199.951 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 05:03:29.360 7200.008 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 07:03:29.267 7199.907 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 09:03:33.304 7204.037 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 11:03:29.329 7196.025 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 13:07:27.991 7438.662 interface[435] Cid/W errWarning Inline data bypass has started.
14Mar2012 13:09:09.334 101.343 sensorApp[505] Cid/W AnalysisEngine reconfiguration starting.
14Mar2012 13:13:10.158 240.824 sensorApp[505] Cid/W AnalysisEngine reconfiguration complete.
14Mar2012 13:13:10.163 0.005 interface[435] Cid/W errWarning Inline data bypass has stopped.
14Mar2012 15:03:30.604 6620.441 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 17:03:29.689 7199.085 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 19:03:29.788 7200.099 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 21:03:29.939 7200.151 mainApp[348] Cid/E errSystemError No installable auto update package found on server
14Mar2012 23:03:29.973 7200.034 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Mar2012 01:03:29.995 7200.022 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Mar2012 03:03:29.961 7199.966 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Mar2012 05:03:29.996 7200.035 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Mar2012 07:03:30.075 7200.079 mainApp[348] Cid/E errSystemError No installable auto update package found on server
15Mar2012 09:03:29.916 7199.841 mainApp[348] Cid/E errSystemError No installable auto update package found on server
================================= END OF FILE ==================================
exec: ls -alR /usr/cids
/usr/cids:
drwxr-xr-x    5 cids     cids         1024 Oct 17 11:01 .
drwxrwxr-x    8 root     root         1024 Jun 23  2011 ..
-rwxrwxr-x    1 cids     cids          314 Jun 23  2011 .bash_profile
drwxrwxr-x    2 cids     cids         1024 Mar 14 13:03 .gnupg
drwx------    2 cids     cids         1024 Oct 17 11:01 .ssh
drwxrwxr-x   11 cids     cids         1024 Oct 17 10:57 idsRoot
/usr/cids/.gnupg:
drwxr-xr-x    5 cids     cids         1024 Oct 17 11:01 ..
-rwxrwxr-x    1 cids     cids          925 Jun 23  2011 pubring.gpg
-rwxrwxr-x    1 cids     cids            0 Jun 23  2011 secring.gpg
-rwxrwxr-x    1 cids     cids         1280 Jun 23  2011 trustdb.gpg
/usr/cids/.ssh:
-rw-r--r--    1 cids     cids            0 Feb  7 09:04 known_hosts
/usr/cids/idsRoot:
drwxrwxr-x   11 cids     cids         1024 Oct 17 10:57 .
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 bin
drwxrwx---    7 cids     cids         1024 Mar 15 09:42 core
drwxrwxr-x    5 cids     cids         1024 Oct 25 07:50 etc
drwxrwxr-x    6 cids     cids         1024 Oct 17 10:57 htdocs
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 lib
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:59 log
drwxrwxr-x    2 cids     cids         1024 Jun 23  2011 shared
drwxrwxrwt    3 root     root          140 Mar 15 09:58 tmp
drwxrwxr-x    5 cids     cids         1024 Mar 14 13:13 var
/usr/cids/idsRoot/bin:
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 .
drwxrwxr-x   11 cids     cids         1024 Oct 17 10:57 ..
-rwxrwxr-x    1 cids     cids        17232 Jun 23  2011 SSM_control_proc
-rwxrwxr-x    1 cids     cids        61516 Jun 23  2011 blversion
-rwxrwxr-x    1 cids     cids         7420 Jun 23  2011 ceGrep
-rwxrwxr-x    1 cids     cids        10127 Jun 23  2011 cidDump
-rwxrwxr-x    1 cids     cids       447956 Jun 23  2011 cidcli
-rwxrwxr-x    1 cids     cids       293416 Jun 23  2011 cidsInit
-rwxrwxr-x    1 cids     cids         6156 Jun 23  2011 cleanUp
-rwxrwxr-x    1 cids     cids         3888 Jun 23  2011 enter_loopback
-rwxrwxr-x    1 cids     cids          111 Jun 23  2011 getEventStoreStats
-rwxrwxr-x    1 cids     cids        63756 Jun 23  2011 hotrod
-rwxrwxr-x    1 cids     cids        12692 Jun 23  2011 ipsDebug
-rwxrwxr-x    1 cids     cids      5783492 Jun 23  2011 mainApp
-rwxrwxr-x    1 cids     cids        27676 Jun 23  2011 rbcp_send_reloading
-rwxrwxr-x    1 cids     cids        27708 Jun 23  2011 rbcp_send_shutdown_done
-rwxrwxr-x    1 cids     cids        30876 Jun 23  2011 rbcpd
-rwxrwxr-x    1 cids     cids         9892 Jun 23  2011 scp_boot_success
-rwxrwxr-x    1 cids     cids        14648 Jun 23  2011 scp_get_card_type
-rwxrwxr-x    1 cids     cids         8772 Jun 23  2011 scp_gmt_time_poll
-rwxrwxr-x    1 cids     cids         9892 Jun 23  2011 scp_os_boot_status
-rwxrwxr-x    1 cids     cids         8388 Jun 23  2011 scp_register
-rwxrwxr-x    1 cids     cids         9892 Jun 23  2011 scp_req_restart
-rwxrwxr-x    1 cids     cids         8932 Jun 23  2011 scp_req_shutdown
-rwxrwxr-x    1 cids     cids        23352 Jun 23  2011 scp_rw_sprom
-rwxrwxr-x    1 cids     cids         4844 Jun 23  2011 scp_set_time_mode
-rwxrwxr-x    1 cids     cids        18196 Jun 23  2011 scpd
-rwxrwxr-x    1 cids     cids        37172 Jun 23  2011 sendCtlTrans
-rwxrwxr-x    1 cids     cids      8447984 Jun 23  2011 sensorApp
-rwxrwxr-x    1 cids     cids        13932 Jun 23  2011 smbios_bios_info
-rwxrwxr-x    1 cids     cids         4492 Jun 23  2011 superflash
-rwxrwxr-x    1 cids     cids        53812 Jun 23  2011 sysId
-rwxrwxr-x    1 cids     cids        73836 Jun 23  2011 uflash
/usr/cids/idsRoot/core:
drwxrwx---    7 cids     cids         1024 Mar 15 09:42 .
drwxrwx---    2 cisco    cids         1024 Mar 15 09:42 cidcli
drwxrwx---    2 cids     cids         1024 Oct 17 10:59 cidsInit
drwxrwx---    2 cids     cids         1024 Oct 17 10:59 mainApp
drwxrwx---    2 cids     cids         1024 Oct 19 12:04 sendCtlTrans
drwxrwx---    2 cids     cids         1024 Oct 17 11:01 sensorApp
/usr/cids/idsRoot/core/cidcli:
drwxrwx---    2 cisco    cids         1024 Mar 15 09:42 .
drwxrwx---    7 cids     cids         1024 Mar 15 09:42 ..
/usr/cids/idsRoot/core/cidsInit:
drwxrwx---    2 cids     cids         1024 Oct 17 10:59 .
/usr/cids/idsRoot/core/mainApp:
/usr/cids/idsRoot/core/sendCtlTrans:
drwxrwx---    2 cids     cids         1024 Oct 19 12:04 .
/usr/cids/idsRoot/core/sensorApp:
drwxrwx---    2 cids     cids         1024 Oct 17 11:01 .
/usr/cids/idsRoot/etc:
drwxrwxr-x    5 cids     cids         1024 Oct 25 07:50 .
-rwxrwxr-x    1 cids     cids         1720 Jun 23  2011 LocatorInput.xml
-rwxrwxr-x    1 cids     cids          345 Jun 23  2011 PlatToPkgMap.conf
-rw-rw-r--    1 cids     cids       592179 Mar 14 13:07 SigCategories.xml
-rwxrwxr-x    1 cids     cids            9 Jun 23  2011 VERSION
-rw-rw-r--    1 cids     cids           15 Oct 17 10:57 VERSION_RP
-rwxrwxr-x    1 cids     cids          443 Jun 23  2011 actionGroups.xml
-rwxrwxr-x    1 cids     cids         5393 Jun 23  2011 anomalyDetection.conf
-rwxrwxr-x    1 cids     cids           87 Jun 23  2011 auth.conf
-rw-rw-r--    1 cids     cids         1988 Jan 21  2011 backup.cfg
-rw-r--r--    1 root     root         2789 Feb  7 09:03 boot.info
-rw-r--r--    1 root     root         6016 Oct 17 10:59 boot.info.diff
-rw-r--r--    1 root     root         2783 Feb  7 09:03 boot.info.old
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 cert
-rw-rw-rw-    1 cids     cids       265384 Feb  7 09:04 cids-shared.bin
-rwxrwxr-x    1 cids     cids          406 Feb  7 09:03 cidsZoneInfo.txt
-rwxrwxr-x    1 cids     cids          672 Jun 23  2011 cidwebserver.conf
-rwxrwxr-x    1 cids     cids        25826 Jun 23  2011 cliAdmin.conf
-rwxrwxr-x    1 cids     cids        21156 Jun 23  2011 cliOperator.conf
-rwxrwxr-x    1 cids     cids          509 Jun 23  2011 cliPlatform.conf
-rwxrwxr-x    1 cids     cids        48385 Jun 23  2011 cliViewer.conf
drwxrwxr-x   19 cids     cids         1024 Feb  7 09:04 config
-rw-rw-r--    1 cids     cids         1988 Jan 21  2011 current.cfg
-rwxrwxr-x    1 cids     cids          186 Jun 23  2011 eventServer.conf
-rwxrwxr-x    1 cids     cids          297 Jun 23  2011 eventStore.conf
-rwxrwxr-x    1 cids     cids          595 Jun 23  2011 idProm.conf
-rwxrwxr-x    1 cids     cids        26192 Jun 23  2011 interface.conf
-rwxrwxr-x    1 cids     cids         1083 Jun 23  2011 log.conf
-rwxrwxr-x    1 cids     cids         4062 Jun 23  2011 mainApp.conf
-rwxrwxr-x    1 cids     cids         1492 Jun 23  2011 notificationPlatform.conf
-rwxrwxr-x    1 cids     cids        17030 Jun 23  2011 osfp.conf
-rw-rw-rw-    1 cids     cids         1024 Feb  7 09:01 random_seed
-rwxrwxr-x    1 cids     cids          379 Jun 23  2011 sa_motd
-rwxrwxr-x    1 cids     cids          269 Jun 23  2011 selfcert.conf
-rwxrwxr-x    1 cids     cids           37 Mar 25  2010 sensorApp.conf
-rwxrwxr-x    1 cids     cids           12 Jun 23  2011 simulator.conf
drwxr-xr-x    2 cids     cids         1024 Oct 17 11:01 snmp
-rwxrwxr-x    1 cids     cids          787 Mar 14 10:09 standard_motd
-rwxrwxr-x    1 cids     cids         3116 Jun 23  2011 stateString.conf
-rwxrwxr-x    1 cids     cids          473 Feb  7 09:04 tls.conf
-rw-r--r--    1 cids     cids            0 Oct 17 10:50 upgraded_from_6_2_3_E4
-rwxrwxr-x    1 cids     cids         1024 Jun 23  2011 validate_motd
/usr/cids/idsRoot/etc/cert:
drwxrwxr-x    5 cids     cids         1024 Oct 25 07:50 ..
-rw-rw-rw-    1 cids     cids          540 Jan 14  2011 mytestca.cer
-rw-------    1 cids     cids          634 Jan 14  2011 mytestca.priv
/usr/cids/idsRoot/etc/config:
drwxrwxr-x   19 cids     cids         1024 Feb  7 09:04 .
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 analysisEngine
drwxrwxr-x    4 cids     cids         1024 Oct 17 10:57 anomalyDetection
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 authentication
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 cliMain
drwxrwxr-x    3 cids     cids         1024 Oct 17 10:57 eventActionRules
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 externalProductInterface
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 healthMonitor
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 host
drwxrwxr-x    2 cids     cids         1024 Feb  7 09:04 interface
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 logger
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 networkAccess
drwxrwxr-x    2 cids     cids         1024 Oct 20 10:35 notification
drwxrwxr-x    3 cids     cids         1024 Oct 17 10:57 signatureDefinition
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 sshKnownHosts
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 trustedCertificates
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 userAccount
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 webServer
/usr/cids/idsRoot/etc/config/analysisEngine:
drwxrwxr-x   19 cids     cids         1024 Feb  7 09:04 ..
-rw-rw-rw-    1 cids     cids          267 Jan 18  2011 current.xml
-rwxrwxr-x    1 cids     cids          851 Jun 23  2011 default.sig.xml
-rw-rw-r--    1 cids     cids          320 Jun 23  2011 default.xml
-rwxrwxr-x    1 cids     cids          851 Jun 23  2011 typedefs.sig.xml
-rw-rw-r--    1 cids     cids         1724 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/anomalyDetection:
drwxrwxr-x    4 cids     cids         1024 Oct 17 10:57 .
-rw-rw-r--    1 cids     cids          424 Jun 23  2011 default.xml
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 instances
drwxrwxr-x    4 cids     cids         1024 Oct 17 10:57 kb
-rw-rw-r--    1 cids     cids         2396 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/anomalyDetection/instances:
drwxrwxr-x    4 cids     cids         1024 Oct 17 10:57 ..
-rwxrwxr-x    1 cids     cids          204 Sep 22  2009 ad0.xml
/usr/cids/idsRoot/etc/config/anomalyDetection/kb:
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 current
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 files
/usr/cids/idsRoot/etc/config/anomalyDetection/kb/current:
-rwxrwxr-x    1 cids     cids           84 Jun 23  2011 initial
/usr/cids/idsRoot/etc/config/anomalyDetection/kb/files:
/usr/cids/idsRoot/etc/config/authentication:
-rw-rw-r--    1 cids     cids          116 Sep 22  2009 current.xml
-rw-rw-r--    1 cids     cids          115 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids          652 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/cliMain:
-rwxrwxr-x    1 cids     cids        36144 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/eventActionRules:
drwxrwxr-x    3 cids     cids         1024 Oct 17 10:57 .
-rw-rw-r--    1 cids     cids          563 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids         3914 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/eventActionRules/instances:
drwxrwxr-x    3 cids     cids         1024 Oct 17 10:57 ..
-rw-rw-rw-    1 cids     cids          555 Aug 10  2011 rules0.xml
/usr/cids/idsRoot/etc/config/externalProductInterface:
-rw-rw-r--    1 cids     cids          115 Sep 22  2009 current.xml
-rw-rw-r--    1 cids     cids          116 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids         1685 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/healthMonitor:
-rw-rw-r--    1 cids     cids          154 Sep 22  2009 current.xml
-rw-rw-r--    1 cids     cids          429 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids         1291 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/host:
-rwxrwxr-x    1 cids     cids          765 Feb  7 09:03 current.xml
-rw-rw-r--    1 cids     cids         1033 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids         4289 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/interface:
drwxrwxr-x    2 cids     cids         1024 Feb  7 09:04 .
-rw-rw-rw-    1 cids     cids          180 Feb  7 09:04 current.xml
-rwxrwxr-x    1 cids     cids          860 Feb  7 09:04 default.sig.xml
-rw-rw-rw-    1 cids     cids          381 Feb  7 09:04 default.xml
-rw-rw-r--    1 cids     cids         2745 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/logger:
-rw-rw-r--    1 cids     cids          113 Sep 22  2009 current.xml
-rw-rw-r--    1 cids     cids          534 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids         1158 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/networkAccess:
-rw-rw-rw-    1 cids     cids          233 Jan 21  2011 current.xml
-rw-rw-r--    1 cids     cids         2233 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/notification:
drwxrwxr-x    2 cids     cids         1024 Oct 20 10:35 .
-rw-rw-rw-    1 cids     cids          380 Oct 20 10:35 current.xml
-rw-rw-r--    1 cids     cids          346 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids         1279 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/signatureDefinition:
-rwxrwxr-x    1 cids     cids          860 Mar 14 13:10 default.sig.xml
-rw-rw-r--    1 cids     cids       807184 Mar 14 13:10 default.xml
-rwxrwxr-x    1 cids     cids          860 Oct 17 10:50 typedefs.sig.xml
-rw-rw-r--    1 cids     cids        53961 Mar 25  2010 typedefs.xml
/usr/cids/idsRoot/etc/config/signatureDefinition/instances:
-rw-rw-rw-    1 cids     cids         1108 Aug  5  2011 sig0.xml
/usr/cids/idsRoot/etc/config/sshKnownHosts:
-rw-rw-r--    1 cids     cids          192 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids          456 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/trustedCertificates:
-rw-rw-r--    1 cids     cids          198 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids          476 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/userAccount:
-rw-rw-rw-    1 cids     cids          268 Jan 21  2011 current.xml
-rw-rw-r--    1 cids     cids          224 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids          727 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/config/webServer:
-rw-rw-r--    1 cids     cids          275 Jun 23  2011 default.xml
-rw-rw-r--    1 cids     cids          759 Jun 23  2011 typedefs.xml
/usr/cids/idsRoot/etc/snmp:
drwxr-xr-x    2 cids     cids         1024 Oct 17 11:01 .
