Renaming ASA 5525 IPS
I have a cluster of 2xASA 5525s with software IPS modules. I would like to rename the hostname of each of the IPS modules. This is easy enough but I was wondering how this affects the reporting data in IME. I know the IPS name is used as a PK field in IME so you can't edit it. I'm worried if I delete the devices from IME and re-add them with their new hostnames that the historic data will be lost for the sensors. Is there any way around this? Will IME automatically pick up the new hostname from the ISP meaning I won't have to re-add them?
63
