Reset IDSM2 post Signature Update
Dear Frdz ..
Would like to know ,Do I need to reset the IDSM2 version 6.2 after signature upgradation to be effective .
I wounder ,after upgrade the new signature is showing in IME but not sure if I need to restart after upgrade .
Thanks in advance
Regards ..
Manik Palekar
Re: Reset IDSM2 post Signature Update
HI Manik, No you dont have to reset/reload the box for signature/upradation or autoupdates to be effective, is your problem that CLI and IDM/IME is showing different signature version ?if yes then you may be hitting
CSCsq53214    IPS reports different sig version in CT and CLI
Check show version and see if it shows the correct Sxxx
Thanks for info ..
Our IME tool is showing the correct signature version (S513)and the CLI sh version is shwoing following output .
#sh version
Upgrade History:
* IPS-sig-S508-req-E4       22:46:16 UTC Tue Aug 17 2010
  IPS-sig-S513-req-E4.pkg   21:59:47 UTC Mon Sep 20 2010
Regards ..
Manik Palekar
Hi Manik, CLI as well as IME both shows S513, so you are good
Whats your concern ?
--regards
Ashish
you have addressed my concern ..Thanks a lot
338
