Seeing errors & FIFO Overruns on the ASA-SSM-10
A few of my customers are utilizing ASA-SSM-10 module running under ASA5510/20 hardware. The FW?s is part of the Failover configuration.
The module is running in "promiscuous fail-open" mode and the class-map for the IPS is applied as global_policy with access-list monitoring all the interfaces and all protocols.
In two independent cases, we are seeing errors on the Sensing interface GigabitEthernet0/1
Total Receive Errors = 772089
Total Receive FIFO Overruns = 3832
I've already verified speed/duplex settings on the FW side and I don't see any errors that would probably be causing this behavior. The bandwidth on the all interfaces is also nowhere close to the rated 150Mbps/s inspection.
Here is the scenario:
Client1 - HA
ASA 5510 Adaptive Security Appliance v7.2(2)19
ASA 5500 Series Security Services Module-10 v5.1(6)E1
Client2 - HA
ASA 5520 Adaptive Security Appliance v7.2(2)10
Wondering if anyone has seen the behavior in their environment and what might be causing it?
239