-rw-rw-rw-    1 cids     cids          214 Feb  7 09:04 snmpd.conf
/usr/cids/idsRoot/htdocs:
drwxrwxr-x    6 cids     cids         1024 Oct 17 10:57 .
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:57 cgi-bin
drwxrwxr-x    2 cids     cids         1024 Jun 23  2011 private
drwxrwxr-x    3 cids     cids         1024 Oct 17 10:57 protected
drwxrwxr-x    3 cids     cids         1024 Oct 17 10:57 public
/usr/cids/idsRoot/htdocs/cgi-bin:
drwxrwxr-x    6 cids     cids         1024 Oct 17 10:57 ..
-rwxrwxr-x    1 cids     cids       192028 Jun 23  2011 event-server.so
-rwxrwxr-x    1 cids     cids       176000 Jun 23  2011 iplog-server.so
-rwxrwxr-x    1 cids     cids       200832 Jun 23  2011 sdee-server.so
-rwxrwxr-x    1 cids     cids       238352 Jun 23  2011 transaction-server.so
/usr/cids/idsRoot/htdocs/private:
drwxrwxr-x    2 cids     cids         1024 Jun 23  2011 .
/usr/cids/idsRoot/htdocs/protected:
drwxrwxr-x    3 cids     cids         1024 Oct 17 10:57 idm
/usr/cids/idsRoot/htdocs/protected/idm:
-rwxrwxr-x    1 cids     cids       450560 Jun 23  2011 dm-launcher.msi
drwxrwxr-x    2 cids     cids         1024 Jun 23  2011 help
-rwxrwxr-x    1 cids     cids      4360869 Jun 23  2011 idm.sgz
-rwxrwxr-x    1 cids     cids          240 Jun 23  2011 idmversion.html
/usr/cids/idsRoot/htdocs/protected/idm/help:
/usr/cids/idsRoot/htdocs/public:
-rwxrwxr-x    1 cids     cids         2416 Jun 23  2011 fatalError.html
-rwxrwxr-x    1 cids     cids          295 Jun 23  2011 index.html
/usr/cids/idsRoot/htdocs/public/idm:
-rwxrwxr-x    1 cids     cids       106595 Jun 23  2011 dm-launcher.jar
-rwxrwxr-x    1 cids     cids         2111 Jun 23  2011 idm.jnlp
-rwxrwxr-x    1 cids     cids         2936 Jun 23  2011 index.html
-rwxrwxr-x    1 cids     cids        67324 Jun 23  2011 jploader.jar
-rwxrwxr-x    1 cids     cids         9326 Jun 23  2011 lzma.jar
-rwxrwxr-x    1 cids     cids       110994 Jun 23  2011 retroweaver-rt-2.0.jar
drwxrwxr-x    3 cids     cids         1024 Oct 17 10:57 skin
/usr/cids/idsRoot/htdocs/public/idm/skin:
drwxrwxr-x    2 cids     cids         1024 Jun 23  2011 images
/usr/cids/idsRoot/htdocs/public/idm/skin/images:
/usr/cids/idsRoot/lib:
-rwxrwxr-x    1 cids     cids      1588980 Jun 23  2011 libcidcli.001.006.so
-rwxrwxr-x    1 cids     cids        28588 Jun 23  2011 libcidcliapp.001.004.so
-rwxrwxr-x    1 cids     cids      1174576 Jun 23  2011 libcidclicommands.so
-rwxrwxr-x    1 cids     cids       869068 Jun 23  2011 libcidcore.002.041.so
-rwxrwxr-x    1 cids     cids       462804 Jun 23  2011 libcidfiletrans.001.005.so
-rwxrwxr-x    1 cids     cids       278808 Jun 23  2011 libcidxml.001.009.so
-rwxrwxr-x    1 cids     cids        39532 Jun 23  2011 libhoard.so
-rwxrwxr-x    1 cids     cids       334724 Jun 23  2011 libidapi.001.015.so
-rwxrwxr-x    1 cids     cids      2158048 Jun 23  2011 libidiom.001.008.so
/usr/cids/idsRoot/log:
drwxrwxr-x    2 cids     cids         1024 Oct 17 10:59 .
-rw-r--r--    1 cids     cids       246828 Mar 15 09:03 main.log
/usr/cids/idsRoot/shared:
-rw-rw-r--    1 cids     cids          471 Oct 17 10:56 host.conf
-rw-rw-r--    1 cids     cids         1275 Jan  5 10:28 ips.lic
-rw-rw-r--    1 cids     cids         1052 Jan  5 10:28 lservrc.bck
-rw-rw-r--    1 cids     cids         1052 Jan  5 10:28 lservrc.pri
-rw-rw-r--    1 cids     cids         1440 Oct 17 10:56 trialprs.bck
-rw-rw-r--    1 cids     cids         1440 Oct 17 10:56 trialprs.prs
-rw-rw-r--    1 cids     cids           32 Oct 17 10:56 trialprschk.bck
-rw-rw-r--    1 cids     cids           32 Oct 17 10:56 trialprschk.prs
/usr/cids/idsRoot/tmp:
drwxrwxrwt    3 root     root          140 Mar 15 09:58 .
-rw-rw-rw-    1 root     cids           60 Mar 15 09:56 cidDump.html
drwxrwxrwx    2 cids     cids         1300 Mar 15 09:56 ipc
-rw-rw-rw-    1 root     cids         1879 Mar 15 09:57 mpstat.log
-rw-rw-rw-    1 root     cids        24577 Mar 15 09:57 top.log
-rw-rw-rw-    1 root     cids         1757 Mar 15 09:57 vmstat.log
/usr/cids/idsRoot/tmp/ipc:
drwxrwxrwx    2 cids     cids         1300 Mar 15 09:56 .
drwxrwxrwt    3 root     root          140 Mar 15 09:58 ..
prw-rw----    1 cids     cids            0 Feb  7 09:04 evt_IdsEventStore0
prw-rw----    1 cids     cids            0 Mar 15 09:03 evt_IdsEventStore1
prw-rw----    1 cids     cids            0 Feb  7 09:04 evt_IdsEventStore2
prw-rw----    1 cids     cids            0 Mar 15 09:56 evt_IdsEventStore3
prw-rw----    1 cids     cids            0 Mar 14 20:39 evt_IdsEventStore4
prw-rw----    1 cids     cids            0 Mar 15 09:54 evt_IpFifo_logAppFifo
prw-rw----    1 cisco    cids            0 Mar 15 09:42 evt_ct--cidcli.32147
prw-rw----    1 cids     cids            0 Mar 15 09:56 evt_ct-mainApp.343
prw-rw----    1 cids     cids            0 Mar 15 09:54 evt_ct-sensorApp.460
prw-rw----    1 cids     cids            0 Feb  7 09:19 evt_mainAppEventSensorUp
prw-rw----    1 cids     cids            0 Feb  7 09:03 evt_sensorAppRestartRequest
prw-rw----    1 cisco    cids            0 Mar 15 09:42 pipe_fmSrvr_ct--cidcli.32147
prw-rw----    1 cids     cids            0 Mar 15 09:56 pipe_fmSrvr_ct-mainApp.343
prw-rw----    1 cids     cids            0 Mar 15 09:54 pipe_fmSrvr_ct-sensorApp.460
prw-rw----    1 cisco    cids            0 Mar 15 09:42 pipe_toSrvr_ct--cidcli.32147
prw-rw----    1 cids     cids            0 Mar 15 09:56 pipe_toSrvr_ct-mainApp.343
prw-rw----    1 cids     cids            0 Mar 15 09:54 pipe_toSrvr_ct-sensorApp.460
-rw-rw----    1 cids     cids            0 Feb  7 09:04 sem_CidsSharedIoctlSem
-rw-rw----    1 cids     cids            0 Mar 15 09:42 sem_IdsEventStoreSem
-rw-rw----    1 cids     cids            0 Mar 15 09:54 sem_IpFifo_logAppFifo
-rw-rw----    1 cids     cids            0 Mar 15 09:54 sem_LogConfigManager
-rw-rw----    1 cids     cids            0 Feb  7 09:04 sem_accessTlsConfig
-rw-rw----    1 cisco    cids            0 Mar 15 09:42 sem_ct--cidcli.32147
-rw-rw----    1 cids     cids            0 Mar 15 09:58 sem_ct-mainApp.343
-rw-rw----    1 cids     cids            0 Mar 15 09:42 sem_ct-map
-rw-rw----    1 cids     cids            0 Mar 15 09:54 sem_ct-sensorApp.460
-rw-rw----    1 cids     cids            0 Mar 15 09:54 sem_curConfigFileSem
-rw-rw----    1 cids     cids            0 Feb  7 09:04 sem_evt_IdsEventStore0
-rw-rw----    1 cids     cids            0 Feb  7 09:04 sem_evt_IdsEventStore1
-rw-rw----    1 cids     cids            0 Feb  7 09:04 sem_evt_IdsEventStore2
-rw-rw----    1 cids     cids            0 Mar 15 09:42 sem_evt_IdsEventStore3
-rw-rw----    1 cids     cids            0 Mar 13 19:40 sem_evt_IdsEventStore4
-rw-rw----    1 cids     cids            0 Mar 15 09:54 sem_evt_IpFifo_logAppFifo
-rw-rw----    1 cisco    cids            0 Mar 15 09:42 sem_evt_ct--cidcli.32147
-rw-rw----    1 cids     cids            0 Mar 15 09:56 sem_evt_ct-mainApp.343
-rw-rw----    1 cids     cids            0 Mar 15 09:54 sem_evt_ct-sensorApp.460
-rw-rw----    1 cids     cids            0 Feb  7 09:19 sem_evt_mainAppEventSensorUp
-rw-rw----    1 cids     cids            0 Feb  7 09:03 sem_evt_sensorAppRestartRequest
-rw-rw----    1 cids     cids            0 Mar 15 09:42 sem_global-shm
-rw-rw----    1 cisco    cids            0 Mar 15 09:42 sem_pipe_ClntConnect_ct--cidcli.32147
-rw-rw----    1 cids     cids            0 Mar 15 09:56 sem_pipe_ClntConnect_ct-mainApp.343
-rw-rw----    1 cids     cids            0 Mar 15 09:54 sem_pipe_ClntConnect_ct-sensorApp.460
-rw-rw----    1 cisco    cids            0 Mar 15 09:42 sem_pipe_SrvrConnect_ct--cidcli.32147
-rw-rw----    1 cids     cids            0 Mar 15 09:56 sem_pipe_SrvrConnect_ct-mainApp.343
-rw-rw----    1 cids     cids            0 Mar 15 09:54 sem_pipe_SrvrConnect_ct-sensorApp.460
-rw-rw----    1 cids     cids            0 Mar 15 09:42 sem_shm_IdsEventStoreShm
-rw-rw----    1 cids     cids            0 Mar 15 09:54 sem_shm_IpFifo_logAppFifo
-rw-rw----    1 cids     cids            0 Mar 15 09:54 sem_shm_LogConfigManager
-rw-rw----    1 cids     cids            0 Mar 15 09:42 sem_shm_ct-map
-rw-rw----    1 cids     cids            0 Mar 15 09:42 sem_shm_global-data
-rw-rw----    1 cids     cids            0 Feb  7 09:03 sem_shm_licenseExpireDate
-rw-rw----    1 cids     cids            0 Feb  7 09:03 sem_upgradeCtSem
-rw-rw----    1 cids     cids            0 Feb  7 09:03 sem_upgradeLockSem
-rw-rw----    1 cids     cids            0 Feb  7 09:03 shm_IdsEventStoreShm
-rw-rw----    1 cids     cids            0 Feb  7 09:03 shm_IpFifo_logAppFifo
-rw-rw----    1 cids     cids            0 Feb  7 09:03 shm_LogConfigManager
-rw-rw----    1 cids     cids            0 Feb  7 09:03 shm_ct-map
-rw-rw----    1 cids     cids            0 Feb  7 09:03 shm_global-data
-rw-rw----    1 cisco    cids            0 Mar 15 09:42 shm_ipsdebug_cidcli
-rw-rw----    1 cids     cids            0 Feb  7 09:03 shm_ipsdebug_mainApp
-rw-rw----    1 cids     cids            0 Feb  9 17:04 shm_ipsdebug_sendCtlTrans
-rw-rw----    1 cids     cids            0 Feb  7 09:04 shm_ipsdebug_sensorApp
-rw-rw----    1 cids     cids            0 Feb  7 09:03 shm_licenseExpireDate
/usr/cids/idsRoot/var:
drwxrwxr-x    5 cids     cids         1024 Mar 14 13:13 .
-rw-rw-rw-    1 cids     cids          145 Jan 20 21:13 H225Q931Regex2.pmz
-rw-rw-rw-    1 cids     cids          308 Jan 20 21:13 H225SetupRegex1.pmz
-rw-rw-rw-    1 cids     cids         3665 Jan 20 21:12 application-policy-enforcement-http.ctm1.pmz
-rw-rw-rw-    1 cids     cids         1368 Jan 20 21:12 application-policy-enforcement-http.ctv1.pmz
-rw-rw-rw-    1 cids     cids         1629 Oct 17 11:12 application-policy-enforcement-http.met1.pmz
-rw-rw-rw-    1 cids     cids          499 Oct 17 11:12 application-policy-enforcement-http.xfr1.pmz
-rw-rw-rw-    1 cids     cids         1606 Oct 17 11:12 application.policy.enforcement.ftp1.pmz
-rw-rw-rw-    1 cids     cids         8882 Mar 13 13:09 atomic-ip-advanced.pmz
drwxrwxrwt    2 root     root           80 Feb  7 09:03 eventStore
-rw-r--r--    1 root     root       554011 Feb  7 09:01 events.tar.gz
-rw-rw-rw-    1 cids     cids         1770 Mar  7 15:11 fixed-tcp.pmz
-rw-rw-rw-    1 cids     cids           69 Jan 19 15:12 fixed-udp.pmz
drwxrwxrwt    2 root     root          480 Feb  7 09:19 iplogs
-rw-rw-rw-    1 cids     cids      1134990 Mar 13 13:14 multi-string-tcp.pmz
-rw-rw-rw-    1 cids     cids         1833 Dec 13 15:12 multi-string-udp.pmz
-rw-rw-rw-    1 cids     cids           86 Feb  7 09:01 nac.shun.txt
-rw-rw-rw-    1 cids     cids      1558315 Mar 13 13:12 service-http.pmz
-rw-rw-rw-    1 cids     cids         1632 Oct 17 11:27 state.pmz
-rw-rw-rw-    1 cids     cids      1009242 Mar 14 13:13 string-tcp.pmz
drwxrwxr-x    6 cids     cids         1024 Mar 14 13:13 updates
/usr/cids/idsRoot/var/eventStore:
drwxrwxrwt    2 root     root           80 Feb  7 09:03 .
drwxrwxr-x    5 cids     cids         1024 Mar 14 13:13 ..
-rw-rw----    1 cids     cids     10000000 Mar 15 09:56 IdsEventStore
-rw-rw-rw-    1 cids     cids          110 Feb  7 09:03 IdsEventStoreData
/usr/cids/idsRoot/var/iplogs:
drwxrwxrwt    2 root     root          480 Feb  7 09:19 .
