SSM-40 ver7.1.(8)E4- and Tripwire File Integrity check
                   We recently upgraded to this version of the firmware from ver 7.0.6
When we did - Tripwire File Integrity fails to discover the command prompt when pulling the configuration.  It does not execute the --more-- command.
Has anyone else experienced something similar on this firmware?  We can execute the command from an ssh command.
Thanks!
We have nother node workinging on the older firmware which is fine. Any workaround - how are you dealing with it?
Re: SSM-40 ver7.1.(8)E4- and Tripwire File Integrity check
BTW- I should add - the device logs on - it does not get past the Cisco license which displays. It hangs where in theory the first "more" would exectue - to pass through the text. The problem is there is not a way for me to execute the more command (ie term length 0) or anything prior to the logon - because once the Tripwire interface logs in - the CISCO license displays and pauses halfway through - and requires the more command before it gets to the command prompt. Because this command is never executed - it hangs and then times out. I also should add that the new firmware appears to be using a later version of ssh - 199openssh_5.9 - as opposed to 199openshh_3.71ps as the former version of firmware was.
223
