Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
SSM MODULES and Mars events and local?
Is it possible to setup an AIP-SSM Module to log event alerts to Its local cache as well as the Mars Appliance. I say this because I ran some tests for alerts and never see them on the IPS module itself but i do see them on the Mars Appliance correctly! I dont know what setting would need to be changed to make sure that the event alerts are logged to the local IPS itself. Or is this even possible?
does anyone know how to make it log locally and to the MARS Appliance?
1 REPLY
Silver
Re: SSM MODULES and Mars events and local?
Make sure Bypass mode is not enabled on IPs Module. Another workaround for this issue is to reload the Advanced Inspection and Prevention Security Services Module (AIP-SSM) IPS module with the hw-module module 1 reload command, and tune any noisy signatures in order to lighten the sensor load.
140