-rw-r--r--    1 cids     cids      1003520 Feb  9 03:48 00000
-rw-r--r--    1 cids     cids      1003520 Feb  9 03:48 00001
-rw-r--r--    1 cids     cids      1003520 Feb  9 03:48 00002
-rw-r--r--    1 cids     cids      1003520 Feb 27 13:34 00003
-rw-r--r--    1 cids     cids      1003520 Feb 27 13:34 00004
-rw-r--r--    1 cids     cids      1003520 Feb 27 13:34 00005
-rw-r--r--    1 cids     cids      1003520 Mar  1 04:03 00006
-rw-r--r--    1 cids     cids      1003520 Mar  1 04:03 00007
-rw-r--r--    1 cids     cids      1003520 Mar  1 04:03 00008
-rw-r--r--    1 cids     cids      1003520 Mar  2 16:28 00009
-rw-r--r--    1 cids     cids      1003520 Mar  2 16:28 00010
-rw-r--r--    1 cids     cids      1003520 Mar  2 16:28 00011
-rw-r--r--    1 cids     cids      1003520 Mar 12 07:54 00012
-rw-r--r--    1 cids     cids      1003520 Mar 12 07:54 00013
-rw-r--r--    1 cids     cids      1003520 Mar 12 07:54 00014
-rw-r--r--    1 cids     cids      1000000 Feb  7 09:19 00015
-rw-r--r--    1 cids     cids      1000000 Feb  7 09:19 00016
-rw-r--r--    1 cids     cids      1000000 Feb  7 09:19 00017
-rw-r--r--    1 cids     cids      1000000 Feb  7 09:19 00018
-rw-r--r--    1 cids     cids      1000000 Feb  7 09:19 00019
-rw-rw-rw-    1 cids     cids          771 Mar 12 07:54 directory
-rw-rw-rw-    1 cids     cids         1475 Mar 12 07:54 index
/usr/cids/idsRoot/var/updates:
drwxrwxr-x    6 cids     cids         1024 Mar 14 13:13 .
drwxr-xr-x    2 cids     cids         1024 Mar 14 13:07 backups
drwxr-xr-x    2 cids     cids         1024 Mar 14 13:13 download
drwxr-xr-x    2 cids     cids         1024 Mar 14 13:13 logs
-rw-r--r--    1 cids     cids          183 Mar 14 13:13 package
drwxr-xr-x    2 cids     cids         1024 Mar 14 13:03 scripts
/usr/cids/idsRoot/var/updates/backups:
drwxr-xr-x    2 cids     cids         1024 Mar 14 13:07 .
drwxrwxr-x    6 cids     cids         1024 Mar 14 13:13 ..
-rw-r--r--    1 root     cids       191709 Mar 14 13:07 SigCategories.xml.gz
-rw-r--r--    1 root     cids          545 Mar 14 13:07 default.sig.xml.gz
-rw-r--r--    1 root     cids       805966 Mar 14 13:07 default.xml.gz
-rw-r--r--    1 root     cids          793 Mar 14 13:07 history.gz
-rw-r--r--    1 root     cids         1312 Mar 14 13:07 instances.tar.gz
-rw-r--r--    1 root     cids          135 Mar 14 13:07 package.gz
/usr/cids/idsRoot/var/updates/download:
drwxr-xr-x    2 cids     cids         1024 Mar 14 13:13 .
/usr/cids/idsRoot/var/updates/logs:
-rw-r--r--    1 cids     cids        62453 Apr 19  2011 Pre6234cidDump.html.gz
-rw-r--r--    1 cids     cids        62425 Oct 17 10:49 Pre6244cidDump.html.gz
-rw-rw-rw-    1 cids     cids         4211 Mar 14 13:13 history
-rw-rw-rw-    1 cids     cids         4035 Mar 14 13:13 install.log
-rw-r--r--    1 cids     cids        15258 Mar 14 13:03 sensorApp_status_check.log
/usr/cids/idsRoot/var/updates/scripts:
drwxr-xr-x    2 cids     cids         1024 Mar 14 13:03 .
-rwxr-xr-x    1 cids     cids        13521 Mar 13 15:22 IPS-sig-S632-req-E4.pkg
-rwxr-xr-x    1 cids     cids          478 Mar 13 15:22 file_list
-rwxr-xr-x    1 cids     cids         7489 Mar 13 15:22 installFunctions
-rwxr-xr-x    1 cids     cids         5750 Mar 13 15:22 installer
exec: ls -alR /root
/root:
drwxrwxr-x    4 root     root         1024 Feb  7 09:04 .
drwxr-xr-x   17 root     root         1024 Mar 15 09:56 ..
drwxrwxr-x    2 root     root         1024 Jun 23  2011 .gnupg
drwx------    2 root     cids         1024 Feb  7 09:04 .ssh
/root/.gnupg:
drwxrwxr-x    4 root     root         1024 Feb  7 09:04 ..
-r--r--r--    1 root     root          925 Dec 15  2008 pubring.gpg
-r--r--r--    1 root     root            0 Dec 15  2008 secring.gpg
-r--r--r--    1 root     root         1280 Dec 15  2008 trustdb.gpg
/root/.ssh:
-rw-r--r--    1 root     root            0 Feb  7 09:04 known_hosts
exec: ls -alR /home
/home:
drwxr-xr-x    5 root     root         1024 Oct 17 10:57 .
drwx------    3 cisco    cids         1024 Oct 17 11:01 cisco
drwxr-x---    3 eventVie cids         1024 Oct 17 10:57 eventViewer
drwxr-x---    3 service  cids         1024 Oct 17 10:57 service
/home/cisco:
drwx------    3 cisco    cids         1024 Oct 17 11:01 .
drwxr-xr-x    5 root     root         1024 Oct 17 10:57 ..
drwx------    2 cisco    cids         1024 Oct 17 11:01 .ssh
/home/cisco/.ssh:
drwx------    3 cisco    cids         1024 Oct 17 11:01 ..
-rw-r--r--    1 cisco    cids            0 Feb  7 09:04 known_hosts
/home/eventViewer:
drwxr-x---    3 eventVie cids         1024 Oct 17 10:57 .
drwx------    2 eventVie cids         1024 Oct 17 11:01 .ssh
/home/eventViewer/.ssh:
drwxr-x---    3 eventVie cids         1024 Oct 17 10:57 ..
-rw-r--r--    1 eventVie cids            0 Feb  7 09:04 known_hosts
/home/service:
drwxr-x---    3 service  cids         1024 Oct 17 10:57 .
-rw-r-----    1 cids     cids           68 Jan 13  2011 .bash_profile
drwx------    2 service  cids         1024 Oct 17 11:01 .ssh
/home/service/.ssh:
drwxr-x---    3 service  cids         1024 Oct 17 10:57 ..
-rw-r--r--    1 service  cids            0 Feb  7 09:04 known_hosts
exec: cat /usr/cids/idsRoot/etc/boot.info.diff
Cisco IDS 6.2(4)E4 Boot Information FileCisco IDS 6.2(4)E4 Boot Information File
bootTime=Mon Oct 17 15:59:11 UTC 2011      |bootTime=Mon Oct 17 15:57:41 UTC 2011
[Platform][Platform]
   platform=module   platform=module
   host=PC   host=PC
   model=SSC-IPS5   model=SSC-IPS5
[DefaultCommandControl][DefaultCommandControl]
   os-name=ma0_0   os-name=ma0_0
   cids-name=Management0/0   cids-name=Management0/0
[Partition][Partition]
   partitionType=application   partitionType=application
[Operating System][Operating System]
   os=2.4.30-IDS-smp-bigphys   os=2.4.30-IDS-smp-bigphys
[CIDS][CIDS]
   version=6.2(4)E4   version=6.2(4)E4
[cpu/0][cpu/0]
   vendor=AuthenticAMD   vendor=AuthenticAMD
   family=5   family=5
   model=10   model=10
   modelName=Geode(TM) Integrated Processor by AMD   modelName=Geode(TM) Integrated Processor by AMD
   speedMHz=498   speedMHz=498
[memory][memory]
   physicalKB=477928      |   physicalKB=510696
   virtualKB=0   virtualKB=0
[drive/hda][drive/hda]
   media=disk   media=disk
   model=VI 512MB   model=VI 512MB
   controller=ide0   controller=ide0
   physicalGeometry=1007/16/63   physicalGeometry=1007/16/63
   logicalGeometry=1007/16/63   logicalGeometry=1007/16/63
[scsi][scsi]
[NetAccelerator][NetAccelerator]
   acceleratorType=none   acceleratorType=none
   state=normal      |   state=unknown
[IP logging][IP logging]
   NumberOfLogFiles=20   NumberOfLogFiles=20
   SizeOfLogFiles=1000000   SizeOfLogFiles=1000000
   MaxOpenLogFiles=20   MaxOpenLogFiles=20
   MaxIplogSize=20   MaxIplogSize=20
[Sensor][Sensor]
   MaxSensorMemory=300000   MaxSensorMemory=300000
; possible capabilities: {inline, setTime, configSerialAccess; possible capabilities: {inline, setTime, configSerialAccess
[IPS-4240/Capabilities][IPS-4240/Capabilities]
   inline=yes   inline=yes
   inline-interfaces=yes   inline-interfaces=yes
   subinterfaces=yes   subinterfaces=yes
   setTime=yes   setTime=yes
   showInventory=yes   showInventory=yes
   promiscuous=yes   promiscuous=yes
   logicalSubinterfaces=yes   logicalSubinterfaces=yes
   virtualPolicies=yes   virtualPolicies=yes
   retrieveSentinelLM=yes   retrieveSentinelLM=yes
[IPS-4255/Capabilities][IPS-4255/Capabilities]
[IPS-4260/Capabilities][IPS-4260/Capabilities]
[IPS-4270/Capabilities][IPS-4270/Capabilities]
[WS-SVC-IDSM2-BUN/Capabilities][WS-SVC-IDSM2-BUN/Capabilities]
[SSM-IPS10/Capabilities][SSM-IPS10/Capabilities]
[SSM-IPS20/Capabilities][SSM-IPS20/Capabilities]
[AIM-IPS/Capabilities][AIM-IPS/Capabilities]
[NM-IPS/Capabilities][NM-IPS/Capabilities]
[SSM-IPS40/Capabilities][SSM-IPS40/Capabilities]
[SSC-IPS2/Capabilities][SSC-IPS2/Capabilities]
   noUnretireDefaultRetiredSignature=yes   noUnretireDefaultRetiredSignature=yes
   noAnomalyDetection=yes   noAnomalyDetection=yes
   enableWatchdog=yes   enableWatchdog=yes
[SSC-IPS5/Capabilities][SSC-IPS5/Capabilities]
exec: cat /usr/cids/idsRoot/etc/cidsZoneInfo.txt
# This zone info file created by mainApp to be used with zic
# Rule  NAME    FROM    TO      TYPE    IN      ON      AT     SAVE   LETTER/S
Rule    Cids    1918   2038      -      march     sunday>=8    02:00    1:00   -
Rule    Cids    1918   2038      -      november     sunday>=1    02:00     0     -
# Zone  NAME            UTCOFF  RULES   FORMAT
Zone  cidsZoneInfo      -6:00   Cids   GMT-06:00/UTC
exec: cat /usr/cids/idsRoot/shared/ips.lic
update1.0ASA-SSC-AIP-5JAF1442BDBNCisco HQ2012-01-05T16:28:38/ex8V7qR0DfiP2camhmXVf/lySw=PERMANENT2013-01-06T00:00:00YES11 update 1.0 LONG NORMAL STANDALONE EXCL INFINITE_KEYS INFINITE_KEYS NEVER 6 JAN 2013 NiL SLM_CODE CL_ND_LCK NiL *1TRUTZ9BYDB97JG400 NiL NiL NiL 5_MINS <UDI><PID>ASA-SSC-AIP-5</PID><SN>JAF1442BDBN</SN></UDI><GRACE>60</GRACE> D00EGzXaLZ,Cw5Oz1X:nfRLHHVEzR3O,pCmDcIaKrJfFUe9TQpmDEdhCSwveicN8V8TrliDpL0dCEpY4d1aWFQLNwthHVwrQB:kvHRBsnQ5jLvecXCaHvM2MiHfY6dBqa1VZSwxsSXlj2GxzdTw2VFUhfh$<WLC>AQEBIf8B//9t7RlS2eT8pms7CEvSeP/6wAj5l+h4dt7CUM1OqGfDTxjXyQA0YmTarh5061VP/hlHebPkGlARtYd1UQO7GJ3KnufZ9oZ6JdFniDf5HrQ8DrXdpCz5RgZE+y8fbN200xiXA5cB3fwcJqoPIFZm2HmD1qFfsyTAzuio66t6Xk5y8xo1lbVhvoh/FZfy5iRY3oE=</WLC>]]&gt;</LICENSE_LINE><USER_MODIFIABLE_COMMENT fieldRestrictions="Max 99 ASCII characters in length."></USER_MODIFIABLE_COMMENT></CISCO_WT_LICENSE></p><p></CISCO_WT_ARTIFACTS></p><p>exec: cat /usr/cids/idsRoot/var/updates/package</p><p>PACKAGE_NAME:IPS-sig-S632-req-E4</p><p>FILE_NAME:IPS-sig-S632-req-E4.pkg</p><p>CURRENT_TIMESTAMP:2012_Mar_14_13.03.38</p><p>PREVIOUS_VERSION:IPS-sig-S631-req-E4</p><p>PREVIOUS_TIMESTAMP:2012_Mar_13_13.03.37</p><p>exec: cat /usr/cids/idsRoot/var/updates/logs/history</p><p>||Base Image Install</p><p>IPS-sig-S540-req-E4.pkg||2011_Jan_18_15.50.41</p><p>IPS-sig-S542-req-E4.pkg||2011_Jan_25_15.19.32</p><p>IPS-sig-S543-req-E4.pkg||2011_Jan_27_19.19.28</p><p>IPS-sig-S544-req-E4.pkg||2011_Jan_31_19.19.33</p><p>IPS-sig-S545-req-E4.pkg||2011_Feb_02_11.19.35</p><p>IPS-sig-S546-req-E4.pkg||2011_Feb_08_13.19.27</p><p>IPS-sig-S547-req-E4.pkg||2011_Feb_09_15.19.30</p><p>IPS-sig-S549-req-E4.pkg||2011_Feb_21_15.29.26</p><p>IPS-sig-S550-req-E4.pkg||2011_Feb_25_17.29.25</p><p>IPS-sig-S551-req-E4.pkg||2011_Mar_01_19.29.26</p><p>IPS-sig-S553-req-E4.pkg||2011_Mar_18_09.03.40</p><p>IPS-sig-S554-req-E4.pkg||2011_Mar_21_15.03.36</p><p>IPS-sig-S555-req-E4.pkg||2011_Mar_29_13.03.36</p><p>IPS-sig-S556-req-E4.pkg||2011_Mar_30_13.03.36</p><p>IPS-sig-S557-req-E4.pkg||2011_Apr_06_23.03.35</p><p>IPS-sig-S558-req-E4.pkg||2011_Apr_12_13.03.42</p><p>IPS-sig-S559-req-E4.pkg||2011_Apr_12_21.03.42</p><p>IPS-sig-S560-req-E4.pkg||2011_Apr_18_17.03.36</p><p>IPS-SSC_5-K9-6.2-3-E4.pkg||2011_Apr_19_09.03.35</p><p>IPS-sig-S561-req-E4.pkg||2011_Apr_21_18.03.37</p><p>IPS-sig-S562-req-E4.pkg||2011_Apr_27_12.03.36</p><p>IPS-sig-S563-req-E4.pkg||2011_Apr_28_16.03.39</p><p>IPS-sig-S564-req-E4.pkg||2011_May_03_20.03.37</p><p>IPS-sig-S565-req-E4.pkg||2011_May_06_18.03.40</p><p>IPS-sig-S566-req-E4.pkg||2011_May_10_17.03.39</p><p>IPS-sig-S567-req-E4.pkg||2011_May_24_13.03.41</p><p>IPS-sig-S568-req-E4.pkg||2011_May_25_13.03.41</p><p>IPS-sig-S569-req-E4.pkg||2011_May_26_11.03.37</p><p>IPS-sig-S570-req-E4.pkg||2011_May_27_13.03.38</p><p>IPS-sig-S571-req-E4.pkg||2011_Jun_01_11.03.40</p><p>IPS-sig-S572-req-E4.pkg||2011_Jun_07_15.03.42</p><p>IPS-sig-S573-req-E4.pkg||2011_Jun_13_09.03.36</p><p>IPS-sig-S574-req-E4.pkg||2011_Jun_14_15.03.36</p><p>IPS-sig-S575-req-E4.pkg||2011_Jun_20_19.03.36</p><p>IPS-sig-S576-req-E4.pkg||2011_Jun_21_15.03.42</p><p>IPS-sig-S577-req-E4.pkg||2011_Jun_24_15.03.43</p><p>IPS-sig-S578-req-E4.pkg||2011_Jun_29_15.03.38</p><p>IPS-sig-S579-req-E4.pkg||2011_Jul_05_09.03.38</p><p>IPS-sig-S580-req-E4.pkg||2011_Jul_06_13.03.38</p><p>IPS-sig-S581-req-E4.pkg||2011_Jul_12_13.03.40</p><p>IPS-sig-S582-req-E4.pkg||2011_Jul_14_17.03.37</p><p>IPS-sig-S583-req-E4.pkg||2011_Jul_22_17.03.37</p><p>IPS-sig-S584-req-E4.pkg||2011_Jul_26_13.03.39</p><p>IPS-sig-S585-req-E4.pkg||2011_Jul_28_15.03.38</p><p>IPS-sig-S586-req-E4.pkg||2011_Jul_29_17.03.37</p><p>IPS-sig-S587-req-E4.pkg||2011_Aug_03_19.03.38</p><p>IPS-sig-S589-req-E4.pkg||2011_Aug_17_17.03.37</p><p>IPS-sig-S590-req-E4.pkg||2011_Aug_24_13.03.40</p><p>IPS-sig-S591-req-E4.pkg||2011_Aug_26_15.03.39</p><p>IPS-sig-S592-req-E4.pkg||2011_Aug_31_13.03.42</p><p>IPS-sig-S593-req-E4.pkg||2011_Sep_07_17.03.41</p><p>IPS-sig-S594-req-E4.pkg||2011_Sep_13_15.03.38</p><p>IPS-sig-S595-req-E4.pkg||2011_Sep_14_13.03.35</p><p>IPS-sig-S596-req-E4.pkg||2011_Sep_20_13.03.37</p><p>IPS-sig-S597-req-E4.pkg||2011_Sep_22_15.03.36</p><p>IPS-sig-S598-req-E4.pkg||2011_Sep_28_13.03.38</p><p>IPS-sig-S599-req-E4.pkg||2011_Sep_30_23.03.36</p><p>IPS-sig-S600-req-E4.pkg||2011_Oct_05_13.03.39</p><p>IPS-sig-S601-req-E4.pkg||2011_Oct_11_15.03.37</p><p>IPS-sig-S602-req-E4.pkg||2011_Oct_14_17.03.36</p><p>IPS-SSC_5-K9-6.2-4-E4.pkg||2011_Oct_17_10.46.13</p><p>IPS-sig-S603-req-E4.pkg||2011_Oct_19_12.03.57</p><p>IPS-sig-S604-req-E4.pkg||2011_Oct_24_16.03.40</p><p>IPS-sig-S605-req-E4.pkg||2011_Oct_26_13.03.39</p><p>IPS-sig-S606-req-E4.pkg||2011_Nov_02_13.03.46</p><p>IPS-sig-S607-req-E4.pkg||2011_Nov_03_13.03.40</p><p>IPS-sig-S608-req-E4.pkg||2011_Nov_08_13.03.45</p><p>IPS-sig-S609-req-E4.pkg||2011_Nov_17_13.03.40</p><p>IPS-sig-S610-req-E4.pkg||2011_Nov_28_19.03.38</p><p>IPS-sig-S611-req-E4.pkg||2011_Dec_06_15.03.43</p><p>IPS-sig-S612-req-E4.pkg||2011_Dec_13_15.03.42</p><p>IPS-sig-S613-req-E4.pkg||2011_Dec_20_17.03.39</p><p>IPS-sig-S614-req-E4.pkg||2011_Dec_23_21.03.38</p><p>IPS-sig-S615-req-E4.pkg||2012_Jan_05_15.03.39</p><p>IPS-sig-S616-req-E4.pkg||2012_Jan_10_13.03.44</p><p>IPS-sig-S617-req-E4.pkg||2012_Jan_12_19.03.43</p><p>IPS-sig-S618-req-E4.pkg||2012_Jan_13_21.03.50</p><p>IPS-sig-S619-req-E4.pkg||2012_Jan_17_21.03.38</p><p>IPS-sig-S620-req-E4.pkg||2012_Jan_19_15.03.40</p><p>IPS-sig-S621-req-E4.pkg||2012_Jan_20_21.03.43</p><p>IPS-sig-S622-req-E4.pkg||2012_Jan_26_15.03.40</p><p>IPS-sig-S623-req-E4.pkg||2012_Feb_02_15.03.45</p><p>IPS-sig-S624-req-E4.pkg||2012_Feb_09_17.03.53</p><p>IPS-sig-S625-req-E4.pkg||2012_Feb_14_13.03.41</p><p>IPS-sig-S626-req-E4.pkg||2012_Feb_16_01.03.42</p><p>IPS-sig-S627-req-E4.pkg||2012_Feb_23_15.03.38</p><p>IPS-sig-S628-req-E4.pkg||2012_Feb_24_23.03.38</p><p>IPS-sig-S629-req-E4.pkg||2012_Feb_29_13.03.45</p><p>IPS-sig-S630-req-E4.pkg||2012_Mar_07_15.03.38</p><p>IPS-sig-S631-req-E4.pkg||2012_Mar_13_13.03.37</p><p>IPS-sig-S632-req-E4.pkg||2012_Mar_14_13.03.38</p><p>exec: cat /usr/cids/idsRoot/var/updates/logs/install.log</p><p>*********************</p><p>Wed Mar 14 13:03:41 UTC 2012</p><p>IPS-sig-S632-req-E4.pkg -i /usr/cids/idsRoot/var/updates/download/IPS-sig-S632-req-E4</p><p>*********************</p><p></p><p>Source ids_functions</p><p>Check usage.</p><p>Check usage parameters.</p><p>Check to see if mainApp should be shutdown.</p><p>Checking to see if sensorApp is busy Wed Mar 14 13:03:46 UTC 2012</p><p>Check complete Wed Mar 14 13:03:47 UTC 2012</p><p>If -i run install.</p><p>Running upgrade install.</p><p>Currently installed signature version is       631</p><p>Checking to see if  is installed</p><p>Checking to see if IPS-sig-S632-req-E4.pkg is already installed</p><p>Checking to see if currently installed version is newer.</p><p>Checking disk space</p><p>Filesystem           1k-blocks      Used Available Use% Mounted on</p><p>/dev/ramdisk             39428     18583     20845  47% /</p><p>/dev/hda2               170821     43958    118043  27% /mnt/rw</p><p>/dev/hda2               170821     43958    118043  27% /dev</p><p>/dev/hda2               170821     43958    118043  27% /etc</p><p>/dev/hda2               170821     43958    118043  27% /home</p><p>/dev/hda2               170821     43958    118043  27% /usr/cids</p><p>/dev/hda2               170821     43958    118043  27% /lib/modules</p><p>/dev/boot                70247     41809     24811  63% /boot</p><p>none                      5120         8      5112   0% /tmp</p><p>none                      8192        52      8140   1% /var</p><p>none                 17592186040320         0 17592186040320   0% /mnt/huge</p><p>none                    525312     19768    505544   4% /usr/cids/idsRoot/var/iplogs</p><p>none                    533504         4    533500   0% /usr/cids/idsRoot/tmp</p><p>none                     31744      9788     21956  31% /usr/cids/idsRoot/var/eventStore</p><p>Installing /usr/cids/idsRoot/var/updates/download/IPS-sig-S632-req-E4</p><p>Storing previous install info.</p><p>Untaring /usr/cids/idsRoot/var/updates/download/IPS-sig-S632-req-E4.