Sig 5753 (s230) - numerous fale positives + proposed fix
To make a long story short: I was investigating a bunch of these signatures firing, and found that simple poor coding (typos, mostly) were triggering all of our events with this sig.
I ran through the RegExp, and discovered that the string stops processing after a double quote ("").
So, a simple typo that ends with ...href="mailto:null@null.com""> will trigger this signature to fire (as it has done many times in our case).
The simple solution I've found would be to add a "not closing tag" ( [^\x3e]+ ) to the end of the RegExp, as such:
[\x3c][Aa][\x20\x09\x0d\x0a][Hh][Rr][Ee][Ff][\x20\x09\x0d\x0a]?[=][\x20\x09\x0d\x0a]?[\x22\x27][Mm][Aa][Ii][Ll][Tt][Oo][:][^\x22\x0d\x0a\x3e]+[\x22][\x22][^\x3e]+
With that RegExp, if there's anything between the "" and the >, the sig will trigger.
Hopefully, the fine folks at Cisco can include this in a sig update in the near future.
-David
1 REPLY
Re: Sig 5753 (s230) - numerous fale positives + proposed fix
I will look into this and get back with you shortly.
121