</p><p>Filesystem           1k-blocks      Used Available Use% Mounted on</p><p>/dev/ramdisk             39428     18583     20845  47% /</p><p>/dev/hda2               170821     43959    118042  27% /mnt/rw</p><p>/dev/hda2               170821     43959    118042  27% /dev</p><p>/dev/hda2               170821     43959    118042  27% /etc</p><p>/dev/hda2               170821     43959    118042  27% /home</p><p>/dev/hda2               170821     43959    118042  27% /usr/cids</p><p>/dev/hda2               170821     43959    118042  27% /lib/modules</p><p>/dev/boot                70247     41809     24811  63% /boot</p><p>none                      5120         8      5112   0% /tmp</p><p>none                      8192        52      8140   1% /var</p><p>none                 17592186040320         0 17592186040320   0% /mnt/huge</p><p>none                    525312     19768    505544   4% /usr/cids/idsRoot/var/iplogs</p><p>none                    533504         4    533500   0% /usr/cids/idsRoot/tmp</p><p>none                     31744      9788     21956  31% /usr/cids/idsRoot/var/eventStore</p><p>backups</p><p>download</p><p>download/foo.hdr</p><p>download/idsPackageMgr</p><p>files</p><p>files/common</p><p>files/common/edc.full.xml</p><p>files/common/SigCategories.xml.gz</p><p>scripts</p><p>scripts/IPS-sig-S632-req-E4.pkg</p><p>scripts/installer</p><p>scripts/installFunctions</p><p>scripts/file_list</p><p>Sourcing ids_functions from install directory.</p><p>Determining Model.</p><p>Model is SSC-IPS5.</p><p></p><p></p><p>Counter at 0</p><p>Wed Mar 14 13:03:57 UTC 2012</p><p></p><p>SensorApp running.</p><p>File installer running...</p><p>File installer Version 1.1</p><p>Archiving /usr/cids/idsRoot/var/updates/package</p><p>Archiving /usr/cids/idsRoot/var/updates/logs/history</p><p>Archiving /usr/cids/idsRoot/etc/config/signatureDefinition/default.sig.xml</p><p>Archiving /usr/cids/idsRoot/etc/config/signatureDefinition/default.xml</p><p>Archiving /usr/cids/idsRoot/etc/SigCategories.xml</p><p>Installing /usr/cids/idsRoot/etc/SigCategories.xml</p><p>un-gziping SigCategories.xml.gz</p><p>gunzip exit status is 0</p><p>Setting file permissions</p><p>tar: Removing leading '/' from member names</p><p>Updating signatures.</p><p>Sending signature edc.</p><p>IDS file updates complete.</p><p>Cleaning up.</p><p></p><p>Exit install portion</p><p>Syncing.</p><p></p><p>Checking to see if error log empty.</p><p>Removing empty error log.</p><p>If system is an IDS-4215 or NM-CIDS, check to see if system swapped.</p><p>***********</p><p>exec: cat /usr/cids/idsRoot/var/updates/logs/sensorApp_status_check.log</p><p>Sending request:</p><p><span><?xml version="1.0" encoding="UTF-8" standalone="yes"?><request xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idiom" rel="nofollow">http://www.cisco.com/cids/idiom</a><span>" schemaVersion="2.00"></request></span></p><p>received response:</p><p><?xml version="1.0" encoding="UTF-8" standalone="yes"?></p><p><span><response xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idiom" rel="nofollow">http://www.cisco.com/cids/idiom</a><span>" schemaVersion="2.00"></span></p><p>  <respGetStatistics></p><p>    <section name="AnalysisEngineStatistics" title="Analysis Engine Statistics"></p><p>      <token name="Uptime" title="Number of seconds since service started">3120849</token></p><p>      <token name="Connections/Second" title="The rate of TCP connections tracked per second">0</token></p><p>      <token name="Packets/Sec" title="The rate of packets per second">47</token></p><p>      <token name="Bytes/Second" title="The rate of bytes per second">697</token></p><p>      <section name="ReceiverStats" title="Receiver Statistics"></p><p>        <token name="TotalPackets" title="Total number of packets processed since reset">147730242</token></p><p>        <token name="IpPackets" title="Total number of IP packets processed since reset">147730242</token></p><p>      </section></p><p>      <section name="TransmitterStats" title="Transmitter Statistics"></p><p>        <token name="TransmittedPackets" title="Total number of packets transmitted">148854814</token></p><p>        <token name="DeniedPackets" title="Total number of packets denied">70</token></p><p>        <token name="ResetPackets" title="Total number of packets reset">80</token></p><p>      </section></p><p>      <section name="FRU" title="Fragment Reassembly Unit Statistics"></p><p>        <token name="currentFragmentsHeld" title="Number of fragments currently in FRU">0</token></p><p>        <token name="currentPartialDatagrams" title="Number of datagrams currently in FRU">0</token></p><p>      </section></p><p>      <section name="StreamReassemblyUnit" title="TCP Stream Reassembly Unit Statistics"></p><p>        <token name="embryonicStreams" title="TCP streams currently in the embryonic state">0</token></p><p>        <token name="establishedStreams" title="TCP streams currently in the established state">0</token></p><p>        <token name="closingStreams" title="TCP streams currently in the closing state">0</token></p><p>        <token name="currentStreams" title="TCP streams currently in the system">0</token></p><p>        <token name="CurrentQueuedPackets" title="TCP Packets currently queued for reassembly">0</token></p><p>      </section></p><p>      <section name="SignatureDBStats" title="The Signature Database Statistics."></p><p>        <token name="Total" title="Total nodes active">4280</token></p><p>        <token name="TCPAaBb" title="TCP nodes keyed on both IP addresses and both ports">1158</token></p><p>        <token name="UDPAaBb" title="UDP nodes keyed on both IP addresses and both ports">0</token></p><p>        <token name="AxBx" title="IP nodes keyed on both IP addresses">204</token></p><p>      </section></p><p>      <section name="SigEvents" title="Statistics for Signature Events"></p><p>        <token name="TotalEvents" title="Number of SigEvents since reset">473050</token></p><p>      </section></p><p>      <section name="ActionsExecuted" title="Statistics for Actions executed on a SigEvent"></p><p>        <token name="produceAlert" title="Number of Alerts written to the IdsEventStore">671</token></p><p>      </section></p><p>      <section name="Inspection Stats" title="Inspection Stats" format="table"></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">AtomicAdvanced</token></p><p>          <token name="active" title="active">1</token></p><p>          <token name="call" title="call">147720536</token></p><p>          <token name="create" title="create">1</token></p><p>          <token name="delete" title="delete">0</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">12</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">Fixed</token></p><p>          <token name="active" title="active">324</token></p><p>          <token name="call" title="call">8204521</token></p><p>          <token name="create" title="create">5390982</token></p><p>          <token name="delete" title="delete">5390658</token></p><p>          <token name="createPerPktPct" title="createPct">3</token></p><p>          <token name="callPerPktPct" title="callPct">5</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">MSRPC_TCP</token></p><p>          <token name="active" title="active">11</token></p><p>          <token name="call" title="call">5636700</token></p><p>          <token name="create" title="create">1065371</token></p><p>          <token name="delete" title="delete">1065360</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">3</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">MSRPC_UDP</token></p><p>          <token name="active" title="active">0</token></p><p>          <token name="call" title="call">2136625</token></p><p>          <token name="create" title="create">1053733</token></p><p>          <token name="delete" title="delete">1053733</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">1</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">MultiString</token></p><p>          <token name="active" title="active">1272</token></p><p>          <token name="call" title="call">24217754</token></p><p>          <token name="create" title="create">3222862</token></p><p>          <token name="delete" title="delete">3221590</token></p><p>          <token name="createPerPktPct" title="createPct">2</token></p><p>          <token name="callPerPktPct" title="callPct">16</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">MultiStringSP</token></p><p>          <token name="active" title="active">0</token></p><p>          <token name="call" title="call">2031</token></p><p>          <token name="create" title="create">822</token></p><p>          <token name="delete" title="delete">822</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">0</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceDnsUdp</token></p><p>          <token name="active" title="active">1</token></p><p>          <token name="call" title="call">2136625</token></p><p>          <token name="create" title="create">1</token></p><p>          <token name="delete" title="delete">0</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">1</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceDnsTcp</token></p><p>          <token name="active" title="active">0</token></p><p>          <token name="call" title="call">290</token></p><p>          <token name="create" title="create">146</token></p><p>          <token name="delete" title="delete">146</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">0</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceFtp</token></p><p>          <token name="active" title="active">0</token></p><p>          <token name="call" title="call">1473</token></p><p>          <token name="create" title="create">86</token></p><p>          <token name="delete" title="delete">86</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">0</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceGeneric</token></p><p>          <token name="active" title="active">3</token></p><p>          <token name="call" title="call">149903097</token></p><p>          <token name="create" title="create">2183268</token></p><p>          <token name="delete" title="delete">2183265</token></p><p>          <token name="createPerPktPct" title="createPct">1</token></p><p>          <token name="callPerPktPct" title="callPct">14</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceHttp</token></p><p>          <token name="active" title="active">1023</token></p><p>          <token name="call" title="call">2457046</token></p><p>          <token name="create" title="create">1183613</token></p><p>          <token name="delete" title="delete">1182590</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">1</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceMsSql</token></p><p>          <token name="active" title="active">0</token></p><p>          <token name="call" title="call">7497</token></p><p>          <token name="create" title="create">4</token></p><p>          <token name="delete" title="delete">4</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">0</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceNtp</token></p><p>          <token name="active" title="active">0</token></p><p>          <token name="call" title="call">4273250</token></p><p>          <token name="create" title="create">2107466</token></p><p>          <token name="delete" title="delete">2107466</token></p><p>          <token name="createPerPktPct" title="createPct">1</token></p><p>          <token name="callPerPktPct" title="callPct">2</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceP2PUDP</token></p><p>          <token name="active" title="active">0</token></p><p>          <token name="call" title="call">86926</token></p><p>          <token name="create" title="create">80336</token></p><p>          <token name="delete" title="delete">80336</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">0</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceP2PTCP</token></p><p>          <token name="active" title="active">2</token></p><p>          <token name="call" title="call">4801535</token></p><p>          <token name="create" title="create">2183265</token></p><p>          <token name="delete" title="delete">2183263</token></p><p>          <token name="createPerPktPct" title="createPct">1</token></p><p>          <token name="callPerPktPct" title="callPct">3</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceRpcUDP</token></p><p>          <token name="active" title="active">1</token></p><p>          <token name="call" title="call">2136625</token></p><p>          <token name="create" title="create">1</token></p><p>          <token name="delete" title="delete">0</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">1</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceRpcTCP</token></p><p>          <token name="active" title="active">1148</token></p><p>          <token name="call" title="call">18355205</token></p><p>          <token name="create" title="create">2179476</token></p><p>          <token name="delete" title="delete">2178328</token></p><p>          <token name="createPerPktPct" title="createPct">1</token></p><p>          <token name="callPerPktPct" title="callPct">12</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceSMBAdvanced</token></p><p>          <token name="active" title="active">3</token></p><p>          <token name="call" title="call">2149076</token></p><p>          <token name="create" title="create">10074</token></p><p>          <token name="delete" title="delete">10071</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">1</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceSnmp</token></p><p>          <token name="active" title="active">1</token></p><p>          <token name="call" title="call">2136625</token></p><p>          <token name="create" title="create">1</token></p><p>          <token name="delete" title="delete">0</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">1</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">ServiceTNS</token></p><p>          <token name="active" title="active">1</token></p><p>          <token name="call" title="call">2153654</token></p><p>          <token name="create" title="create">2145688</token></p><p>          <token name="delete" title="delete">2145687</token></p><p>          <token name="createPerPktPct" title="createPct">1</token></p><p>          <token name="callPerPktPct" title="callPct">1</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">String</token></p><p>          <token name="active" title="active">1382</token></p><p>          <token name="call" title="call">36576325</token></p><p>          <token name="create" title="create">4196806</token></p><p>          <token name="delete" title="delete">4195424</token></p><p>          <token name="createPerPktPct" title="createPct">2</token></p><p>          <token name="callPerPktPct" title="callPct">24</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">SweepICMP</token></p><p>          <token name="active" title="active">9</token></p><p>          <token name="call" title="call">1089941</token></p><p>          <token name="create" title="create">73435</token></p><p>          <token name="delete" title="delete">73426</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">0</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">SweepTCP</token></p><p>          <token name="active" title="active">404</token></p><p>          <token name="call" title="call">288986532</token></p><p>          <token name="create" title="create">860041</token></p><p>          <token name="delete" title="delete">859637</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">21</token></p><p>        </section></p><p>        <section name="entry" title=""></p><p>          <token name="Inspector" title="Inspector">SweepOtherTcp</token></p><p>          <token name="active" title="active">204</token></p><p>          <token name="call" title="call">144493266</token></p><p>          <token name="create" title="create">442425</token></p><p>          <token name="delete" title="delete">442221</token></p><p>          <token name="createPerPktPct" title="createPct">0</token></p><p>          <token name="callPerPktPct" title="callPct">10</token></p><p>        </section></p><p>      </section></p><p>    </section></p><p>  </respGetStatistics></p><p></response></p><p>exec: cat /usr/cids/idsRoot/shared/host.conf</p><p>Cisco IDS 5.0 configuration file</p><p>[Network]</p><p>Interface=ma0_0</p><p>IpInterface=10.1.2.2/29,10.1.2.1</p><p>Hostname=IPS_Sensor</p><p>Telnet=disabled</p><p>[AccessListEntries/ACL0]</p><p>IpInterface=10.x.x.5/32</p><p>[AccessListEntries/ACL1]</p><p>IpInterface=10.x.x.69/32</p><p>[AccessListEntries/ACL2]</p><p>IpInterface=10.x.x.86/32</p><p>[AccessListEntries/ACL3]</p><p>IpInterface=10.x.x.117/32</p><p>[Time]</p><p>Offset=-360</p><p>StandardTimeZoneName=GMT-06:00</p><p>NtpServerIpAddr=10.x.x.5</p><p>NtpServerKeyId=</p><p>NtpServerKeyVal=</p><p>UnauthenticatedNtpServerIpAddr=</p><p>exec: cat /usr/cids/idsRoot/shared/ips.lic</p><p><?xml version="1.0" encoding="UTF-8"?><CISCO_WT_ARTIFACTS version="1.0"><CISCO_WT_LICENSE version="1.0"><FEATURE_NAME>update</FEATURE_NAME><FEATURE_VERSION>1.0</FEATURE_VERSION><UDI><PID>ASA-SSC-AIP-5</PID><SN>JAF1442BDBN</SN></UDI><SOURCE>Cisco HQ</SOURCE><CREATE_DATE>2012-01-05T16:28:38</CREATE_DATE><LICENSE_LINE_HASH hashAlgo="SHA1">/ex8V7qR0DfiP2camhmXVf/lySw=</LICENSE_LINE_HASH><TYPE>PERMANENT</TYPE><EXPIRATION><END_DATE>2013-01-06T00:00:00</END_DATE></EXPIRATION><EULA>YES</EULA><LICENSE_LINE><![CDATA[11 update 1.0 LONG NORMAL STANDALONE EXCL INFINITE_KEYS INFINITE_KEYS NEVER 6 JAN 2013 NiL SLM_CODE CL_ND_LCK NiL *1TRUTZ9BYDB97JG400 NiL NiL NiL 5_MINS <UDI><PID>ASA-SSC-AIP-5</PID><SN>JAF1442BDBN</SN></UDI><GRACE>60</GRACE> D00EGzXaLZ,Cw5Oz1X:nfRLHHVEzR3O,pCmDcIaKrJfFUe9TQpmDEdhCSwveicN8V8TrliDpL0dCEpY4d1aWFQLNwthHVwrQB:kvHRBsnQ5jLvecXCaHvM2MiHfY6dBqa1VZSwxsSXlj2GxzdTw2VFUhfh$<WLC>AQEBIf8B//9t7RlS2eT8pms7CEvSeP/6wAj5l+h4dt7CUM1OqGfDTxjXyQA0YmTarh5061VP/hlHebPkGlARtYd1UQO7GJ3KnufZ9oZ6JdFniDf5HrQ8DrXdpCz5RgZE+y8fbN200xiXA5cB3fwcJqoPIFZm2HmD1qFfsyTAzuio66t6Xk5y8xo1lbVhvoh/FZfy5iRY3oE=</WLC>]]&gt;</LICENSE_LINE><USER_MODIFIABLE_COMMENT fieldRestrictions="Max 99 ASCII characters in length."></USER_MODIFIABLE_COMMENT></CISCO_WT_LICENSE></p><p></CISCO_WT_ARTIFACTS></p><p>exec: cat /usr/cids/idsRoot/etc/config/analysisEngine/current.xml</p><p><span><config xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>" typedefsVersion="2007-12-06" xmlns:enc="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#" rel="nofollow">http://www.w3.org/2001/04/xmlenc#</a><span>" xmlns:ds="</span><a class="jive-link-external-small" href="http://www.w3.org/2000/09/xmldsig#" rel="nofollow">http://www.w3.org/2000/09/xmldsig#</a><span>"></span></p><p>  <struct></p><p>    <map name="virtual-sensor"></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="name">vs0</var></p><p>        </key></p><p>        <struct></p><p>          <set name="physical-interface"></p><p>            <key></p><p>              <var name="name">GigabitEthernet0/0</var></p><p>            </key></p><p>          </set></p><p>        </struct></p><p>      </mapEntry></p><p>    </map></p><p>  </struct></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/authentication/current.xml</p><p><span><config typedefsVersion="2004-03-01" xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>"></span></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/externalProductInterface/current.xml</p><p><span><config typedefsVersion="2006-11-08" xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>"></span></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/healthMonitor/current.xml</p><p><span><config xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>" typedefsVersion="2007-10-30" xmlns:enc="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#" rel="nofollow">http://www.w3.org/2001/04/xmlenc#</a><span>" xmlns:ds="</span><a class="jive-link-external-small" href="http://www.w3.org/2000/09/xmldsig#" rel="nofollow">http://www.w3.org/2000/09/xmldsig#</a><span>"></span></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/host/current.xml</p><p><span><config xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>" typedefsVersion="2007-11-26" xmlns:enc="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#" rel="nofollow">http://www.w3.org/2001/04/xmlenc#</a><span>" xmlns:ds="</span><a class="jive-link-external-small" href="http://www.w3.org/2000/09/xmldsig#" rel="nofollow">http://www.w3.org/2000/09/xmldsig#</a><span>"></span></p><p>  <struct></p><p>    <struct name="network-settings"></p><p>      <var name="host-ip">10.1.2.2/29,10.1.2.1</var></p><p>      <var name="host-name">IPS_Sensor</var></p><p>      <var name="telnet-option">disabled</var></p><p>      <set name="access-list"></p><p>        <key></p><p>          <var name="network-address">10.x.x.5/32</var></p><p>        </key></p><p>        <key></p><p>          <var name="network-address">10.x.x.69/32</var></p><p>        </key></p><p>        <key></p><p>          <var name="network-address">10.x.x.86/32</var></p><p>        </key></p><p>        <key></p><p>          <var name="network-address">10.x.x.117/32</var></p><p>        </key></p><p>      </set></p><p>    </struct></p><p>    <struct name="time-zone-settings"></p><p>      <var name="offset">-360</var></p><p>      <var name="standard-time-zone-name">GMT-06:00</var></p><p>    </struct></p><p>    <union name="ntp-option"></p><p>      <struct name="enabled-ntp-unauthenticated"></p><p>        <var name="ntp-server">10.x.x.5</var></p><p>      </struct></p><p>    </union></p><p>    <union name="summertime-option"></p><p>      <struct name="recurring"></p><p>        <var name="summertime-zone-name">UTC</var></p><p>      </struct></p><p>    </union></p><p>    <struct name="auto-upgrade"></p><p>      <union name="cisco-server"></p><p>        <struct name="enabled"></p><p>          <union name="schedule-option"></p><p>            <struct name="periodic-schedule"></p><p>              <var name="start-time">09:03:17</var></p><p>              <var name="interval">2</var></p><p>            </struct></p><p>          </union></p><p>          <var name="user-name">markpiontek</var></p><p>          <var name="password"></p><p><span>            <enc:EncryptedData Type="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#Content" rel="nofollow">http://www.w3.org/2001/04/xmlenc#Content</a><span>"></span></p><p><span>              <enc:EncryptionMethod Algorithm="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#aes128-cbc" rel="nofollow">http://www.w3.org/2001/04/xmlenc#aes128-cbc</a><span>"></enc:EncryptionMethod></span></p><p>              <ds:KeyInfo></p><p>                <ds:KeyName>cips51.sym</ds:KeyName></p><p>              </ds:KeyInfo></p><p>              <enc:CipherData></p><p>                <enc:CipherValue>******************</enc:CipherValue></p><p>              </enc:CipherData></p><p>            </enc:EncryptedData></p><p>          </var></p><p><span>          <var name="cisco-url"></span><a class="jive-link-external-small" href="https://198.133.219.25//cgi-bin/front.x/ida/locator/locator.pl" rel="nofollow">https://198.133.219.25//cgi-bin/front.x/ida/locator/locator.pl</a><span></var></span></p><p>        </struct></p><p>      </union></p><p>    </struct></p><p>  </struct></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/interface/current.xml</p><p><span><config xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>" typedefsVersion="2007-12-04" xmlns:enc="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#" rel="nofollow">http://www.w3.org/2001/04/xmlenc#</a><span>" xmlns:ds="</span><a class="jive-link-external-small" href="http://www.w3.org/2000/09/xmldsig#" rel="nofollow">http://www.w3.org/2000/09/xmldsig#</a><span>"></span></p><p>  <struct></p><p>    <var name="bypass-mode">auto</var></p><p>  </struct></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/logger/current.xml</p><p><span><config typedefsVersion="2004-04-17" xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>"></span></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/networkAccess/current.xml</p><p><span><config xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>" typedefsVersion="2005-04-20" xmlns:enc="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#" rel="nofollow">http://www.w3.org/2001/04/xmlenc#</a><span>" xmlns:ds="</span><a class="jive-link-external-small" href="http://www.w3.org/2000/09/xmldsig#" rel="nofollow">http://www.w3.org/2000/09/xmldsig#</a><span>"></span></p><p>  <struct></p><p>    <struct name="general"></p><p>      <set name="never-block-hosts"></p><p>        <key></p><p>          <var name="ip-address">10.x.x.8</var></p><p>        </key></p><p>        <key></p><p>          <var name="ip-address">10.x.x.69</var></p><p>        </key></p><p>      </set></p><p>    </struct></p><p>  </struct></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/notification/current.xml</p><p><span><config xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>" typedefsVersion="2004-03-01" xmlns:enc="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#" rel="nofollow">http://www.w3.org/2001/04/xmlenc#</a><span>" xmlns:ds="</span><a class="jive-link-external-small" href="http://www.w3.org/2000/09/xmldsig#" rel="nofollow">http://www.w3.org/2000/09/xmldsig#</a><span>"></span></p><p>  <struct></p><p>    <map name="trap-destinations"></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="ip-address">10.x.x.86</var></p><p>        </key></p><p>        <struct></p><p>          <var name="trap-community-name">public</var></p><p>          <var name="trap-port">162</var></p><p>        </struct></p><p>      </mapEntry></p><p>    </map></p><p>    <var name="error-filter">warning|error|fatal</var></p><p>    <var name="enable-detail-traps">false</var></p><p>    <var name="enable-notifications">true</var></p><p>    <var name="enable-set-get">true</var></p><p>    <var name="read-only-community">nagioscheck</var></p><p>    <var name="read-write-community">c5c6692a461c537f8cd37b2eb7bec9fb</var></p><p>    <var name="trap-community-name">public</var></p><p>  </struct></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/sshKnownHosts/current.xml</p><p><span><config typedefsVersion="2004-03-01" xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>"></span></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/trustedCertificates/current.xml</p><p><span><config typedefsVersion="2004-03-01" xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>"></span></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/userAccount/current.xml</p><p><span><config xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>" typedefsVersion="2004-03-01" xmlns:enc="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#" rel="nofollow">http://www.w3.org/2001/04/xmlenc#</a><span>" xmlns:ds="</span><a class="jive-link-external-small" href="http://www.w3.org/2000/09/xmldsig#" rel="nofollow">http://www.w3.org/2000/09/xmldsig#</a><span>"></span></p><p>  <struct></p><p>    <map name="user-accounts"></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="name">eventViewer</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="credentials"></p><p>            <var name="role">viewer</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="name">service</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="credentials"></p><p>            <var name="role">service</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>    </map></p><p>  </struct></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/webServer/current.xml</p><p><span><config typedefsVersion="2004-03-01" xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>"></span></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/anomalyDetection/instances/ad0.xml</p><p><span><config xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>" typedefsVersion="2005-03-29" xmlns:enc="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#" rel="nofollow">http://www.w3.org/2001/04/xmlenc#</a><span>" xmlns:ds="</span><a class="jive-link-external-small" href="http://www.w3.org/2000/09/xmldsig#" rel="nofollow">http://www.w3.org/2000/09/xmldsig#</a><span>"></span></p><p>  <struct></p><p>  </struct></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/eventActionRules/instances/rules0.xml</p><p><span><config xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>" typedefsVersion="2007-10-05" xmlns:enc="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#" rel="nofollow">http://www.w3.org/2001/04/xmlenc#</a><span>" xmlns:ds="</span><a class="jive-link-external-small" href="http://www.w3.org/2000/09/xmldsig#" rel="nofollow">http://www.w3.org/2000/09/xmldsig#</a><span>"></span></p><p>  <struct></p><p>    <map name="overrides"></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="action-to-add">log-attacker-packets</var></p><p>        </key></p><p>        <struct></p><p>          <var name="override-item-status">Enabled</var></p><p>          <var name="risk-rating-range">70-89</var></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="action-to-add">log-victim-packets</var></p><p>        </key></p><p>        <struct></p><p>          <var name="override-item-status">Enabled</var></p><p>          <var name="risk-rating-range">70-89</var></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="action-to-add">log-pair-packets</var></p><p>        </key></p><p>        <struct></p><p>          <var name="override-item-status">Enabled</var></p><p>          <var name="risk-rating-range">70-89</var></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="action-to-add">produce-alert</var></p><p>        </key></p><p>        <struct></p><p>          <var name="override-item-status">Enabled</var></p><p>          <var name="risk-rating-range">70-89</var></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="action-to-add">produce-verbose-alert</var></p><p>        </key></p><p>        <struct></p><p>          <var name="override-item-status">Enabled</var></p><p>          <var name="risk-rating-range">70-89</var></p><p>        </struct></p><p>      </mapEntry></p><p>    </map></p><p>    <list name="filters"></p><p>      <listEntry name="Ignore_two_hosts"></p><p>        <struct></p><p>          <var name="signature-id-range">3030</var></p><p>          <var name="subsignature-id-range">0</var></p><p>          <var name="attacker-address-range">10.x.x.0-10.x.x.255</var></p><p>          <var name="actions-to-remove">produce-alert</var></p><p>          <var name="os-relevance">relevant|not-relevant|unknown</var></p><p>        </struct></p><p>      </listEntry></p><p>      <listEntry name="Q00000"></p><p>        <struct></p><p>          <var name="signature-id-range">11226,11228</var></p><p>          <var name="subsignature-id-range">0</var></p><p>          <var name="victim-address-range">10.x.x.69</var></p><p>          <var name="actions-to-remove">log-attacker-packets|log-victim-packets|log-pair-packets</var></p><p>          <var name="os-relevance">relevant|not-relevant|unknown</var></p><p>        </struct></p><p>      </listEntry></p><p>      <listEntry name="Q00001"></p><p>        <struct></p><p>          <var name="signature-id-range">5595</var></p><p>          <var name="subsignature-id-range">0</var></p><p>          <var name="attacker-address-range">10.x.x.220-10.x.x.245</var></p><p>          <var name="actions-to-remove">produce-alert</var></p><p>          <var name="os-relevance">relevant|not-relevant|unknown</var></p><p>        </struct></p><p>      </listEntry></p><p>      <listEntry name="Q00002"></p><p>        <struct></p><p>          <var name="signature-id-range">2100</var></p><p>          <var name="subsignature-id-range">0</var></p><p>          <var name="attacker-address-range">10.x.x.86</var></p><p>          <var name="actions-to-remove">produce-alert</var></p><p>          <var name="os-relevance">relevant|not-relevant|unknown</var></p><p>        </struct></p><p>      </listEntry></p><p>      <ordering></p><p>        <name>Ignore_two_hosts</name></p><p>        <name>Q00000</name></p><p>        <name>Q00001</name></p><p>        <name>Q00002</name></p><p>      </ordering></p><p>    </list></p><p>  </struct></p><p></config></p><p>exec: cat /usr/cids/idsRoot/etc/config/signatureDefinition/instances/sig0.xml</p><p><span><config xmlns="</span><a class="jive-link-external-small" href="http://www.cisco.com/cids/idconf" rel="nofollow">http://www.cisco.com/cids/idconf</a><span>" typedefsVersion="2009-12-21" xmlns:enc="</span><a class="jive-link-external-small" href="http://www.w3.org/2001/04/xmlenc#" rel="nofollow">http://www.w3.org/2001/04/xmlenc#</a><span>" xmlns:ds="</span><a class="jive-link-external-small" href="http://www.w3.org/2000/09/xmldsig#" rel="nofollow">http://www.w3.org/2000/09/xmldsig#</a><span>"></span></p><p>  <struct></p><p>    <map name="signatures"></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1004</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1225</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1316</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1406</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">false</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1408</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1604</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1611</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1623</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1627</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1701</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1703</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1706</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">1725</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">2011</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">2152</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">2200</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3030</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3128</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3142</var></p><p>          <var name="subsig-id">3</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3143</var></p><p>          <var name="subsig-id">3</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3143</var></p><p>          <var name="subsig-id">4</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3151</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3220</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3323</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3325</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3357</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">3537</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4001</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4068</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4602</var></p><p>          <var name="subsig-id">3</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4602</var></p><p>          <var name="subsig-id">4</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4607</var></p><p>          <var name="subsig-id">6</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4607</var></p><p>          <var name="subsig-id">7</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4607</var></p><p>          <var name="subsig-id">8</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4607</var></p><p>          <var name="subsig-id">9</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4609</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4615</var></p><p>          <var name="subsig-id">2</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4615</var></p><p>          <var name="subsig-id">3</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">4704</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5055</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5176</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5448</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5449</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5450</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5451</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5478</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5513</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5538</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5546</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5648</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5653</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5654</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5663</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5710</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5726</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5726</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5739</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">5930</var></p><p>          <var name="subsig-id">7</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">6007</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">6066</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">6155</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">6155</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">6408</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">6462</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">6462</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">6462</var></p><p>          <var name="subsig-id">2</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">6522</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">6996</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">7104</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">7201</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="service-p2p"></p><p>              <var name="event-action">deny-connection-inline|produce-alert</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">7202</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="service-p2p"></p><p>              <union name="specify-service-ports"></p><p>                <struct name="yes"></p><p>                  <var name="service-ports">1-1024</var></p><p>                </struct></p><p>              </union></p><p>            </struct></p><p>          </union></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">9401</var></p><p>          <var name="subsig-id">2</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">9403</var></p><p>          <var name="subsig-id">2</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">9412</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">9418</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">9430</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">9433</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">9515</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">9516</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">9583</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11001</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="string-tcp"></p><p>              <var name="event-action">produce-alert|deny-packet-inline</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11001</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="service-p2p"></p><p>              <var name="event-action">deny-packet-inline|produce-alert</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11005</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="service-http"></p><p>              <var name="event-action">produce-alert|deny-packet-inline</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11005</var></p><p>          <var name="subsig-id">2</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="service-p2p"></p><p>              <var name="event-action">deny-packet-inline|produce-alert</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11007</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="string-tcp"></p><p>              <var name="event-action">produce-alert|deny-packet-inline</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11007</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="service-p2p"></p><p>              <var name="event-action">deny-packet-inline|produce-alert</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11018</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="string-tcp"></p><p>              <var name="event-action">produce-alert|deny-packet-inline</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11019</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11019</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11020</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="service-p2p"></p><p>              <var name="event-action">produce-alert|reset-tcp-connection</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11024</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11030</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="service-http"></p><p>              <var name="event-action">produce-alert|reset-tcp-connection</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11031</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <union name="engine"></p><p>            <struct name="service-http"></p><p>              <var name="event-action">produce-alert|reset-tcp-connection</var></p><p>            </struct></p><p>          </union></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11202</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11211</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11211</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11214</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11216</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11219</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11221</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11226</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">false</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11228</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">false</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11231</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11233</var></p><p>          <var name="subsig-id">2</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">false</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11233</var></p><p>          <var name="subsig-id">3</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11238</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">false</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11252</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">11252</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">12704</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">12711</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">15235</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">15235</var></p><p>          <var name="subsig-id">1</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">15235</var></p><p>          <var name="subsig-id">2</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">15393</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">15816</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">17269</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">17397</var></p><p>          <var name="subsig-id">0</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>      <mapEntry></p><p>        <key></p><p>          <var name="sig-id">50013</var></p><p>          <var name="subsig-id">2</var></p><p>        </key></p><p>        <struct></p><p>          <struct name="status"></p><p>            <var name="enabled">true</var></p><p>          </struct></p><p>        </struct></p><p>      </mapEntry></p><p>    </map></p><p>  </struct></p><p></config></p><p>exec: md5sum /usr/cids/idsRoot/etc/PlatToPkgMap.conf</p><p>c6c9fea7889c15e05d03b600730f3fe6  /usr/cids/idsRoot/etc/PlatToPkgMap.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/anomalyDetection.conf</p><p>7b3f71fb901b9fc28e90b7e12e59a14e  /usr/cids/idsRoot/etc/anomalyDetection.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/auth.conf</p><p>547c27aff453c1f4b486a1d89b780a90  /usr/cids/idsRoot/etc/auth.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/cidwebserver.conf</p><p>63897ea39e2cb41a8454808278268e66  /usr/cids/idsRoot/etc/cidwebserver.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/cliAdmin.conf</p><p>64c5a915e99cb0c191e58c46af8897bd  /usr/cids/idsRoot/etc/cliAdmin.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/cliOperator.conf</p><p>3535f06de762298a4940dff164c7b4b4  /usr/cids/idsRoot/etc/cliOperator.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/cliPlatform.conf</p><p>93808e25c2532f26b2424d6893a38a41  /usr/cids/idsRoot/etc/cliPlatform.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/cliViewer.conf</p><p>0be55ac6b4510768be641d949a75c0ef  /usr/cids/idsRoot/etc/cliViewer.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/eventServer.conf</p><p>99a34deeb7032669b6175a4b067c4d45  /usr/cids/idsRoot/etc/eventServer.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/eventStore.conf</p><p>cb75c8579003277106bfd8bb73fdcfd5  /usr/cids/idsRoot/etc/eventStore.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/idProm.conf</p><p>f1fb68d6d2739b799e07074b5ab11f8c  /usr/cids/idsRoot/etc/idProm.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/interface.conf</p><p>c8d5159778d7d38fcc4f0a571ac97b8b  /usr/cids/idsRoot/etc/interface.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/log.conf</p><p>eb29fbcb878c7bef6095daf1667d7b68  /usr/cids/idsRoot/etc/log.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/mainApp.conf</p><p>b713207e1e58644732b7d13a26a80161  /usr/cids/idsRoot/etc/mainApp.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/notificationPlatform.conf</p><p>4314f45a896275b57353c32e29ae4515  /usr/cids/idsRoot/etc/notificationPlatform.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/osfp.conf</p><p>190a18f42ebd914e601338bab398c4a1  /usr/cids/idsRoot/etc/osfp.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/selfcert.conf</p><p>4b9938402c7d62428978694a9740e9bf  /usr/cids/idsRoot/etc/selfcert.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/sensorApp.conf</p><p>c3583abd0206459ad70194fb11789f4a  /usr/cids/idsRoot/etc/sensorApp.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/simulator.conf</p><p>e6abacf2d57f20edca0b724589e60a41  /usr/cids/idsRoot/etc/simulator.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/stateString.conf</p><p>8a6ab4cf6839b16058183b70349b3e1e  /usr/cids/idsRoot/etc/stateString.conf</p><p>exec: md5sum /usr/cids/idsRoot/etc/tls.conf</p><p>575e7c6a41c9964a0667c431f58f42d3  /usr/cids/idsRoot/etc/tls.conf</p><p>exec: /sbin/lsmod</p><p>Module                  Size  Used by    Tainted: P</p><p>tipc                  158328   0  (unused)</p><p>rebootkom               1012   0  (unused)</p><p>ipt_state                632   1  (autoclean)</p><p>ip_conntrack           21896   0  (autoclean) [ipt_state]</p><p>iptable_filter          1768   1  (autoclean)</p><p>ip_tables              12024   2  [ipt_state iptable_filter]</p><p>skge-cids             257120   2</p><p>cids-shared           576364   4  [skge-cids]</p><p>cidmodcap               2792  12</p><p>ssc-idprom              1264   0  [skge-cids]</p><p>scx200-acb              5956   0  [ssc-idprom]</p><p>cs5536-gpio             4932   0  [skge-cids scx200-acb]</p><p>exec: /sbin/ifconfig -a</p><p>eth0      Link encap:Ethernet  HWaddr 1C:DF:0F:84:01:5C</p><p>          UP BROADCAST RUNNING MULTICAST  MTU:1600  Metric:1</p><p>          RX packets:175631937 errors:0 dropped:0 overruns:0 frame:0</p><p>          TX packets:174632225 errors:0 dropped:0 overruns:0 carrier:0</p><p>          collisions:0 txqueuelen:1000</p><p>          RX bytes:3525621198 (3.2 GiB)  TX bytes:3776019786 (3.5 GiB)</p><p>          Interrupt:11 Memory:e0004000-0</p><p>ge0_0     Link encap:Ethernet  HWaddr 00:00:00:02:00:02</p><p>          BROADCAST MULTICAST  MTU:1500  Metric:1</p><p>          RX packets:163596477 errors:0 dropped:0 overruns:0 frame:0</p><p>          TX packets:163596273 errors:0 dropped:0 overruns:0 carrier:0</p><p>          collisions:0 txqueuelen:1000</p><p>          RX bytes:1471482030 (1.3 GiB)  TX bytes:1471299135 (1.3 GiB)</p><p>lo        Link encap:Local Loopback</p><p>          inet addr:127.0.0.1  Mask:255.255.255.255</p><p>          UP LOOPBACK RUNNING  MTU:16436  Metric:1</p><p>          RX packets:2691569 errors:0 dropped:0 overruns:0 frame:0</p><p>          TX packets:2691569 errors:0 dropped:0 overruns:0 carrier:0</p><p>          collisions:0 txqueuelen:0</p><p>          RX bytes:265183136 (252.8 MiB)  TX bytes:265183136 (252.8 MiB)</p><p>ma0_0     Link encap:Ethernet  HWaddr 00:4D:79:4D:41:43</p><p>          inet addr:10.1.2.2  Bcast:10.1.2.7  Mask:255.255.255.248</p><p>          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1</p><p>          RX packets:8839635 errors:0 dropped:0 overruns:0 frame:0</p><p>          TX packets:9437848 errors:0 dropped:0 overruns:0 carrier:0</p><p>          collisions:0 txqueuelen:1000</p><p>          RX bytes:1105532488 (1.0 GiB)  TX bytes:1410608557 (1.3 GiB)</p><p>sy0_0     Link encap:Ethernet  HWaddr 00:00:00:02:00:01</p><p>          inet addr:127.0.2.1  Bcast:127.0.255.255  Mask:255.255.0.0</p><p>          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1</p><p>          RX packets:3195819 errors:0 dropped:0 overruns:0 frame:0</p><p>          TX packets:1697987 errors:0 dropped:0 overruns:0 carrier:0</p><p>          collisions:0 txqueuelen:1000</p><p>          RX bytes:246078432 (234.6 MiB)  TX bytes:156813134 (149.5 MiB)</p><p>exec: netstat -a</p><p>Active Internet connections (servers and established)</p><p>Proto Recv-Q Send-Q Local Address           Foreign Address         State</p><p>tcp        0      0 *:ssh                   *:*                     LISTEN</p><p>tcp        0      0 *:telnet                *:*                     LISTEN</p><p>tcp        0      0 *:bbs                   *:*                     LISTEN</p><p>tcp        0      0 10.1.2.2:https          *:*                     LISTEN</p><p>tcp        0      0 10.1.2.2:https          10.x.x.69:1729          ESTABLISHED</p><p>tcp        1      0 10.1.2.2:https          10.x.x.69:1615          CLOSE_WAIT</p><p>tcp        0      0 10.1.2.2:https          10.x.x.69:1746          ESTABLISHED</p><p>tcp        1      0 10.1.2.2:https          10.x.x.69:1689          CLOSE_WAIT</p><p>tcp        0      0 10.1.2.2:ssh            10.x.x.69:4826          ESTABLISHED</p><p>tcp        1      0 10.1.2.2:https          10.x.x.69:datametrics   CLOSE_WAIT</p><p>tcp        0      0 127.0.2.1:bbs           127.0.1.1:1262          ESTABLISHED</p><p>udp        0      0 *:32774                 *:*</p><p>udp        0      0 *:snmp                  *:*</p><p>udp        0      0 10.1.2.2:ntp            *:*</p><p>udp        0      0 127.0.2.1:ntp           *:*</p><p>udp        0      0 localhost:ntp           *:*</p><p>udp        0      0 *:ntp                   *:*</p><p>Active UNIX domain sockets (servers and established)</p><p>Proto RefCnt Flags       Type       State         I-Node Path</p><p>unix  4      [ ]         DGRAM                    167    /dev/log</p><p>unix  2      [ ]         DGRAM                    1317</p><p>unix  2      [ ]         DGRAM                    183</p><p>exec: netstat -r</p><p>Kernel IP routing table</p><p>Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface</p><p>10.1.2.0        *               255.255.255.248 U         0 0          0 ma0_0</p><p>127.0.0.0       *               255.255.0.0     U         0 0          0 sy0_0</p><p>default         10.1.2.1        0.0.0.0         UG        0 0          0 ma0_0</p><p>exec: /sbin/iptables -v -L</p><p>Chain INPUT (policy DROP 1 packets, 81 bytes)</p><p> pkts bytes target     prot opt in     out     source               destination</p><p>2692K  265M ACCEPT     all  --  lo     any     anywhere             anywhere</p><p>    0     0 DROP       tcp  --  ma0_0  any     anywhere             anywhere            tcp dpt:telnet</p><p> 4042  307K ACCEPT     all  --  ma0_0  any     10.x.x.5             anywhere</p><p>8674K  853M ACCEPT     all  --  ma0_0  any     10.x.x.69            anywhere</p><p> 105K 8828K ACCEPT     all  --  ma0_0  any     10.x.x.86            anywhere</p><p>    0     0 ACCEPT     all  --  ma0_0  any     10.x.x.117           anywhere</p><p>56616   76M ACCEPT     all  --  ma0_0  any     anywhere             anywhere            state RELATED,ESTABLISHED</p><p>3196K  185M ACCEPT     all  --  !ma0_0 any     127.0.0.0/16         anywhere</p><p>Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)</p><p> pkts bytes target     prot opt in     out     source               destination</p><p>Chain OUTPUT (policy ACCEPT 13M packets, 1616M bytes)</p><p> pkts bytes target     prot opt in     out     source               destination</p><p>exec: cat /proc/net/cisco/cids-shared.info</p><p>Name                             cids-shared</p><p>TotalBuffers                     13901</p><p>FreeBuffers                      13517 (97 %)</p><p>MemoryPages                      8</p><p>UsedBy                           4</p><p>RxRing                           next=7377,calc=0,cnt=0,st=Empty,chg=0</p><p>TxRing                           next=7377,calc=0,cnt=0,st=Empty,chg=0</p><p>MsgRingCount                     0</p><p>Diagnostic                       none</p><p>SystemPciIds                     0x61 0x62</p><p>BypasMode                        AUTO</p><p>BypassRunning                    0</p><p>DataFlowing                      1</p><p>ThreadIdleLoopsPastSec           0</p><p>cutthru_packets                  0</p><p>Physical Config</p><p>ID      Name   Pair Logic Reset Admin Speed Duplex  Mode</p><p> 0        ge0_0  0    0     n/a   up   Auto  Auto   Prom</p><p>Logical Config</p><p>exec: cat /proc/net/cisco/eth0</p><p>Detailed statistic for device eth0</p><p>=======================================</p><p>Board statistics</p><p>Card name                      Generic Marvell Yukon chipset Ethernet device</p><p>Vendor/Device ID               1148/4320</p><p>Card type (Bit)                64</p><p>Active Port                    A</p><p>Preferred Port                 A</p><p>Interrupt Moderation           dynamic (2000 ints/sec)</p><p>Bus type                       PCI</p><p>Bus speed (MHz)                66</p><p>Bus width (Bit)                32</p><p>Driver version                 8.41.2.3 (02)</p><p>Driver release date            Oct-13-2006</p><p>Hardware revision              v1.0</p><p>Receive statistics</p><p>Received bytes                 102309869726</p><p>Received packets               175631943</p><p>Received interrupt               -915116253</p><p>Missed interrupt               20</p><p>Receive errors                 0</p><p>Receive dropped                0</p><p>Received multicast             0</p><p>Receive error types</p><p>   length                      0</p><p>   buffer overflow             0</p><p>   bad crc                     0</p><p>   framing                     0</p><p>   missed frames               0</p><p>   too long                    0</p><p>   carrier extension           0</p><p>   too short                   0</p><p>   symbol                      0</p><p>   LLC MAC size                0</p><p>   carrier event               0</p><p>   jabber                      0</p><p>Transmit statistics</p><p>Transmitted bytes              102560268510</p><p>Transmitted packets            174632232</p><p>Transmit errors                0</p><p>Transmit dropped               0</p><p>Transmit collisions            0</p><p>Transmit error types</p><p>   excessive collision         0</p><p>   carrier                     0</p><p>   fifo underrun               0</p><p>   heartbeat                   0</p><p>   window                      0</p><p>exec: cat /proc/net/cisco/ge0_0.stats</p><p>DESCRIPTION                      Marvell driver Virtual device</p><p>DEVICE_ID                        0</p><p>DEVICE_TYPE                      Sensing</p><p>DEVICE_VLAN                      4091</p><p>DEVICE_MAC                       00:00:00:02:00:02</p><p>PCI_BUS                          0</p><p>PCI_DEV                          96</p><p>PCI_FUNC                         1</p><p>RX_PACKETS                       163596482</p><p>RX_BYTES                         100255730474</p><p>TX_PACKETS                       163596482</p><p>TX_BYTES                         100255730474</p><p>Dump_Backplane_Headers           0</p><p>SHM_FREE                         97</p><p>SHM_DROPS                        0</p><p>exec: cat /proc/net/cisco/ma0_0.stats</p><p>DESCRIPTION                      Marvell driver Virtual device</p><p>DEVICE_ID                        0</p><p>DEVICE_TYPE                      Management</p><p>DEVICE_VLAN                      33</p><p>DEVICE_MAC                       00:4D:79:4D:41:43</p><p>PCI_BUS                          0</p><p>PCI_DEV                          96</p><p>PCI_FUNC                         1</p><p>RX_PACKETS                       8839648</p><p>RX_BYTES                         1105533605</p><p>TX_PACKETS                       9437861</p><p>TX_BYTES                         1410610721</p><p>exec: cat /proc/net/cisco/sy0_0.stats</p><p>DESCRIPTION                      Marvell driver Virtual device</p><p>DEVICE_ID                        0</p><p>DEVICE_TYPE                      Control</p><p>DEVICE_VLAN                      4092</p><p>DEVICE_MAC                       00:00:00:02:00:01</p><p>PCI_BUS                          0</p><p>PCI_DEV                          96</p><p>PCI_FUNC                         1</p><p>RX_PACKETS                       3195819</p><p>RX_BYTES                         246078432</p><p>TX_PACKETS                       1697987</p><p>TX_BYTES                         156813134</p><p>exec: dmesg</p><p>=/dev/ram0 init=loadrc hda=flash nousb console=ttyS0 htlblow=8 hugepages=74 tlv=BP9QAAD9gAD+gB8vdm1saW51ei0yLjQuMzAtSURTLXNtcC1iaWdwaHlzcw==</p><p>ide_setup: hda=flash</p><p>hugetlb_lowmem_setup: Allocated 33554432 huge pages (size=0x400000) from lowmem area at 0xc1800000</p><p>No local APIC present or hardware disabled</p><p>Initializing CPU#0</p><p>Detected 498.059 MHz processor.</p><p>Console: colour *CGA 80x25</p><p>Calibrating delay loop... 992.87 BogoMIPS</p><p>Memory: 470240k/520100k available (1621k kernel code, 49468k reserved, 707k data, 132k init, 0k highmem)</p><p>Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)</p><p>Inode cache hash table entries: 32768 (order: 6, 262144 bytes)</p><p>Mount cache hash table entries: 512 (order: 0, 4096 bytes)</p><p>Buffer cache hash table entries: 32768 (order: 5, 131072 bytes)</p><p>Page-cache hash table entries: 131072 (order: 7, 524288 bytes)</p><p>CPU: L1 I Cache: 64K (32 bytes/line), D cache 64K (32 bytes/line)</p><p>CPU: L2 Cache: 128K (32 bytes/line)</p><p>CPU:     After generic, caps: 0088a93d c0c0a13d 00000000 00000000</p><p>CPU:             Common caps: 0088a93d c0c0a13d 00000000 00000000</p><p>Checking 'hlt' instruction... OK.</p><p>POSIX conformance testing by UNIFIX</p><p><span>mtrr: v1.40 (20010327) Richard Gooch (</span><a class="jive-link-email-small" href="mailto:rgooch@atnf.csiro.au">rgooch@atnf.csiro.au</a><span>)</span></p><p>mtrr: detected mtrr type: none</p><p>CPU: L1 I Cache: 64K (32 bytes/line), D cache 64K (32 bytes/line)</p><p>CPU: L2 Cache: 128K (32 bytes/line)</p><p>CPU:     After generic, caps: 0088a93d c0c0a13d 00000000 00000000</p><p>CPU:             Common caps: 0088a93d c0c0a13d 00000000 00000000</p><p>CPU0: AMD Geode(TM) Integrated Processor by AMD PCS stepping 02</p><p>per-CPU timeslice cutoff: 365.46 usecs.</p><p>SMP motherboard not detected.</p><p>Local APIC not detected. Using dummy APIC emulation.</p><p>Waiting on wait_init_idle (map = 0x0)</p><p>All processors have done init_idle</p><p>PCI: PCI BIOS revision 2.10 entry at 0xff699, last bus=0</p><p>PCI: Using configuration type 1</p><p>PCI: Probing PCI hardware</p><p>PCI: Probing PCI hardware (bus 00)</p><p>isapnp: Scanning for PnP cards...</p><p>isapnp: No Plug & Play device found</p><p>Linux NET4.0 for Linux 2.4</p><p>Based upon Swansea University Computer Society NET3.039</p><p>Initializing RT netlink socket</p><p>hugetlb_init: Using 8 pages from low memory at c1800000for HugeTLB FS</p><p>hugetlb_init: Adding a 0x400000 size page at c109c020 to HugeTLB lowmem freelist</p><p>hugetlb_init: Adding a 0x400000 size page at c1090020 to HugeTLB lowmem freelist</p><p>hugetlb_init: Adding a 0x400000 size page at c1084020 to HugeTLB lowmem freelist</p><p>hugetlb_init: Adding a 0x400000 size page at c1078020 to HugeTLB lowmem freelist</p><p>hugetlb_init: Adding a 0x400000 size page at c106c020 to HugeTLB lowmem freelist</p><p>hugetlb_init: Adding a 0x400000 size page at c1060020 to HugeTLB lowmem freelist</p><p>hugetlb_init: Adding a 0x400000 size page at c1054020 to HugeTLB lowmem freelist</p><p>hugetlb_init: Adding a 0x400000 size page at c1048020 to HugeTLB lowmem freelist</p><p>Total HugeTLB memory allocated, 82 of 0x400000 size pages</p><p>Starting kswapd</p><p>Journalled Block Device driver loaded</p><p>Hugetlbfs mounted.</p><p>keyboard: controller not found</p><p>pty: 2048 Unix98 ptys configured</p><p>Serial driver version 5.05c (2001-07-08) with MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI ISAPNP enabled</p><p>ttyS00 at 0x03f8 (irq = 4) is a 16550A</p><p>Real Time Clock Driver v1.10f</p><p>RAMDISK driver initialized: 16 RAM disks of 76800K size 1024 blocksize</p><p>loop: loaded (max 8 devices)</p><p>lpc: version 0.1 (Dec 15 2008)</p><p>Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4</p><p>ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx</p><p>hdb: C/H/S=0/0/0 from BIOS ignored</p><p>hda: VI 512MB, CFA DISK drive</p><p>ide0 at 0x1f0-0x1f7,0x3f6 on irq 14</p><p>hda: attached ide-disk driver.</p><p>hda: 1015056 sectors (520 MB) w/1KiB Cache, CHS=1007/16/63</p><p>Partition check:</p><p> hda: hda1 hda2 hda3 hda4</p><p>ide: late registration of driver.</p><p>SCSI subsystem driver Revision: 1.00</p><p>i2c-core.o: i2c core module version 2.10.0 (20060214)</p><p>i2c-dev.o: i2c /dev entries driver module version 2.10.0 (20060214)</p><p>i2c-proc.o version 2.10.0 (20060214)</p><p>i2c-i801 version 2.10.0 (20060214)</p><p>ipmi message handler version 37</p><p>ipmi device interface version 37</p><p>IPMI SMB Interface driver version 37a</p><p>NET4: Linux TCP/IP 1.0 for NET4.0</p><p>IP Protocols: ICMP, UDP, TCP, IGMP</p><p>IP: routing cache hash table of 4096 buckets, 32Kbytes</p><p>TCP: Hash tables configured (established 32768 bind 32768)</p><p>Linux IP multicast router 0.06 plus PIM-SM</p><p>NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.</p><p>RAMDISK: Compressed image found at block 0</p><p>Freeing initrd memory: 7554k freed</p><p>VFS: Mounted root (ext2 filesystem) readonly.</p><p>Freeing unused kernel memory: 132k freed</p><p>EXT2-fs warning: checktime reached, running e2fsck is recommended</p><p>kjournald starting.  Commit interval 5 seconds</p><p>EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,2), internal journal</p><p>EXT3-fs: mounted filesystem with ordered data mode.</p><p>EXT2-fs warning: checktime reached, running e2fsck is recommended</p><p>kjournald starting.  Commit interval 5 seconds</p><p>EXT3-fs: mounted filesystem with ordered data mode.</p><p>cs5536_gpio_baseaddr f000</p><p>scx200_acb: NatSemi SCx200 ACCESS.bus Driver</p><p>i2c-dev.o: Registered 'SCx200 ACB0' as minor 0</p><p>EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,1), internal journal</p><p>sk98lin: Network Device Driver v8.41.2.3</p><p>(C)Copyright 1999-2006 Marvell(R).</p><p>sk98lin: Port A: FlowControl impossible without AutoNegotiation, disabled</p><p>eth0: Generic Marvell Yukon chipset Ethernet device</p><p>      PrefPort:A  RlmtMode:Check Link State</p><p>skge-cids(SkCidsSetDebugLevel,800): Setting CIDS debug level 0x00000000.</p><p>skge-cids(SkCidsSetOperMode,784): Setting CIDS operation mode SENSOR.</p><p>skge-cids(SkCidsSetPacketDump,830): CIDS packet dump - False.</p><p>skge-cids(SkCidsSetDataLoopback,863): CIDS data loopback - False.</p><p>skge-cids(sk98lin_init_device,692): Attempts to initialize sensing virtual devices.</p><p>skge-cids(SkCidsDevRegister,266): Registers virtual device eth1 as a Linux network device successfully.</p><p>skge-cids(SkCidsRegisterVirtualDevices,414): Add eth1 successfully to CIDS context.</p><p>skge-cids(SkCidsDevRegister,266): Registers virtual device eth2 as a Linux network device successfully.</p><p>skge-cids(SkCidsRegisterVirtualDevices,414): Add eth2 successfully to CIDS context.</p><p>skge-cids(SkCidsShrRegister,1052): Registers virtual sensing device as a Linux network device successfully.</p><p>skge-cids(SkCidsRegisterVirtualDevices,414): Add eth3 successfully to CIDS context.</p><p>skge-cids(SkCidsInit,949): Register virtual net devices to CIDS context successfully.</p><p>skge-cids(sk98lin_init_device,699): Sensing virtual devices initialized successfully.</p><p>eth0: network connection up using port A</p><p>    speed:           1000</p><p>    autonegotiation: no</p><p>    duplex mode:     full</p><p>    flowctrl:        none</p><p>    irq moderation:  dynamic (2000 ints/sec)</p><p>    scatter-gather:  disabled</p><p>    tx-checksum:     enabled</p><p>    rx-checksum:     enabled</p><p>skge-cids(SkGeOpen,2617): Attempt to open sensing virtual devices.</p><p>skge-cids(SkCidsOpenVirtual,531): Open virtual device eth1 successfully.</p><p>skge-cids(SkCidsOpen,1035): Open virtual device successfully.</p><p>skge-cids(SkCidsOpenVirtual,531): Open virtual device eth2 successfully.</p><p>skge-cids(SkCidsOpen,1035): Open virtual device successfully.</p><p>skge-cids(SkCidsOpenVirtual,531): Open virtual device eth3 successfully.</p><p>skge-cids(SkCidsOpen,1035): Open virtual device successfully.</p><p>skge-cids(SkGeOpen,2622): Sensing virtual devices opened successfully.</p><p>skge-cids(SkCidsShrStart,202): Starting cids-shared component.</p><p>ip_tables: (C) 2000-2002 Netfilter core team</p><p>ip_conntrack version 2.1 (4063 buckets, 32504 max) - 288 bytes per conntrack</p><p>TIPC: Compiled Dec 15 2008 18:40:43</p><p>../reg.c: Started in single node mode</p><p>../reg.c: Started in network mode</p><p>../reg.c: Own node address <1.1.2>, network identity 1234</p><p>../media.c: Enabled bearer <eth:sy0_0>, detection scope <1.1.0></p><p>MacUpdate</p><p>RlmtUpdate</p><p>SirqUpdate</p><p>retrive values</p><p>done</p><p>MacUpdate</p><p>RlmtUpdate</p><p>SirqUpdate</p><p>retrive values</p><p>done</p><p>exec: /usr/cids/idsRoot/bin/ipsDebug -s -m</p><p>##########################</p><p>cidcli info version 2</p><p> index 0</p><p>   in use 1</p><p>   id     32147</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Signal handler</p><p>   status</p><p> index 1</p><p>   in use 1</p><p>   id     32152</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Main state machine</p><p>   status E getHostSupportInfo</p><p> index 2</p><p>   in use 1</p><p>   id     32161</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   CT handler</p><p>   status</p><p> index 3</p><p>   in use 1</p><p>   id     634</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Progress</p><p>   status</p><p>##########################</p><p>sendCtlTrans info version 2</p><p> index 0</p><p>   in use 0</p><p>   id     939</p><p>   tstate E</p><p>   state  N</p><p>   resid  0</p><p>   desc   Signal handler</p><p>   status</p><p> index 1</p><p>   in use 0</p><p>   id     941</p><p>   tstate D</p><p>   state  N</p><p>   resid  0</p><p>   desc   main</p><p>   status</p><p>##########################</p><p>sensorApp info version 2</p><p> index 0</p><p>   in use 1</p><p>   id     460</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Signal handler</p><p>   status</p><p> index 1</p><p>   in use 1</p><p>   id     488</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   SensorApp::run</p><p>   status</p><p> index 2</p><p>   in use 1</p><p>   id     505</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   CT handler</p><p>   status</p><p> index 3</p><p>   in use 1</p><p>   id     1656</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Producer</p><p>   status</p><p> index 4</p><p>   in use 0</p><p>   id     526</p><p>   tstate E</p><p>   state  N</p><p>   resid  0</p><p>   desc   Show version</p><p>   status</p><p>##########################</p><p>mainApp info version 2</p><p> index 0</p><p>   in use 1</p><p>   id     342</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Signal handler</p><p>   status</p><p> index 1</p><p>   in use 1</p><p>   id     347</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Main run</p><p>   status</p><p> index 2</p><p>   in use 1</p><p>   id     348</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Timer task</p><p>   status</p><p> index 3</p><p>   in use 1</p><p>   id     413</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   CT processor</p><p>   status</p><p> index 4</p><p>   in use 1</p><p>   id     433</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Logging task</p><p>   status</p><p> index 5</p><p>   in use 1</p><p>   id     434</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   LogApp syslog reader</p><p>   status</p><p> index 6</p><p>   in use 1</p><p>   id     435</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   InterfaceApp status monitor</p><p>   status</p><p> index 7</p><p>   in use 1</p><p>   id     436</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Nac task</p><p>   status</p><p> index 8</p><p>   in use 1</p><p>   id     437</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Nac idapi reader</p><p>   status</p><p> index 9</p><p>   in use 1</p><p>   id     438</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Web session</p><p>   status E getVersion</p><p> index 10</p><p>   in use 1</p><p>   id     439</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Web session</p><p>   status</p><p> index 11</p><p>   in use 1</p><p>   id     440</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Web session</p><p>   status</p><p> index 12</p><p>   in use 1</p><p>   id     441</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Web session</p><p>   status E getHealthAndSecurityStatus</p><p> index 13</p><p>   in use 1</p><p>   id     442</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Web session</p><p>   status E getVersion</p><p> index 14</p><p>   in use 1</p><p>   id     443</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Web session</p><p>   status</p><p> index 15</p><p>   in use 1</p><p>   id     444</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Web session</p><p>   status E getVersion</p><p> index 16</p><p>   in use 1</p><p>   id     445</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Web session</p><p>   status E getHealthAndSecurityStatus</p><p> index 17</p><p>   in use 1</p><p>   id     446</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Web session</p><p>   status</p><p> index 18</p><p>   in use 1</p><p>   id     447</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Web session</p><p>   status</p><p> index 19</p><p>   in use 1</p><p>   id     448</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Web connections</p><p>   status</p><p> index 20</p><p>   in use 1</p><p>   id     420</p><p>   tstate ?</p><p>   state  N</p><p>   resid  0</p><p>   desc</p><p>   status</p><p> index 21</p><p>   in use 1</p><p>   id     908</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   TLS message dispatcher</p><p>   status</p><p> index 22</p><p>   in use 1</p><p>   id     452</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   HeartbeatTask</p><p>   status</p><p> index 23</p><p>   in use 1</p><p>   id     462</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Notification subscription task</p><p>   status</p><p> index 24</p><p>   in use 1</p><p>   id     463</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Notification subscription task</p><p>   status</p><p> index 25</p><p>   in use 1</p><p>   id     461</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   CPU usage</p><p>   status</p><p> index 26</p><p>   in use 1</p><p>   id     464</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   Notification subscription task</p><p>   status</p><p> index 27</p><p>   in use 1</p><p>   id     465</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   Notification agent task</p><p>   status</p><p> index 28</p><p>   in use 1</p><p>   id     909</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   TLS handshake</p><p>   status</p><p> index 29</p><p>   in use 0</p><p>   id     805</p><p>   tstate D</p><p>   state  N</p><p>   resid  0</p><p>   desc   TLS message dispatcher</p><p>   status</p><p> index 30</p><p>   in use 0</p><p>   id     806</p><p>   tstate D</p><p>   state  N</p><p>   resid  0</p><p>   desc   TLS handshake</p><p>   status</p><p> index 31</p><p>   in use 1</p><p>   id     699</p><p>   tstate R</p><p>   state  N</p><p>   resid  0</p><p>   desc   TLS message dispatcher</p><p>   status</p><p> index 32</p><p>   in use 1</p><p>   id     700</p><p>   tstate R</p><p>   state  E</p><p>   resid  0</p><p>   desc   TLS handshake</p><p>   status</p><p> index 33</p><p>   in use 0</p><p>   id     655</p><p>   tstate D</p><p>   state  N</p><p>   resid  0</p><p>   desc   TLS message dispatcher</p><p>   status</p><p> index 34</p><p>   in use 0</p><p>   id     656</p><p>   tstate D</p><p>   state  N</p><p>   resid  0</p><p>   desc   TLS handshake</p><p>   status</p><p> index 35</p><p>   in use 0</p><p>   id     31364</p><p>   tstate D</p><p>   state  N</p><p>   resid  0</p><p>   desc   TLS handshake</p><p>   status</p><p> index 36</p><p>   in use 0</p><p>   id     28665</p><p>   tstate D</p><p>   state  N</p><p>   resid  0</p><p>   desc   TLS handshake</p><p>   status</p><p> index 37</p><p>   in use 0</p><p>   id     27771</p><p>   tstate D</p><p>   state  N</p><p>   resid  0</p><p>   desc   TLS message dispatcher</p><p>   status</p><p> index 38</p><p>   in use 0</p><p>   id     27772</p><p>   tstate D</p><p>   state  N</p><p>   resid  0</p><p>   desc   TLS handshake</p><p>   status</p><p>Semaphore Table:</p><p>key        idx        id   value    w0     w1   lpid perm    uid    gid file</p><p>0x02ebe368  0 0011501605      1      0      0  32152 0660    101     50 sem_evt_ct--cidcli.32147</p><p>0x02ebe368  1 0011501605      1      0      0  32152 0660    101     50 sem_evt_ct--cidcli.32147</p><p>0x02ebe367  0 0011468836      1      0      0  32152 0660    101     50 sem_ct--cidcli.32147</p><p>0x02ebe367  1 0011468836      1      0      0  32152 0660    101     50 sem_ct--cidcli.32147</p><p>0x02ebe364  0 0011436067      0      0      0  32152 0660    101     50 sem_pipe_ClntConnect_ct--cidcli.32147</p><p>0x02ebe364  1 0011436067      1      0      0  32152 0660    101     50 sem_pipe_ClntConnect_ct--cidcli.32147</p><p>0x02ebe363  0 0011403298      0      0      0  32152 0660    101     50 sem_pipe_SrvrConnect_ct--cidcli.32147</p><p>0x02ebe363  1 0011403298      1      0      0  32152 0660    101     50 sem_pipe_SrvrConnect_ct--cidcli.32147</p><p>0x02de8a18  0 0009502749      1      0      0   1656 0660     50     50 sem_evt_IdsEventStore4</p><p>0x02de8a18  1 0009502749      2      0      0   1656 0660     50     50 sem_evt_IdsEventStore4</p><p>0x00000aca  0 0002293793      1      0      0  32152 0660     50     50 sem_evt_ct-sensorApp.460</p><p>0x00000aca  1 0002293793      1      0      0  32152 0660     50     50 sem_evt_ct-sensorApp.460</p><p>0x00000ac9  0 0002261024      1      0      0  32152 0660     50     50 sem_ct-sensorApp.460</p><p>0x00000ac9  1 0002261024      1      0      0  32152 0660     50     50 sem_ct-sensorApp.460</p><p>0x00000ac6  0 0002228255      0      0      0    505 0660     50     50 sem_pipe_ClntConnect_ct-sensorApp.460</p><p>0x00000ac6  1 0002228255      1      0      0  32152 0660     50     50 sem_pipe_ClntConnect_ct-sensorApp.460</p><p>0x00000ac5  0 0002195486      0      0      0  32152 0660     50     50 sem_pipe_SrvrConnect_ct-sensorApp.460</p><p>0x00000ac5  1 0002195486      1      0      0  32152 0660     50     50 sem_pipe_SrvrConnect_ct-sensorApp.460</p><p>0x00000701  0 0002097180      1      0      0  32152 0660     50     50 sem_evt_IdsEventStore3</p><p>0x00000701  1 0002097180      3      0      0  32152 0660     50     50 sem_evt_IdsEventStore3</p><p>0x000006fd  0 0002064411      1      0      0    449 0660     50     50 sem_evt_IdsEventStore2</p><p>0x000006fd  1 0002064411      1      0      0    449 0660     50     50 sem_evt_IdsEventStore2</p><p>0x000006f9  0 0002031642      1      0      0    449 0660     50     50 sem_evt_IdsEventStore1</p><p>0x000006f9  1 0002031642      1      0      0    449 0660     50     50 sem_evt_IdsEventStore1</p><p>0x00000554  0 0001736729      1      0      0    437 0660     50     50 sem_evt_IdsEventStore0</p><p>0x00000554  1 0001736729      1      0      0    437 0660     50     50 sem_evt_IdsEventStore0</p><p>0x00000552  0 0001671191      1      0      0  11193 0660     50     50 sem_accessTlsConfig</p><p>0x00000552  1 0001671191      2      0      0    347 0660     50     50 sem_accessTlsConfig</p><p>0x00000534  0 0001409048      1      0      0   1656 0660     50     50 sem_CidsSharedIoctlSem</p><p>0x00000534  1 0001409048      2      0      0    488 0660     50     50 sem_CidsSharedIoctlSem</p><p>0x000003f9  0 0001048598      1      0      0  32152 0660     50     50 sem_shm_IdsEventStoreShm</p><p>0x000003f9  1 0001048598      3      0      0  32152 0660     50     50 sem_shm_IdsEventStoreShm</p><p>0x000003f8  0 0001015829      1      0      0    447 0660     50     50 sem_IdsEventStoreSem</p><p>0x000003f8  1 0001015829      3      0      0  32152 0660     50     50 sem_IdsEventStoreSem</p><p>0x00000322  0 0000950292      1      0      0  32152 0660     50     50 sem_shm_global-data</p><p>0x00000322  1 0000950292      3      0      0  32152 0660     50     50 sem_shm_global-data</p><p>0x00000321  0 0000917523      1      0      0    434 0660     50     50 sem_global-shm</p><p>0x00000321  1 0000917523      3      0      0  32152 0660     50     50 sem_global-shm</p><p>0x00000320  0 0000884754      1      0      0    347 0660     50     50 sem_upgradeCtSem</p><p>0x00000320  1 0000884754      1      0      0    347 0660     50     50 sem_upgradeCtSem</p><p>0x0000031d  0 0000851985      1      0      0    347 0660     50     50 sem_shm_licenseExpireDate</p><p>0x0000031d  1 0000851985      1      0      0    347 0660     50     50 sem_shm_licenseExpireDate</p><p>0x0000031b  0 0000819216      1      0      0    347 0660     50     50 sem_evt_sensorAppRestartRequest</p><p>0x0000031b  1 0000819216      1      0      0    347 0660     50     50 sem_evt_sensorAppRestartRequest</p><p>0x0000031a  0 0000786447      1      0      0    348 0660     50     50 sem_upgradeLockSem</p><p>0x0000031a  1 0000786447      1      0      0    347 0660     50     50 sem_upgradeLockSem</p><p>0x00000318  0 0000753678      1      0      0    488 0660     50     50 sem_evt_mainAppEventSensorUp</p><p>0x00000318  1 0000753678      1      0      0    488 0660     50     50 sem_evt_mainAppEventSensorUp</p><p>0x00000316  0 0000720909      1      0      0  32152 0660     50     50 sem_evt_ct-mainApp.343</p><p>0x00000316  1 0000720909      1      0      0  32152 0660     50     50 sem_evt_ct-mainApp.343</p><p>0x00000315  0 0000688140      0      0      0  32152 0660     50     50 sem_ct-mainApp.343</p><p>0x00000315  1 0000688140      7      0      0    442 0660     50     50 sem_ct-mainApp.343</p><p>0x00000312  0 0000655371      0      0      0    413 0660     50     50 sem_pipe_ClntConnect_ct-mainApp.343</p><p>0x00000312  1 0000655371      2      0      0  32152 0660     50     50 sem_pipe_ClntConnect_ct-mainApp.343</p><p>0x00000311  0 0000622602      0      0      0  32152 0660     50     50 sem_pipe_SrvrConnect_ct-mainApp.343</p><p>0x00000311  1 0000622602      2      0      0  32152 0660     50     50 sem_pipe_SrvrConnect_ct-mainApp.343</p><p>0x0000030e  0 0000589833      1      0      0  32152 0660     50     50 sem_shm_ct-map</p><p>0x0000030e  1 0000589833      3      0      0  32152 0660     50     50 sem_shm_ct-map</p><p>0x0000030d  0 0000557064      1      0      0    442 0660     50     50 sem_ct-map</p><p>0x0000030d  1 0000557064      3      0      0  32152 0660     50     50 sem_ct-map</p><p>0x00000308  0 0000524295      1      0      0    526 0660     50     50 sem_evt_IpFifo_logAppFifo</p><p>0x00000308  1 0000524295      3      0      0    526 0660     50     50 sem_evt_IpFifo_logAppFifo</p><p>0x00000305  0 0000491526      1      0      0    526 0660     50     50 sem_shm_IpFifo_logAppFifo</p><p>0x00000305  1 0000491526      3      0      0    526 0660     50     50 sem_shm_IpFifo_logAppFifo</p><p>0x00000304  0 0000458757      1      0      0    526 0660     50     50 sem_IpFifo_logAppFifo</p><p>0x00000304  1 0000458757      3      0      0    526 0660     50     50 sem_IpFifo_logAppFifo</p><p>0x00000301  0 0000425988      1      0      0    526 0660     50     50 sem_shm_LogConfigManager</p><p>0x00000301  1 0000425988      3      0      0    526 0660     50     50 sem_shm_LogConfigManager</p><p>0x00000300  0 0000393219      1      0      0    526 0660     50     50 sem_LogConfigManager</p><p>0x00000300  1 0000393219      3      0      0    526 0660     50     50 sem_LogConfigManager</p><p>0x000002ff  0 0000360450      1      0      0  32152 0660     50     50 sem_curConfigFileSem</p><p>0x000002ff  1 0000360450      3      0      0    526 0660     50     50 sem_curConfigFileSem</p><p>Shared Memory Table:</p><p>key                id      size    cpid   lpid  nattch perm    uid    gid file</p><p>0x000003fa 0000294918    185320     347    635       3 0660     50     50 shm_IdsEventStoreShm</p><p>0x00000323 0000262149    102076     347    635       3 0660     50     50 shm_global-data</p><p>0x0000031e 0000229380         4     347    635       1 0660     50     50 shm_licenseExpireDate</p><p>0x0000030f 0000196611    120008     347    635       3 0660     50     50 shm_ct-map</p><p>0x00000306 0000163842    245780     342    635       3 0660     50     50 shm_IpFifo_logAppFifo</p><p>0x00000302 0000131073      4020     342    635       3 0660     50     50 shm_LogConfigManager</p><p>exec: cat /usr/cids/idsRoot/etc/sensorApp.conf</p><p>[NormalizerSettings]</p><p>QueuedTimeout=4</p><p>CID Diagnostics Report END Thu Mar 15 09:58:49 UTC 2012</p><p></p><p></p><p></p><p>IPS_Sensor#</p></body>
Mark
Well,
You are already on S632 signature set.
From the logs, sensor is currently not in bypass.
And "show statistics virtual-sensor" shows
Processing Load Percentage = 5
What is the issue that you are facing ?
Sawan Gupta
Thanks & Regards, Sawan Gupta
That's odd because IME is not reflecting that at all.
See the attached screenshot.  That is the issue that I am facing... it shows in bypass, CPU 100%, and signatures not up to date.
I just took this screenshot now as you will see in the time stamp.
Mark
Probably IME is stuck somewhere. Try refreshing/relaunching it.
If it doesn't help, please do file a bug.
Sawan Gupta
I had closed it after my initial post this morning sand opened it back up to take the screenshot afetr you said it looks fine.
Appreciate your help on this.  I'll go ahead and see about filing a bug.  I often feel like I'm the only one using an AIP-5!! lol
Mark
I didn't hear that about S632, thanks.  TAC poked around and said that the situation I was experiencing was a known issue in a previous IPS version, I think he said 6.2(3) but it might have been 6.2(2).  Eitherway, it was supposed to be fixed already but since I am experiencing it on 6.2(4), it was sent back to development to review.
The solution is to reload the module.  The good news is, as was pointd out in this thread, it's only a sync issue between IDM/IME and the IPS.  The sensor is actually running normally, but of course alerts wont work while in this state.
Mark
not12bhere
FYI-
S632 was one of the many signatures that has caused multiple ASA5505 SSC's to lock up on update. It really makes me uncomfortable that our IPS's fail to restart (and therefore enter bypass mode to keep our network from shutting down) on about 15-20% of the signature updates when using the auto-update feature. . .
